Tire Pressure question | FerrariChat
Discussion in 'Technical Q&A' started by Ron328, May 5, 2004.
  1. Ron328
    Ron328 F1 Rookie
    2,626
    Willamette Valley, Oregon
    Ron
    My 328 had Goodyear tires (OEM) that were replaced with Pirelli's of the SAME
    dimensions. My question is, should the tire pressure be the same or is there
    some variation depending on the tire manufacturer? Thnx.
  2. Schatten
    Schatten F1 World Champ
    Apr 3, 2001
    11,238
    Austin, TX
    Randy
    Different tires prefer different pressures. Same size doesn't necessarily matter. Typically, you want to get the pressures up in the front where the car turns-in as precise as it can, then tune the pressures in the rear for any slight oversteer/understeer characteristics.
    Which Pirellis did you opt for?
  3. Ron328
    Ron328 F1 Rookie
    2,626
    Ron
    Randy,
    Thanks. I opted for the PZero Nero's. 205/55 front and 225/50 rear.
    Ron
  4. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Ron,
    I have, front and rear 2.6 bar checked when cold, although tyre pressures are a personal thing and these figures can vary slightly.
    MW
  5. Ron328
    Ron328 F1 Rookie
    2,626
    Ron
    Thanks Malcolm. I talked to the manager (w/c I should have done before)
    of the shop that installed the tires...he said to follow Ferrari's recommended
    pressure. 2.6 bar should be pretty close to the recommended rear tire pressure. The front is lower, somewhere close to 2.2 (about 32 psi). Thanks again.
