Test pipes difference | FerrariChat
Discussion in 'Boxers/TR/M' started by Natkingcolebasket69, Nov 19, 2017.
  1. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Quick one guys: do you think there are differences between cat delete pipes? I know the difference in price isn’t probably justified but i wanted to ask your expertise and thoughts?
    Capristo? Tubi? No brand?
    Im just curious! You guys have seen it all;) Image Unavailable, Please Login
  2. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    But you will get a check engine light if you decat it ?
    Sent from my FRD-L14 using Tapatalk
  3. Natkingcolebasket69
    Nope. Mine was decatted before. No CEL. I got ansa test pipes. Just wondering if some are better than others;)
  4. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Early TRs have no check engine light. I don't know when they received them. Maybe 1995?
  5. Natkingcolebasket69
    I would think with the 92 512TR? I am not positive though.
  6. ago car nut
    5,267
    Madison Ohio
    David A.
    If the test pipes are straight thru. and the same dia. So probably no difference. The ones with resonators maybe just are quieter.
  7. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    If you only slap on the test pipes there will be no difference in sound or probably power. I found a set for cheap and did the swap......no difference in sound and I couldnt tell any HP gain.
    Natkingcolebasket69 likes this.
  8. Natkingcolebasket69
    I agree as far as hp but when i had mine own it was louder, much louder;)
  9. 53ford
    53ford Karting
    Nov 13, 2009
    112
    You need to lose the precats too. They are the sound and power thieves. Several companies make them, I think mine are Capristo.
  10. Natkingcolebasket69
    I run tubi pre cats;) and i have some ansa test pipes, not on right now though. I have the cats.
  11. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Ahh gotcha. I have stock precats and had test pipes for the test. Put it back to stock a few days later.
  12. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,117
    Mel
    Testpipes on a TR make far too much sound imo ... remember that video of my friend in NL ....
  13. Melvok
    Jul 25, 2008
    14,117
    Mel
    What I wrote ... TOO loud ? Swapped them back ?
  14. Melvok
    Jul 25, 2008
    14,117
    Mel
    I have a set of those Tubi straight pipes still for sale if you want them cheap :)
  15. Natkingcolebasket69
    What configuration did u run? Tubi ? Did you have precats?
    U are a very values member! Love ur expertise and experience!
  16. Natkingcolebasket69
    I swapped them back bc of snog requirements here but i have tubi precats though and ansa exhaustion... i wanted to possibly put them back on to try and see what a straight pipe sound was like on the TR.
    I was also wondering if there were differences between my ansa test pipes and say Capristo or tubi?
  17. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    I think those pipes you still have are for the original cats, not for the precats what they have in US and also may be in switzerland, but not sure there
  18. Natkingcolebasket69
    I have tubi straight pipes precats i bought from eurospares.
    I was more inquiring on the difference between the different brands that make test pipes to replace the original cats. I see capristo cost like 800 usd, and u can also find some for 200 usd (no brands).
    I have some ansa not mounted on and im wondering if some pipes provide better sound than others etc ? Maybe stronger?
  19. Melvok
    Jul 25, 2008
    14,117
    Mel
  20. turbo-joe
    Apr 6, 2008
    8,934
    romano schwabel
    so this you still have from the "better times" :) are not the pipes for the pre cats, for the cats itself?
  21. Natkingcolebasket69
    Thats a cat delete picture. My question was to see if there was a difference of quality between brands.
    The precat delete pipes are different ;) but u guys know more than me;)
  22. Melvok
    Jul 25, 2008
    14,117
    Mel
    #22 Melvok, Nov 21, 2017
    Indeed! Sicher :D
    For replacing the cats. Because they are hollow, there will be no difference other than the material of which they are made of.
    Mine are FUCHS by-the-way ... the BEST :D
  23. Natkingcolebasket69
  24. Melvok
    Jul 25, 2008
    14,117
    Mel
    Woow ... better than new :D
