Tie rod hitting top of front sway bar link? | Page 2 | FerrariChat
Discussion in '308/328' started by LOBO1, Feb 7, 2019.
  1. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    That's the spacing we're expecting, just can't figure out how to get there without modify parts.
  2. absostone
    absostone F1 World Champ
    10,218
    have you set the car on the wheels yet? on terra ferma?
  3. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    Our's don't have much slope at all. Both look fairly straight, parallel to ground.
  4. Steve Magnusson
    26,944
    Based on thorn's photo in post #17, it doesn't look like there is any angle up or down in those parts (and, if those parts can be swapped, I'll need to time travel back to the past and slap the design engineers around some ;)). Any chance you can take a photo like thorn's in that same as-loaded condition?
    absostone likes this.
  5. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    We did, first photo with tape measure is of the car on the ground with wheels.
    It's now up in the air again, as we troubleshoot the sway bar/ tie rod issue.
  6. absostone
    10,218
    hmmm well we're all here with you. we'll get her fixed
  7. absostone
    10,218
    strange thing is that in your photos pre rebuild the tierod was hitting the link when the sus was suspended
  8. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    This car was in terrible shape when we got it and it had a blown head gasget
    so we have never driven it.
  9. absostone
    10,218
    I remember seeing a thread a few years back where someone had the same issue
  10. absostone
    10,218
    Well the good news is that it’s looking great now. Once this issue is resolved. You’ll enjoy the car
  11. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,299
    Black Forest Germany
    Martin N.
    I'm not near my car at the moment, but took a few quick pics last night from below the lift (four post lift, car on its wheels, suspension loaded)
    These show another angle and how far away both parts are from each other.
    Haven't looked with the wheels off from the ground. But due to the radius movement of the sway bar parts will come closer.
    Best from Germany
    Martin
  12. VA_Alfa
    VA_Alfa Karting
    Jun 20, 2009
    59
    Waynesboro, VA
    Alex Sullivan
    It looks to me like the lower A-arms need to swap sides , and of course flip over. Martins photo shows the outer end of the lower A-arm with a slight upward bend. The OP’s has a downward bend.
  13. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,281
    CT
    John Kreskovsky
    Correct. Beat me to it.
  14. absostone
    10,218
  15. absostone
    10,218
  16. absostone
    10,218
    also are the A arm bushing spacers installed in the correct location? and the upper ball joint connection looks like its at a extreme angle in some of the pics
  17. Hinecker
    Hinecker Formula Junior
    Mar 14, 2011
    379
    Hi all,
    Just looked at my 328 and the lower A-arms look like Martin's, plenty of clearance between the tie rod and the sway bar link. I agree on that the lower A-arms may have been swapped... left to right(and upside down of course).
    John.
  18. derekw
    derekw Formula 3
    Sep 7, 2010
    1,521
    London, UK
    Derek W
    Not near my car but this pic from google shows the a-arm end turns up, not down.
  19. absostone
    10,218
  20. absostone
    10,218
    btw is this a 328 or 308? or what
  21. johnk...
    Jun 11, 2004
    11,281
    CT
    John Kreskovsky
  22. absostone
    10,218
    yea I saw that, everything on these old Ferraris are wonky
  23. thorn
    thorn F1 Rookie
    Aug 7, 2012
    3,324
    Tallahassee, FL
    If the A-arm is flipped and put on the other side of the car, then the "hump" on the arm near the frame mounts would be upside down, and become a "tub". So I don't think the arm on the OP's car (or mine) is on the wrong side. Of course if I'm wrong, please say so... as I'll need to get mine back on the rack.
    Re: my sway bar links.... JohnK, thanks for pointing that out. It's always had that weird off-angle, but I assumed "that's how it is". However, I just studied both sides of the car. Looks like the swaybar wasn't centered correctly when it was installed by the PO, as the left link is canted towards the center of the car. So time for me to correct that issue. (Seriously, thanks. I hadn't noticed that forest, for the trees.)
  24. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    The more I look at all the pics the more I think that the tie rod end mount (#3 and #4) must have been swapped. The illustration shows them angled. On closer examination of the illustration it shows one angled up and the other angled down. Hmmm...
    Lester
  25. Martin308GTB
    Jan 22, 2003
    4,299
    Martin N.
    That's a picture angle issue. There's no angle at all. The wishbone is straight. Will take another picture later this evening.
    Best from Germany
    Martin
    johnk... likes this.
