Tie rod hitting top of front sway bar link? | Page 5 | FerrariChat
Discussion in '308/328' started by LOBO1, Feb 7, 2019.
  1. absostone
    absostone F1 World Champ
    10,215
    hope im not confusing the situ but I feel we need to go through the entire parts list
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  3. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    Rears are approx 96 mm centers
    front and rear are definitely different lengths
    I think from memory fronts are shorter but can someone please confirm
    Crowndog might have the answer here
  4. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,297
    Black Forest Germany
    Martin N.
    Unfortunately not. I just measured a spare rear. These are 70mm centers, not 96. The front ones are significantly longer.
    Best from Germany
  5. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    Quoting my own post for an addition/correction:
    You can't even swap sides by omitting the woodruff key. The direction of the cone for the track rod end also matters.
    Best Regards
    Martin
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    #106 Crowndog, Feb 9, 2019
    Hello Martin,
    It may be that since there appear to be two different size doggie bones perhaps he has the longer on the front?
    Which for his car is inappropriate and should have the shorter. Remember the rule that every car is different.
    Or versa vica
  7. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    #107 Martin308GTB, Feb 9, 2019
    Hi Robert,
    from GT4 1973 till 308QV 1985 parts numbers are the same for the short rear ones and long front ones. Even the 328 used the same rears.
    I think it's easy to check for the correct length of the dogbones. With the car on the wheels the stabilizer should be angled nearly horizontally.
    Robert, these are cars, not glasses :)
    Best from Germany
    Martin
    Crowndog likes this.
  8. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Not convinced. :)
    My eyes are not what they used to be.
    Anyway just my $.02 since I looks like the weird angle suggests to me the bone is not right.
  9. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    Which picture do you refer to?
  10. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  11. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    Cannot see/open the attachment.
  12. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    794
    Treasure Coast Florida
    MATT
    It looks to me like your tie rod ends are incorrect the threaded portion has extra thread + the nut is a very high-profile Cortes pin style. Look at Thorn's photo on page 1... his has a very short threaded portion with a very short lock nut.
  13. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    Like shown on my detail pic in my post #60 on page three, the tie rod end nut is far away enough to not collide with the dogbone.
    If there's slight collision, it's in the extreme position of full droop and steering end position.
    But not the nut collides, but the steering arm itself.
    Best from Germany
    Martin
  14. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Post #46
  15. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    Hi Robert,
    this is not the OP's situation. It's 'thorn's picture from post #17. And this weird angle is just caused by the stabilizer not centered correctly, what 'thorn' meanwhile easily corrected.
    Best
    Martin
  16. LOBO1
    LOBO1 Rookie
    Dec 26, 2017
    41
    BOB LOEB
    We have several suggestions of things to check on Monday (thanks for all the help) but I don't believe the issue is with incorrect sway bar links (dog bones). The front links and the sway bar were the first things we inspected (before posting for help), when we noticed the problem.
    The front sway bar and link sizes, matched exactly with a properly clearing suspension, on comparison.
  17. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    Yep, check that
    Factory would not have got that so wrong
  18. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    Again my bet is Crowndog is correct
  19. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    #119 Martin308GTB, Feb 10, 2019
    This thread is beginning to get funny :)
    Did you read all posts one after another?
    We should go back to the thread topic and wait for the OP's results of further investigation and not discuss 'thorn's' misaligned stabilizer, which he meanwhile corrected.
    Best
    Martin
  20. daytonaman
    May 1, 2007
    986
    Australia
    howard pigdon
    Martin yes I have looked at all the posts. Appologies if I am missing something here.
    All I know is front and rear dogbones are different length and not interchangeable. Rear will cause this problem if accidentaly fitted to front
  21. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    How that? The rear ones are approx. 25mm shorter than the front ones. But in fact, it would bugger up the whole stabilizer geometry. But no way cause collision between dogbone and steering arm.
    Best
    Martin
  22. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Now I’ll throw another bone (haha)
    Could the dogbones be from another car or wrong replacements? I still think they should be measured and compared to knowns.
  23. Martin308GTB
    Jan 22, 2003
    4,297
    Martin N.
    Hi Robert,
  24. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Oh darn. But good news.
  25. thorn
    thorn F1 Rookie
    Aug 7, 2012
    3,324
    Tallahassee, FL
    Right, that's my car - not the OP's. I was hoping that it would help in showing how the angles and parts are arranged. Unfortunately I think it clouded the original issue a bit, as a) my link was "off angle" (since corrected) and b) either way, I wasn't having problems with the tie rod hitting the link.
    I'd post a pic of my corrected parts, but I think we've got enough "good" examples posted already. ;)
    Martin308GTB and absostone like this.
