the love/hate seesaw | FerrariChat
Discussion in '348/355' started by taggart1974, Dec 13, 2010.
  1. taggart1974
    taggart1974 Rookie
    Apr 16, 2010
    13
    ahhhhh!!! so i'm mid project, (1990 348ts), 5 months of no driving so having installed the new black leather/alcantara with red stitchin panels and dash i decided to slap an old seat in (i'm still waiting for the recovered 355 ones to be done) and take her for a blast to blow off the cobwebs. (don't worry, all fluids also replaced) connected the new battery, started her up and reset the ecu, all seemed good so into 1st and off i went, made it 3 feet on to the highway and she died (much to the bemusement of the other motorists!!) currently abandoned awaiting daylight for further inspection. i knew 20 year old italian women are supposed to be fiery and unpredictable but this is too much!! large beer currently in hand.
  2. Saint Bastage
    Saint Bastage F1 Rookie
    Jun 1, 2007
    2,548
    Connecticut
    Lane
    #2 Saint Bastage, Dec 13, 2010
    Standing on the side of the road in the dark next to a broken Ferrari drinking a large beer....Dude, I'm gonna need a photo of that. I'm sure all the other motorists are not bemused but rather suspicious. I'd expect a visit from some official looking people soon. Get out some dark sunglasses now. That way your ready for there bright lights and it will surely complete the look.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Does the engine still crank over, but no start? This will hopefully turn out to be something minor, but if the engine sounds like it's spinning over significantly faster than usual, then you've lost the timing belt and you're in trouble.
    Not out of gas, for sure?
    Alarm/immobilizer system kicked in?
  4. taggart1974
    taggart1974 Rookie
    Apr 16, 2010
    13
    its electrical for sure, just strange how she was running fine then suddenly died?! but a bit above my average skill level, engineer where i work will have a look tomorrow. did as many electrical connections as i could see with marine electrical grease last week so i'm lost.new battery is ok so can't be that. all i wanted was 30 mins of driving pleasure after 5 months of staring at her just sitting there, was it too much to ask, luckily i'm very patient and have a good sense of humour. results to follow.maybe they should get the italians to design the cars and the germans to build them, ha ha...
  5. Rob'Z
    Rob'Z Formula 3
    Mar 29, 2008
    1,024
    Tucson,AZ
    Robert
    They did, Gallardo.
    Sorry to hear about your troubles, hope everything works out.
  6. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Most of the time when I see a vehicle that shuts off all together while running, it's because one of the two main battery cables has come loose. (I wrench on motorcycles for a living)
    Much of the time, the thing that breaks is the last thing you touched. Both of these things point at the main battery cables. Could be something else, but that's where I'd start.
    Good luck. Hope you get back on the "love" side of the seesaw soon.
  7. eyboro
    eyboro Formula Junior
    988
    Chicago
    Eitan
    Check your alternator.
  8. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    +1: An easy thing to check is if your car has battery cable quick-disconnects or "bullet connectors" under the air filter box. A lot of 348s have these, while some don't. And some 348s have had these cables replaced with solid cables to eliminate these connectors. Best of luck!
  9. taggart1974
    taggart1974 Rookie
    Apr 16, 2010
    13
    put the multimeter on the battery this morning and it is dead (11.3 volts)!!, there was no warning light which is strange but it was obviously not being charged. will get her back home and investigate further, i suspect the alternator. i believe there is an updated unit on later models, anyone have the part number. think i will take the oppertunity to replace the leads to and do away with the under airbox connector. thanks again for all the help guys.
  10. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Wrong direction with the grease!
    I would bet Paul and Rick are spot on.
  11. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    The "updated unit" for replacing the Delco alternator in a 1990 348 costs several thousand dollars. It's a Nippondenso alternator and a kit that includes a new mounting bracket, a new wiring harness, a new belt, and a new heat shield (I think). There is no reason that a properly repaired Delco alternator should not give satisfactory service for many years, and the parts to rebuild the Delco alternator are regularly stocked at any alt shop.
    But don't condemn the alternator until you're sure the wiring is OK and the belt is properly tensioned.
  12. Kaivball
    Kaivball Three Time F1 World Champ
    Jan 11, 2007
    35,997
    Kalifornia
    Hate to revive an old thread but I just rebuilt my alternator on my 348 and it's missing the infamous heat shield.
    Any stooge ways of addressing this or any sources where I can buy this?
    Thanks,
    Kai
  13. plugzit
    plugzit F1 Veteran
    7,674
    Redondo Beach, CA
    Bruce Bogart
    Heat shield? It's supposed to have a heat shield? Nobody told me! Maybe I need one too.
  14. Ricambi America
    Sponsor Owner
    This shield?
    http://www.ricambiamerica.com/product_info.php?products_id=203106
    I know I have at least one in stock. It is an odd shape --- and I think it is more designed to funnel cold air into the alternator than actually be a heat shield.
    Or, are you referring to the slatted undertray piece that also covers the A/C (runs laterally at the front of the engine) ?
  15. MaterMech
    MaterMech Formula Junior
    Feb 26, 2007
    476
    Los Gatos CA
    Mark Johnson
    Are you talking about the heat shield that goes above the Delco unit? The ND alternators did not have that.
  16. Kaivball
    Jan 11, 2007
    35,997
    Kalifornia
    Yes. The ND doesn't need it?
    Kai
