TACHOMETER REMOVAL IN MONDIAL | FerrariChat
Discussion in 'Technical Q&A' started by TOM B, Feb 15, 2004.
  1. TOM B
    TOM B Formula 3
    Jul 24, 2003
    1,038
    Orange County, NY
    Thomas Buckley
    I was asked to post my procedure for removing the tach from my Mondial.
    Around the tach there is a black, square, plastic frame. To remove, I used a scraper made of plastic so as not to damage the frame. It is just held in place by 4 plastic knobs which are a press fit into 4 corresponding holes. Just gently pry against the side of the frame and it should pop out. This exposes 4 self tapping screws . one at each corner of the tach. Remove these and the tach comes out. Before removing any wires, I recommend writing the color of the wire at each connection on the white plastic of the tach.
    The charge from Palo Alto was $159.00 and they turned the tach around in one day. An added benefit I received (besides an accurate tach) was that my odometer and trip odometer are now working perfectly. Previously, the trip odometer would get stuck and would stop the odometer. Spinning the trip odometer knob would get them both going again. Who would have thought that the odometers worked off the tach ?
    Tom
  2. Vivaldi
    Vivaldi Karting
    Aug 1, 2001
    83
    SoCal
    Alex Vivaldi
    Thanks, Tom!
