The BORA | Page 83 | FerrariChat
The BORA
Discussion in 'Maserati' started by wbaeumer, Aug 11, 2011.
  1. thecarnut
    thecarnut F1 Rookie
    3,275
    Atlanta
    The Car Nut
    I am in the process of disconnecting the gearbox linkage. The small screw that holds the u-joint is giving me trouble. The nut came out without any issues but the screw will not drift out. Are there any tricks to remove this screw?
    Ivan
  2. eogorman
    eogorman Formula Junior
    May 10, 2005
    340
    Buhl, ID
    Eugene O'Gorman
    It is a tapered pin and the nut is on the small end of the taper. Loosen the nut a couple of turns and try a c clamp. Maybe a little heat
    71Satisfaction likes this.
  3. staatsof
    96,451
    Fuggetaboutitland
    Bob
    Yes utilize the nut as a way to protect threads. Add a thin washer under the nut so that you don't bend it over when using a medium sledge hammer with a short handle to effect impact shock to break the grip. Support the joint in some fashion. from behind. I used something to the floor which means the pin needs to be vertical.
    These are a real beotch to get out. Spraying some Kroil on them first and letting them soak for at least over night.
    I think I bought new taper pins where needed and threaded the ends. Definitely put anti-seize on them.
    Before removing the sliding portion that's under the headers see if it slides nicely. On my those two mounts were operating different planes so the shaft would bind which makes for crap shifting.
    I used small shim washers to get them aligned and that work beautifully.
    I also added a piece of straight silicone hose between the mounts to keep the sliding needle bearings from drying out due to the heat with slide seals on the outside ends. But you do need to add filtered vent just like with the CV boots because it all heats up.
    Use silicone boots not the OEM crap. If you dig you can find them.
    Did I mention this was a real beotch? ;):p
    71Satisfaction and Ferraripilot like this.
  4. 71Satisfaction
    71Satisfaction Formula 3
    Jul 15, 2012
    1,325
    New York and Norway
    Art
    Ivan, both Eugene and Bob have good advice.
    They are all tapered pins, remove them like a tiny ball joint. Mine were stuck so hard they got badly damaged. I bought replacement u-joints, tapered pins and a tapered drill bit from Aircraft Spruce & Specialty Co.
    When re-assembling, note that you do NOT need to torque that nut down hard AT ALL. Leave it just snug. I had to recondition the steering bars on Khamsin 1196 with the same tapered-pins at the under-dash U-joints. These came out with a light tap because they were installed "gently". That was a learning moment.
    - Art
  5. 71Satisfaction
    Jul 15, 2012
    1,325
    New York and Norway
    Art
    Good morning all,
    What is the general or specific location of an OEM voltage regulator in a 1975 Bora? I'm suddenly getting a weak Generator warning light and voltage gauge showing 10V when running the Bora. My first intent is to check that none of the wiring at the alternator has come apart, but I suspect the voltage regulator. Any other suggestions are welcome, but I'll start there.
    Cheers,
    - Art
  6. staatsof
    96,451
    Fuggetaboutitland
    Bob
    I think it's up front LH side behind Head lamp bucket. That means removing the dreaded skin shredding wire grill in the luggage compartment.
    There's a much more modern solid state Bosch for later than the Bora from a Mercedes. It's probably in the interchange list.
  7. Cepat
    Cepat Formula Junior
    265
    Florida, USA
    Dean
    #2057 Cepat, Jun 23, 2025
    by this do you mean increase the size of the factory opening for reciculation? That would of course render the flap useless, although I see no reason why I wouldn't want some recirculation even if the fresh air vent is open.
    Or is there another area to make a second hole?
    I did what Ivan said and put a spacer to bring the front cover in the frunk a cm or so away from the firewall there and seems theres a bit more air flow. Will report back after driving on a hot day if it helps. I didn't do the separate circuit on a relay thingy yet.
  8. staatsof
    96,451
    Fuggetaboutitland
    Bob
    Well I never actually did it to mine but let me describe how my friend discovered this issue. H was unhappy with the air flow through the vents and decided first to put in a more powerful squirrel cage fan. His son was in the trunk and when the fan was on high he was unable to pull the panel inside the trunk off because the suction was too great. So hiss deduction was the opening into cabin that it sucks from was undersized. I don't know where that opening is so you'll have to figure it out. Once he did that the system performed much better and he was utilizing the old York compressor with R12. I believe he had the roto-lock with O-rings connectors. The idea is to create more airflow when recirculating. He lived in a hotter part of the bay area climate and would regularly see 90-105F during the summer.
    Hope that helps.
    Cepat likes this.
  9. thecarnut
    thecarnut F1 Rookie
    3,275
    Atlanta
    The Car Nut
    Update: After trying multiple things and failing, a friend suggested an air hammer. I bought a cheap one on Amazon plus a set of blunt bits. The pin was out in less that 15 seconds.
    Ivan
    Ferraripilot and staatsof like this.
  10. thecarnut
    thecarnut F1 Rookie
    3,275
    Atlanta
    The Car Nut
  11. staatsof
    96,451
    Fuggetaboutitland
    Bob
    Congrats VICTORY!
    If you attach a pair of large casters bolted to the front chassis mounts of the subframe, remove the shocks and springs then insert some pieces of 2x4in the A-arms to prevent them from collapsing you can easily wheel the entire subframe and engine around on the floor.
    highwaybora likes this.
  12. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,978
    Atlanta
    John!
    Fabulous. What winning looks like!
  13. thecarnut
    thecarnut F1 Rookie
    3,275
    Atlanta
    The Car Nut
    I was thinking of moving the subframe assembly around the garage but have now decided against it. My biggest concern is how to re-align everything when it comes time to install the subframe. The holes for the four bolts must be perfectly aligned. If I move the subframe then I will need to somehow be able to move it in all four directions in order for the holes to align. The body is in a fixed position and can't be moved; it only goes up and down. If I leave the subframe on the jack stands then by lowering the body the holes should still be aligned. At least that is the theory.
    I should be able to pull the heads where the engine sits now.
    Ivan
    Ferraripilot likes this.
  14. staatsof
    96,451
    Fuggetaboutitland
    Bob
    Let me just say as someone who's done this with taking everything apart, sandblasting it, having it powder coated, replated and then reassembling the engine plus transaxle on the subframe and subsequently lifting it back up again via a pair of floor jacks under a piece of plywood under the oil pan ... your fears are completely misguided. The main body and it's frame plus the subframe itself are so rigid and accurate in manufacture that alignment is not an issue.
    This is totally different than my rear GOC's subframe and body which had solid aluminum mounts substituted for the rubber ones and that was a real SOB to do with me lying under the car on jack stands using both of my legs and arms to spread everything to get it all to align so that the bolts would go through. The Biturbo in Ghibli guise was still a sloppy and imprecisely manufactured car.
    The Bora, at least mine is not. when I completed the subframe & engine structure I rolled it out onto my driveway in SF to take pictures of because it was so impressive looking. My driveway was not flat and indeed had many twist's and undulations as it crossed a 12 ft wide sidewalk and a 3 ft elevation change. That didn't torque anything out of alignment. But make sure the top cross brace over the transaxle is bolted firmly in place.
  15. thecarnut
    thecarnut F1 Rookie
    3,275
    Atlanta
    The Car Nut
    Perhaps I did not explain myself clearly. Of course the subframe is rigid and the mounting holes locations on the subframe will not change. What will change if I move the subframe around is the location of those holes with relation to the body that is sitting above it.
    Ivan
  16. thecarnut
    thecarnut F1 Rookie
    3,275
    Atlanta
    The Car Nut
  17. Nembo1777
    Nembo1777 F1 World Champ
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    Italian Voodoo incantations under a full moon, works even better with Modenese dialect:D.
    Best of luck with the process.
  18. JCR
    JCR F1 World Champ
    11,103
    H-Town, Tejas
  19. staatsof
    96,451
    Fuggetaboutitland
    Bob
    So what? I didn't have a lift. I dropped it down and put it back up via a piece of plywood under the oil pan and a pair of floor jacks.
    Ivan, it's been some 35 years ago so my memory about everything I did may not be complete but I didn't have a lot of fancy tools at the time and I made out just fine. I even suffered through an earthquake in the middle of all of that. I added four more jack stands earlier that week because it looked a bit shaky to me. The earthquake shook left to right with respect to the car so much that all of the Victorian row houses in my block ended up leaning 6" to the left and up against each other.
    How ever you want to accomplish this I think you need to be prepared to move that subframe around a bit for final alignment as you drop the car back down onto the subframe and engine.
    Good luck.
  20. staatsof
    96,451
    Fuggetaboutitland
    Bob
    I watched this this morning. I like his short videos. Yes I don't find the seats very comfortable for long trips. I have long legs and I had to tuck my legs behind the pedals at time for some relief.
    But he did make a few errors like the rubber mounts for the rear subframe. But the NSX reference was spot on. We were making that same comparison back then. I took my double glazed window and turned it into a true fully sealed thermopane window which the original was not. When you have the the subframe and engine out of the car you can do that. I re-utilized the original runner gasket by cutting the center divider out of it. That worked very well.
    But yes it didn't sell well, still doesn't. Perhaps because it's a bit too civilized?
    Then there was the oil crisis and Maserati was broke which meant it got sold off to DeTomaso.
    Nembo1777 and Ferraripilot like this.
  21. staatsof
    96,451
    Fuggetaboutitland
    Bob
    This approach won't work with wheels on the ground but the last time when I was trying to check the timing chains I would put it in gear an rotate the rear wheels. I assume that you're trying to locate the master link because heads have to come off? I link you'll need to pull the engine out of the subframe and put it on an engine stand. That's what I did and the tranaxle came off so for the timing the engine I did it from the rear using Stan Bishop's excellent guide. Lot's of work ...
  22. Ferraripilot
    May 10, 2006
    17,978
    Atlanta
    John!
    That's a great idea with the glass.
    Alfieri really wanted to make a 12 (I heard flat 12 specifically) for the Bora but it wasn't in the cards financially. That, IMO, is why the Bora isn't a real competitor with the Boxer/Countach, just not exotic nor fast enough but certainly more useable.
    The 'real' no malarkey power figure for a 4.7L Bora engine is around 270hp, whereas the Ferrari 365BB 'real' figure is around 340hp, there's just no comparison nor real sense in truly comparing performance for that reason. A Bora with it's refined and more useable demeanor combined with a real 340hp from new would be an entirely different kettle of fish though
  23. staatsof
    96,451
    Fuggetaboutitland
    Bob
    The top speed number cited in that video are BS. No Bora ever went that fast. My Bora (4.) does an honest 0-6o in 6.o seconds. That's what the short gears does for you and 140 mph rev limited is plenty fast enough .
    I've driven at 135 mph across Nevada for an hour at a time. any more than tat and these cars wander anyway.
    I drove my friends Bora another 4.9 @ 5000 ft elevation near Ely NV @ 160 mph (long gears) and it had the Merak front lip. That didn't help at all it still wandered. I also drove his 87 Countach double downdraft an Al Burtoni car and it didn't seem all that much faster but it WAS crazy exotic looking and that's difference I believe. The Bora was too conservative looking at the time when you consider the Miura, Countach Ferrari BB it was also a F of a lot more money than a Pantera. That guy in the #27 video is in for shock by comparison once he gets it running. The Bora is so much more refined than all of those cars but it has it's issues.
    It is a very strong car chassis and body wise. On one drive out to Ely, NV for the Silver State race we got on 50 after leaving Reno and after about an hour it feels safe enough from police presence that you can open it up. So I'm doing a nice 130 and way off down the road I see a sign too small to make out, especially at that speed but once I did OMFG! New pavement ahead and it's a 3" bump of new pavement I'm hitting at say 120 MPH. That's all I could drag the speed down to. The noise that made as every suspension corner hit the bump stops and echoed through the cabin.
    I pulled over got out the flashlight and inspected everything I could se. Zero damage, later confirmed when I got home. Impressive.
    highwaybora, Froggie and Ferraripilot like this.
  24. Ferraripilot
    May 10, 2006
    17,978
    Atlanta
    John!
    Good stuff Bob, thank you. We enjoy your tales!
    For recording purposes, the below is a bone stock 4.7L dyno sheet. Although the sheet notes 258.2hp, there's a few asterisks the need unpacking so read on.
    Two things to note about this pull:
    1) I am told the pull was stopped at 5200rpm due to it being a new engine and not wanting to stretch it too much, but it was looking like it was going to pull another 5-10hp.
    2) the carburetor jets were also bone stock, meaning it was undoubtedly running dangerously lean (thus losing a chunk of hp) as is the issue with modern fuel compared to the old good stuff. Jetting for modern fuel not only makes the thing run cooler, but also gives you at least another 15hp+ when it's running as intended such is the difference in fuel now. I've picked up 10-12hp at the wheels on a dynojet rejetting carbureted 308s, not kidding. Makes a big difference.
    This is why I'm stating the 'real 4.7 figure', when set up correctly, is in the 270-280hp range, very possibly a touch more than even that though.
    71Satisfaction and Froggie like this.
  25. am117au
    am117au Karting
    Apr 22, 2014
    231
    Sydney Australia
    Greg G
    Ivan
    I had to use ratchet tie down when i restored my Bora,, It was a hell of a job aligning all the bolt holes.
    Greg
