The BORA | Page 84 | FerrariChat
The BORA
Discussion in 'Maserati' started by wbaeumer, Aug 11, 2011.
  1. staatsof
    96,349
    Fuggetaboutitland
    Bob
    This is the problem I ran into with my Espada. I could not get it to run well with the stock jets and when I ran into a slew of Countach owners dealing with the same issues I found out that the idle circuits and accelerator pump circuits on those DCOE s just had to be modified due to how differently these engine run on gas with alcohol in it. What a PITA!
    Somewhat anecdotally I had a chance to compare gas with and WO alcohol on a more modern car my 2005 Jaguar S-Type R.
    A car that doesn't sip gas anyway. It's very hard to hit 21 MPG on the highway even if you're very careful.
    Round trip from my house in NJ to a spot in PA that sell alcohol free gas at a then reasonable price. I approached 24 MPH on the trip home .
  2. staatsof
    96,349
    Fuggetaboutitland
    Bob
    DOH! ;):p
    Nembo1777 likes this.
  3. Conaero
    Conaero Rookie
    Dec 2, 2013
    22
    Chichester
    Matthew Yates
    Afternoon could one of you kind Bora owners tell me what version of the Carello H4 7” headlight are?
    should be a part number on the glass- xx.xxx.xxx
  4. thecarnut
    thecarnut F1 Rookie
    3,271
    Atlanta
    The Car Nut
    Both heads are now removed. Trying to do this with the engine still in the car would have been extremely difficult. Getting both chains to have the master links visible while the engine is at TDC is a task by itself. I probably rotated the engine 50 times before both links were visible at TDC.
    Ivan
    Cepat, Ferraripilot and Astonish78 like this.
  5. staatsof
    96,349
    Fuggetaboutitland
    Bob
    Insane actually. Not that dropping the entire assembly is easier either. Are you taking the transaxle off to check on the clutch etc?
  6. thecarnut
    thecarnut F1 Rookie
    3,271
    Atlanta
    The Car Nut
    I was not thinking of looking for additional work but I will use a horoscope to see if I can determine the condition of the clutch lining and throw our bearing. The clutch was not shattering, which many Boras do, so I am inclined to leave it alone.
    Ivan
  7. staatsof
    96,349
    Fuggetaboutitland
    Bob
    One of those two huge bolts that the shocks and springs hang on never came out of my car. Even after I had the sub-frame out, made trickier by the one bolt all efforts failed.
    I suggest some anti-seize. I wonder if a bigger version of the tool you utilized on the shift linkage taper pins would have worked.
  8. thecarnut
    thecarnut F1 Rookie
    3,271
    Atlanta
    The Car Nut
    The shock bolts were not a problem to remove. Anti-sieze is a good idea. I was told by a Maserati mechanic that the springs would not be under any tension when the rear tires are in the air .... not true. When it comes time to re-assemble I plan to reattach the springs before the cage is fully back in its place.
    Ivan
    Ferraripilot likes this.
  9. staatsof
    96,349
    Fuggetaboutitland
    Bob
    What sign are you? ... ;):p
  10. thecarnut
    thecarnut F1 Rookie
    3,271
    Atlanta
    The Car Nut
    Perhaps it wasn't a typo :) You sometimes need help from the stars in order to work on these cars.
    The heads are now in the very capable hands of Ferraripilot, who is checking them out. I now know that two V8 heads fit in the trunk of a Granturismo.
    Ivan
    peterp, Nembo1777 and Ferraripilot like this.
  11. staatsof
    96,349
    Fuggetaboutitland
    Bob
    When things got really difficult in all of my early early Biturbo travails I used to post about building a huge bonfire and dancing around it naked whist swing a dead chicken around madly.
    Cepat likes this.
  12. Nembo1777
    Nembo1777 F1 World Champ
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    Maserati Bimotore;-)
  13. italiancars
    italiancars F1 Rookie
    Apr 18, 2004
    3,463
    Hershey, PA
    that’s an image I really didn’t need
  14. staatsof
    96,349
    Fuggetaboutitland
    Bob
    What about two sets of golf clubs?
  15. staatsof
    96,349
    Fuggetaboutitland
    Bob
    I have some HI-8 video if you'd like, I didn't say I did the dancing. It was my female Voodoo priestess/mechanic. ;)
  16. Nembo1777
    Nov 4, 2006
    11,700
    opposite lock
    Marc Sonnery
    Grease monkeys like Bob are a strange species:D:eek:;). They do have bizarre full moon pagan rituals:p.
  17. Cepat
    Cepat Formula Junior
    265
    Florida, USA
    Dean
    This thread has become even more enteraining.
    Heres a boring question: How big a PITA is it to replace the clutch master cylinder? I though the slave was bad because the master had been rebuilt in the past. So I replaced the slave but still only can get a firm pedal by pumping it. I dont see any brake fluid anywhere under the car or in the drivers footwell. I think the master has a blown seal or something interal. I'm thinking its a couple hours with my head painfully in the footwell but any advise is well appreciated!
  18. staatsof
    96,349
    Fuggetaboutitland
    Bob
    Never had to ... but I can only imagine how difficult that will be ... but not as bad as doing it has been so far in my Espada.
    The Espada's packaging for brake and clutch hydraulics is even lower and tighter than the Bora is and given that its a far shoddier built car than the Bora you end up having to re-engineer quite a few things. You begin by removing the wiper blades and arms, then the wiper motor on the LH side of the car, followed by the cable drive for the wiper in front of the driver. I gets a whole lot worse after that. :) so have fun.
    Requires at least two bonfires ...
    Just remember that it's actually brake fluid.
    So here's an interesting if insane while you at it upgrade idea ... Khamsin style clutch circuit! :eek:
    Clearly a 3 bonfire project and lots of naked Voodoo priestess's
    Nembo1777 and Cepat like this.
  19. Cepat
    265
    Florida, USA
    Dean
    There’s two nuts holding the master in place on the sled it goes back and forth on. The bottom nut was quite tight. I needed a half inch drive ratchet with a 13mm socket. The upper nut….well that may be my Waterloo. I cannot get a socket or box end wrench on it due to the high pressure banjo fitting causing interference. I can get a tiny 13mm open end wrench on it but I just cannot get enough leverage with that to break the nut loose. I have a longer wrench but again interference is an issue with all the other stuff up there. Trying to remove the banjo fitting looks challenging as well for all the same reasons. Anyone have any bright ideas? Has anyone here replaced a clutch master cylinder ? I see this as an engineering or design fail. But for sure people do replace these. Appreciate any advice.
  20. Cepat
    265
    Florida, USA
    Dean
    By Neptune’s Trident!!!
    Two hours to get this out
    I was able to get the banjo fitting off with a ratcheting box end 17mm wrench. 2-3 clicks at a time due to interference. Then I could finally get a 13mm box end on the mounting nut and break it loose. Hopefully mounting the replacement will suck a bit less.
  21. thecarnut
    thecarnut F1 Rookie
    3,271
    Atlanta
    The Car Nut
    I do not know if this can be done on a Bora but on Ghiblis (which the clutch master is also a pain to remove) I replace the seals without removing the clutch master cylinder.
    From inside the car, disconnect the rod that goes between the pedal and the cylinder. Remove the rubber boot and the retaining circlip for the rod. Work out the internal plunger and seals. Once the internals have been removed, feel inside the cylinder for wear grooves. Use a 400 grit sandpaper to polish the inside of the cylinder. Put it all back together.
    Ivan
    Cepat likes this.
  22. Cepat
    265
    Florida, USA
    Dean
    well I’ve gotten it out and I have ordered a new one. Not interested in rebuilding the old one.
  23. eogorman
    eogorman Formula Junior
    May 10, 2005
    339
    Buhl, ID
    Eugene O'Gorman
    The clutch is very difficult to bleed and get all the air out. I have only been successful by reverse bleeding. ie put pressure on the slave cylinder
    Cepat likes this.
  24. Cepat
    265
    Florida, USA
    Dean
    Sounds like fun.
  25. staatsof
    96,349
    Fuggetaboutitland
    Bob
    How many bonfires and Voodoo priestess's? ;)
