Things to be aware of....known issues F12 | Page 3 | FerrariChat
Discussion in 'F12/812' started by supersport888, Aug 26, 2021.
  1. Eilig
    Eilig F1 Rookie
    4,305
    Tänzelndes Pferd
    6 yrs ago I bought a brand new ENTIRE GEARBOX for F12 for $20k.
    NYC Fred and day355 like this.
  2. synergy
    synergy Formula Junior
    Aug 5, 2007
    524
    Austin Texas
    Chris
    Wow, that seems like a great deal or I am getting royally screwed! The dealer told me today that the parts are $10K (for an SAP kit) and the labor is $10K which is how it got to $20K. Pretty outrageous!
    So I decided that I am going to take the car to a local master Ferrari tech tomorrow who works at an independent shop for a second opinion. I find it highly unusual that after my major service a few weeks ago where they replaced the DCT fluid and inspected it that now all of a sudden (with no miles other than driving home) I have a random leak. My hope is that they over filled it or spilled oil when filling the DCT. I will know more in a few days and I will report back!
  3. Solid State
    Solid State F1 World Champ
    10,793
    Maximus Decimus Meridius
    Leaks are not covered under the extended warranty which retails for about $8k/year.
  4. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,382
    The Netherlands
    I’m not sure that understand why they need the SAP kit. If they’re using the SAP kit then it’s more than just a gearbox reseal.
    More info here;
    https://www.ferrarichat.com/forum/threads/dct-repair.658520/
    While your gearbox is out and split, you might also want to consider having the sensors replaced.
    NYC Fred likes this.
  5. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,860
    Bulgaria
    If they overfilled the DCT it will throw oil from the special revision hole, made for that, not from the area, that 2 parts join.
    If you need a SAP kit, I have one for sale for much less than Ferrari wants, don't worry.
    synergy likes this.
  6. WhySock
    WhySock Rookie
    May 25, 2024
    20
    Houston, TX
    MK
    Assuming they are at $250/hr for labor they are quoting 40 hours to pull a transmission, reseal it, and put it back in. Surely it can't take that long. Sounds like they are putting in $5K in parts, and doing 20 hours of labor, and then decided to throw a 2x multiple on it just for extra profit. Definitely shop around. Most good indy shops will warranty their stuff for 6 months to a year. Likely about what the Ferrari dealer is going to offer as far as their warranty.
  7. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,382
    The Netherlands
    No, they aren’t taking the piss. The SAP kit does cost $10k. And as for the labour, US rates are crazy high - up to $300/hour. So 33 hours to drop, split and rebuild the gearbox is about the norm.
    I’ve seen the DCT workshop manual and it’s a very involved process.
    I think the more pertinent question is why they’re proposing to replace the SAP for a simple leak. It possible that it’s a precaution but in that case, they should make it clear that it’s discretionary.
    WhySock and synergy like this.
  8. synergy
    Aug 5, 2007
    524
    Austin Texas
    Chris
    The dealer claims that the only way to get the new gasket is to order the SAP kit. I find that to be ridiculous since the car has no issues with shifting and no codes. I took it to an independent Ferrari repair shop today (Moorespeed, Austin TX) and the owner thinks it was overfilled. They are going to clean up the oil and get the engine hot to see what the situation is. Let's hope for a positive result!
    NYC Fred and ANOpax like this.
  9. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    160
    I haven't been able to follow the subject very well, but as far as I understand, the authorized Ferrari service has stated an exorbitant labor fee. If your vehicle's warranty has expired, it would be much more reasonable for you to have this operation done by a trusted and experienced Ferrari private service/mechanic. Of course, I don't know the current situation and the choice is yours.
  10. ANOpax
    ANOpax Formula 3
    Jul 1, 2015
    1,382
    The Netherlands
    This seems odd as the case joint where the SAP resides is sealed with caulk, not a gasket.
    There are also third party gaskets available for other parts of the gearbox but I’m pretty sure that the SAP kit doesn’t contain gaskets for the gearbox case - only for the internals such as the solenoids and these too are also available from third parties such as Hollywood Mechanic - take a look on his website for the different gasket and seal kits that he sells.
    It’s possible that they’re claiming the leak is internal and the oil you’re seeing is coming from weep holes but the photos you showed looked like it was a failure of the case seal.
  11. synergy
    Aug 5, 2007
    524
    Austin Texas
    Chris
    Quick update: the car is still at the third party Ferrari mechanic and he said they cleaned everything up, drove the car at operating temperature multiple times and allowed the car to sit for 4 days. The gearbox area is dry as a bone, no leaks!! The mechanic said there are no warnings or any signs of DCT issues whatsoever. He is going to drive it a few more times but so far so good. He mentioned that the gearbox oil was a bit low so they filled it to spec. So now I am totally confused on what could have happened. Did the Ferrari dealer spill oil when trying to fill and after it sat after the service the oil began to drip out of the pan?
  12. Solid State
    10,793
    Puzzling.
    synergy likes this.
  13. DZ-96
    DZ-96 Formula 3
    1,929
    South Germany
    Daniel
    Drive the car normally and let it check (or check yourself) after a few weeks.
    A minimal leak will not cause a gearbox damage, so if there is a leak, you can plan a repair or just drive the car until it gets worse.
    Daniel
    NYC Fred and synergy like this.
  14. Fuzzmeist
    Fuzzmeist Rookie
    Aug 3, 2014
    19
    New York
    Michael
    I know this post is already almost four years old but I am hoping someone can elaborate on the "creaking from torque bolts in the rear driveshaft". I noticed that my F12 makes a clicking noise from under the rear axle when I drive forward from a standstill, and sometimes as I come to a full stop. Is this the aforementioned torque bolts, and is there a way to fix this? Thanks.
  15. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,860
    Bulgaria
    No. Even if you tighten the bolts as tight as you can, they would still eventually click. My dealer told me this is absolutely the same on every front engined Ferrari from that era.
  16. AhmetUz
    AhmetUz Karting
    Aug 11, 2022
    160
    Does that noise occur every time, or is it intermittent? As far as I know, this is a common occurrence in front-engined Ferraris (F12, FF), and I think it's normal. If you still think it's not normal, you can contact a Ferrari technical service or an official dealer for further evaluation.
  17. jblaw
    jblaw Karting
    May 20, 2016
    119
    You can just have them tightened, it’s the hub not the lugs. Takes just a few minutes per side. The option is to repack them with the glue they used (basically locktite), but that is an undertaking.
  18. rumen1
    rumen1 Formula 3
    Jun 23, 2012
    1,860
    Bulgaria
    NOTHING will help. I even changed my drive shafts and it fixed it for about a month.
  19. colonels
    colonels Formula Junior
    Aug 5, 2011
    887
    so i'm the original poster here is detail of what tech did:
    confirm click noise especially when starting from a turning position
    removed left axle nut, marked position, machined off the lock section. installed old nut and torqued it and it was past previous marked position indicating it was not fully tight. checked splines noted they were in great condition. installed new nut and torqued to proper torque. rinse repeat on right axle.
    it did fix the clicking noise however it may be back i haven't driven it in a while been on vacation and got a F430 spider for summer drives.
  20. dustywusty
    dustywusty Formula Junior
    386
    Florida
    Dealer charged me a few thousand (think it was close to 7) to fully replace driveshafts and hubs to fix the clicking issue on the older F12. It did it again the day after. It was also not just from turning, it was from any motion change forward or backward.
  21. WhySock
    WhySock Rookie
    May 25, 2024
    20
    Houston, TX
    MK
    I hope the dealer refunded your $7K.
    rumen1 likes this.
  22. dustywusty
    386
    Florida
    Funny man!
    WhySock likes this.
