News
The F50 Thread
Discussion in '288GTO/F40/F50/Enzo/LaFerrari' started by amenasce, Dec 28, 2010.
  1. Rossocorsa1
    Rossocorsa1 F1 Rookie
    May 14, 2017
    3,761
  2. VetroresinaNL
    VetroresinaNL Formula 3
    1,618
    The Netherlands
    Vetroresina
    That I do not know.
  3. joe sackey
    joe sackey Four Time F1 World Champ
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
  4. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
  5. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
    mikesufka and Rossocorsa1 like this.
  6. VetroresinaNL
    1,618
    The Netherlands
    Vetroresina
    My error, being in a hurry is never ok :(.
  7. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,333
    London
    Mark
    Hi, can anyone help with some pictures......
    In the big red circus box that holds the 2 roll hoops and the removable rear panel..... How are the 2 roll hoops secured?
    I see in the box there is a metal bar running along the side (with what looks like threaded holes), down at the level where the hoops sit on the floor of the box - are they secured to that, and if so by what method?
    any photos or guidance greatly appreciated
    thanks
    Mark
  8. Marcel Massini
    Marcel Massini F1 World Champ
    Honorary
    Mar 2, 2005
    13,202
    joe sackey likes this.
  9. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
    There should be hardware that secures the items as guided by the owner's manual IIRC.
  10. thepinkumbrella
    thepinkumbrella F1 Veteran
    Feb 26, 2006
    5,669
    United Kingdom
    Paul Harris
    Where is it nowadays?
    Paul
  11. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,333
    London
    Mark
    Hi Joe, I can't find anything in the manual relation to the hoops in the circus box.
    If anyone gets a chance to post a photo it would be great.
    thanks
    mark
  12. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,333
    London
    Mark
    I think it maybe something as simple as the bolt, washer and spring washer in the picture (part 46,47 & 48) that screws through the roll hoop into the metal bar on the inside of the circus box, but just want to make sure I am making the correct assumption.
  13. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,333
    London
    Mark
    Problem solved I have found the answer, the roll hoops are secured to the metal bar in the circus box, with a metal plate, insulation gasket to avoid scratching and handled turn bolt.
    Picture attached for future reference.
    Cheers Mark Image Unavailable, Please Login
  14. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
    Learn something new every day, thanks for sharing Mark.
  15. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
  16. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
    FWIW that's 104795 above.
  17. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
  18. Marcel Massini
    Honorary
    Mar 2, 2005
    13,202
    Build start #15 December 1995.
    Completed 19 April 1996.
    Assembly #22157.
    Engine #42445.
    Gearbox #229.
    Body #52.
    Build#121/349.
    Marcel Massini
  19. Marcel Massini
    Honorary
    Mar 2, 2005
    13,202
  20. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,333
    London
    Mark
    the coolest feature is missing from your picture....the little removable torch (totally unique to the F50) that sits in the centre console, it lights up when the doors are opened to act as a courtesy light - given there is not one in the removable roof panel.
  21. 275GTB
    275GTB Formula 3
    Jan 12, 2010
    1,333
    London
    Mark
    Is the above a USA spec car? the seat belt configuration is different from euro spec cars - that car has the seat belt recoil mechanism housed in the middle, between the seats. On a euro spec car the seat belts are housed individually to the left and right of the seat, effectively close to the door shut.
    Thus allowing for the canopy bag to sit flat on the small shelf, nice and neat behind the seats. In the euro spec car, it sits much lower and does not impede your vision out of the rear window.
    In the picture above, the straps are clearly there for the canopy bag, but the seat belt mechanism is right in the middle of where the bag should be, so where does it go? Does it rest on top of the seat belt box, ie balanced in the middle, sitting a lot higher in the US spec car with a space underneath the right and left side? does it actually impede the view out of the rear window when fitted?
  22. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
    Yes, but for me the coolest features on the interior of an F50 are the gear shift lever and the 3rd pedal.
  23. joe sackey
    Sponsor
    May 23, 2006
    48,571
    Southern California
    Joe Sackey
    Yes that's a USA car, slightly different configuration of course.
    I'm not sure if the tonneau will impede rear vision, in fact I've never seen it used or in the car in the USA.
