Tie rod hitting top of front sway bar link? | Page 4 | FerrariChat
Discussion in '308/328' started by LOBO1, Feb 7, 2019.
  1. absostone
    absostone F1 World Champ
    10,215
    this could be part of the reason to me that I asked about the correct bushing spacers , and why to me the arms look out of line. Ie caster
  2. absostone
    10,215
    I believe they replace the "dogbones" with Heim joints when thicker roll bars are used when tracking ,to not preload the suspension
  3. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    Not sure... I'll have to check the caster Monday, but in the picture it looks
    like positive caster..and that would raise the tie rod away from the
    dog bone.
  4. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    The pictures of the a arms on a blanket were after we welded the
    bushings in... Do you see anything that looks wrong?
  5. absostone
    10,215
    I cant realy see the spacer rings in the photo so I don't know. just trying to cover all bases
  6. absostone
    10,215
    ok...…. from my notes. the thick spacers for the bushings go on the straight side of the upper arm and all the rest of the spacers are the same size
  7. absostone
    10,215
    meaning thick spacer on upper arm toward the rear of the car
  8. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    I could email that picture that you can zoom in on if you like... it's around 1mb.
  9. absostone
    10,215
    I could pm U my email but you just gotta look to see if the bushing spacers are in the correct location. And like I said I don't know what model you have, it looks like a early 308, so it should be similar to the GT4
  10. absostone
    10,215
    sent, check your conversation inbox. top right of screen
  11. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
  12. absostone
    10,215
    any pics of the uppers off the car before stripping down?
  13. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
  14. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
  15. absostone
    10,215
    ok according to MY notes for my SUS. your pics look correct. Thick spacer on straight side
  16. absostone
    10,215
    ok so now back to my early early question, in your newest pics prior to removal of components, the pics show the radiused dip of the upper ball joints pointing outward, but your restored pics show a straight edge facing outward. might as well check
  17. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    That's good... one more thing to rule out.
    Thnaks
  18. absostone
    10,215
    when I zoom in on your pics they get blurry, so lets just check
  19. absostone
    10,215
    best I can do is try and relive the details I remember when I did my fronts last March. It may lead to nowhere but we gotta check. geometry is geometry, it works how it wants to, not how our minds want it to
  20. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    The old and new ball joints look pretty different... What are you referring to that makes
    it look reversed?
  21. Jdubbya
    Jdubbya The $10 Trillion Man
    43,780
    Hell's waiting room
    This may sound like a stupid question but it doesn't look like you've solved it yet so here goes......is the swaybar centered between the two sides? There's really nothing to center is there, it can slide back and forth in the rubber mounts. If you have a lot of clearance on the other side sliding the bar a bit to that side would move it inboard and clear of the tire rod nut.
  22. absostone
    10,215
    that's also a possibility. but if you look at the scratches on the top of the drop links, it looks like a long way to go
  23. absostone
    10,215
    I went to to dig out my original old ball joints, and by eye it looks like the bolt portion tilts more inboard when the dipped portion faces outward, but im a couple of coors in. but something keeps bugging me, im no pro mechanic but its something to compare to. can anyone else check the orientation of theyre upper joints?
  24. absostone
    10,215
    the curved dip facing outward in your pics before you stripped everything off the car
    [​IMG]is this the way you put the new ones on? with the dipped portion outward? I cant see from your pics, its blurry when I zoom in, but they look like the opposite side is facing outward on your restored pics
  25. absostone
    10,215
    I keep calling it bolt but its the threaded shaft portion is what I mean.
