Testarossa engine removal step by step | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by ang308, Jul 7, 2018.
  1. ang308
    ang308 Formula Junior
    392
    Stamford, CT
    Billy
    Now the fun begins. Start undoing all connections and vacuum lines. Disconnect vacuum lines at motor and then put aside. There are 3 little ones and one big one on my car. The big one to feed vacuum to brake booster???? I’m not sure. There is a 10mm clamp that holds the two vacuum lines under passenger side distributor on the exhaust cam seal. It is held in place by a 10mm nut
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. ang308
    392
    Stamford, CT
    Billy
    Next on the driver side exhaust cam seal is a vacuum booster. Disconnect hose to that and pull away. As soon as I disconnected I heard a swoosh so I know it is holding vacuum but what was weird is a little oil cane out of hose. Is this normal??? Maybe one of you guys can tell me
  3. ang308
    392
    Stamford, CT
    Billy
  4. ang308
    392
    Stamford, CT
    Billy
  5. ang308
    392
    Stamford, CT
    Billy
    With oil vapor hose out of the way you have to disconnect air cooler hose for alternator. Undo the clamp and remove air hose out of the way.
  6. ang308
    392
    Stamford, CT
    Billy
  7. ang308
    392
    Stamford, CT
    Billy
  8. ang308
    392
    Stamford, CT
    Billy
    Here is where things might be different cause of my setup. On the driver side intake the last bolt there are a couple grounds that are hooked up. It’s a 13mm I do that and remove ground wires
    Lavenknight likes this.
  9. ang308
    392
    Stamford, CT
    Billy
    Next up I have to remove air cleaner and housing roger to starter. You don’t really have to but it makes life easier. The top is held by 4 blade screws. The 3 are easy but the fourth one is under the vapor hose that is attached to rear of air intake housing. Remove that hose it’s a little bit of a pain but then you can get to the 4th screw. Also undo the 2 clamps that go to the throttle bodies.
  10. ang308
    392
    Stamford, CT
    Billy
  11. ang308
    392
    Stamford, CT
    Billy
    Now remove the 13mm nut that holds the positive wire at starter. Take out cable and fish out towards passenger side rear quarter panel.
  12. ang308
    392
    Stamford, CT
    Billy
  13. ang308
    392
    Stamford, CT
    Billy
    Next up I undid the ac connections. Before ameveryone cries foul that I’m polluting the ozone my car hasn’t had Freon in it for a while. Top hose is 1 1/16 and lower is 23mm
  14. ang308
    392
    Stamford, CT
    Billy
    With air cleaner out of the way it’s essy to disconnect accelerator cable. Take cotter pin out of gas pedal line. Then unscrew center just enough to pry off. I drppped screw and had to look for it So just loosen enough to pry off ball
    Use vice grips to hold cable while unloosening the 8mm hold bolt. Then unscrew the holder that attaches to the ball on throttle plates. Fish out the cable and put aside. Mine went through in between alternator and bracket. Just a reminder for later
  15. ang308
    392
    Stamford, CT
    Billy
  16. ang308
    392
    Stamford, CT
    Billy
    And this is where I stopped for the day. Because of custom made wire harness to feed efi I have to take off upper intake runners and fuel distributors. Couldn’t they make a quick disconnect for this. Uugh. Life would have been much easier. So tomorrow I’ll get into that and take photos as well even though in regular tr this doesn’t need to be done
  17. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    These are great threads! Thank you Billy. Oh, please post a photo of that 355 peeking out ;)
  18. ang308
    392
    Stamford, CT
    Billy
    When I get home later I will. I have to change plugs in that next. Car is running a bit rich and they fouled up causing a small miss. But after this service I’ll do that. And searching I found best plugs for 355 are ngk Zmr7ap. Right now I have iridiums in there don’t know which ones off hand but car is a 95 without cats.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
  20. ang308
    392
    Stamford, CT
    Billy
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
  22. ang308
    392
    Stamford, CT
    Billy
    Dave rocks likes this.
  23. ang308
    392
    Stamford, CT
    Billy
    Success. I got motor out. So because my car has a custom wiring harness I had to remove intake manifold. I will include it here but it’s definitely not necessary for taking motor out. On regular cars I believe there is just the disconnect from battery under car and a 9 pin connector at rear by coolant tank.
  24. ang308
    392
    Stamford, CT
    Billy
  25. ang308
    392
    Stamford, CT
    Billy
