That old car smell is back! 1970 Aston DBSV8 | Page 4 | FerrariChat
Discussion in 'British' started by carguy246, Aug 8, 2022.
  1. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    Thanks. I’m working on some of the mechanical and electrical issues. Just figured out last night that while all the fuses are good they were corroded and some were not making contact so I’m getting new fuses and I’ll clean the fuse box contacts. Pretty easy because there are only 12 fuses. Once I get the new fuses that should resolve some more issues. Just moving the fuses got the side lights working and I got the turn signals working as well. I also have an appointment with a local shop to get new tires installed and change the transmission and differential fluid. I’ll probably get most of the mechanical issues resolved around the time they salt the roads and I have to stop driving it.
    Hopefully I can get the trunk carpets sorted out over the winter.
    I'm kinda amazed how good the engine sounds right out of the box without any tuning.
  2. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    Thanks, sorry it took so long but it was worth it.
    audi_328 likes this.
  3. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    So a quick update. Drove the car to a local European car shop and had them install new tires and change the transmission and differential fluid. When I got the car back I was checking some of the fluids and noticed the brake fluid level was a lot lower than when I originally filled it before I started driving it.
    The car has a firm pedal but the brakes don’t seem to work that well, like there is no power assist. I couldn’t find any leaks so I did some research. Turns out the brake boosters can leak internally and fill up with brake fluid. I didn’t see any fluid in the vacuum line but inside the booster was full of brake fluid. Other one had the same problem. So I removed both of them and will send them off to be rebuilt this week.
    Also removed the tachometer and will be sending it out to be rebuilt. The roads are heavily salted now so I can’t drive it until spring anyway. More to follow in the spring.
    Statler, Bullfighter and Simon like this.
  4. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    Oengus and BJK like this.
  5. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    I got the rebuilt brake boosters back and got them installed but I need to bleed the brakes again, which requires removing the back seat -again. On the plus side, the car should be ready for more test drives once the salt is off the roads.
    Simon likes this.
  6. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    Bled the brakes and took the car for a short drive.
    Good news, tachometer is now working.
    Bad news
    -brakes work but still no power assist, I’m guessing the problem is a lack of vacuum probably from as leaking vacuum hose etc.
    Also disconnected the speedometer to see if the cable was turning when the car was moving and it was, so the speedometer likely needs to be rebuilt.
    More to follow.
  7. carguy246
    carguy246 Formula 3
    1,202
    Maryland
  8. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    I’ve made some progress on the cold start problem, I can jump the cold start injector to inject fuel and the car starts better but still not easily. I’m thinking the cold regulator (or whatever it’s called) on the Bosch injection pump isn’t working or needs adjustment.
    The only thing that is preventing me from driving the car is no power assist on the brakes. The boosters were just rebuilt, the car is generating vacuum and I can’t find any leaks in the vacuum hose, so I’ll do some more investigating this weekend. Really hoping I don’t have to remove the boosters again or bleed the brakes again.
  9. Bluebottle
    Bluebottle F1 Veteran
    8,586
    Newbury, Berkshire, England
    Good luck with that - I am sure you are looking forward to getting the old girl back on the road.
    carguy246 likes this.
  10. AstonAMV8
    AstonAMV8 Rookie
    Apr 20, 2025
    1
    Steve Horsman
    Nice car. I have a AMV8 1972 and i have converted it from the original Bosh fuel injection to EFI. However i still have a smell of petrol. Do you still get your smell lingering in the car and do you know if this is a common issue with this type of car? Had mine for approx 5 years now. New fuel lines etc and still that smell. Any suggestions? Thanks Steve
  11. Oengus
    Oengus F1 World Champ
    I’ve been slowly looking for a late 70’s carbureted AM V8
  12. 71Vette
    71Vette Karting
    Oct 24, 2023
    213
    Stuttgart, Germany
    Esben
    What a lovely car - congrats!
    Esben
  13. carguy246
    carguy246 Formula 3
    1,202
    Maryland
    Sorry for the delay in responding. Is the fuel smell in the engine compartment or somewhere else? If it is in the engine compartment, the fuel filter is located on the center of the firewall. I would check to see if it is leaking. If it isn’t leaking I would trace the fuel lines in both directions (towards the fuel injection and back towards the fuel tank) looking for any leaks.
  14. Roo
    Roo Rookie
    May 29, 2006
    31
    I also have a 1972 AMV8. Most sources of fuel smell come from the tank. After 53 years you may find the bottom of the tank starts rusting out from water in the fuel. Small pinholes allow leaks and the resultant smell. Best option is to remove the tank and reseal if it it is not too far gone. Also make sure all the plastic fuel lines are renewed.
