Testarossa engine removal step by step | Page 4 | FerrariChat
Discussion in 'Boxers/TR/M' started by ang308, Jul 7, 2018.
  1. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,105
    Allentown, PA
    Tim
    Hi David-
    I just searched through your past posts to find the one you're referring to describing removing the engine without a lift, but I was unable to find it. Would you mind posting a link? I'm considering doing the major on my own this winter and if I could put off the purchase of a lift, it would certainly help me afford more parts!
  2. ago car nut
    ago car nut F1 Veteran
    5,469
    Madison Ohio
    David A.
    Try this search under my name.
    TR transaxle rebuild
    xplodee likes this.
  3. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,421
    Alabama (was Mich.)
    Jeff
    It is also possible to leave the rear wheels & tires on, and use a floor jack under the front cross-frame of the engine cradle, and roll everything out from under the car body. Like Ago Car Nut....I have done quite a few engine-outs without a lift this way. I eventually made a "swiveling castor" that bolted to the front engine cradle, that way I could roll it around the garage as needed.
  4. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Stripped bleeder:
    Carefully clean the bottom of the bleeder hole. A sharp point works well - slow and easy so it is not scratched. Without clean surfaces it won’t seal. Over torquing and corrosion strips the threads. Adding a helicoil may be problematic with the tapered seat at the botton of the hole. It might be worth a trip to a qualified machine shop for that repair - personally, a DIY solution could be difficult (but thats just me). Always use plenty of anti- seize on the threads, but keep it off the seat.
    Good luck with your repair on that one.... please keep us updated. I’m eager to see how its done.
  5. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,056
    Troy, Michigan
    James
    what city? I can help you for sure. Did my '86 two years ago. I have a cradle I built too.
  6. ago car nut
    5,469
    Madison Ohio
    David A.
    Nick, just take your time and treat it as a labor of love.
  7. Warlock
    Warlock Rookie
    Nov 24, 2013
    4
    Dallas, TX
    Sunny
    Hey @raysur did you ever get around to making a thread about dropping the engine using a 4 post lift?
  8. raysur
    raysur Formula Junior
    608
    So. Cal.
    Jeff
    I didn't make a thread but I had a post outlining the steps. I'll search for it.
    Warlock likes this.
  9. ago car nut
    5,469
    Madison Ohio
    David A.
    I had mine out twice before I had a 2 post lift.
  10. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,452
    wisconsin/chicago
    bo
    You can do it with a scissor lift too….
  11. MAFIOSA
    MAFIOSA Rookie
    Oct 4, 2013
    46
    tell me why have mechanics doubles their labour cost to do this
    in 2016 i paid $1500 labour plus parts ,now its $3500.00 to $4,000 USD PLUS PARTS
    i honestly dont like mechanics anynore
  12. bpu699
    Dec 9, 2003
    17,452
    wisconsin/chicago
    bo
    You paid $1500 labour to do a major? I heard it was closer to $20,000 today. Last major that the PO of my car did 20 years ago was $15,000. Then I did my own.
    turbo-joe likes this.
  13. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,409
    romano schwabel
    mafiosa ( the name obliges ;) ) seems to have all for free ? ;)
  14. Rifledriver
    36,779
    In fantasy land maybe.
  15. ago car nut
    5,469
    Madison Ohio
    David A.
    I know this is old post. Anyway, I made a cradle that was referenced on this forum. Put 4" blocks under front tires, removed rear wheels and lowered engine and rear chassis onto low cradle. Then raised car up with two floor jacks from both sides. Rolled engine on cradle out. I have since moved and have a lift now.
    Warlock likes this.
