News
Tming light recommendations
Discussion in 'Technical Q&A' started by Bryan, Jun 13, 2004.
  1. Bryan
    Bryan Formula 3
    My timing light (30 years old!!!) bit the dust.
    How much has the technology changed and what are people using now for timing lights, as far as brands, that have other 'bells and whistles' besides the light itself?
    I have seen a couple that offer built in advance settings, but I'm not sure how this would work with an older car with mechanical advance.
  3. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,699
    Brighton (UK)
    Dan
    I've just bought one with an adjustable advance setting. Believe me it's worth the extra. What it does is enable you to dial in x number of degrees of advance. This is really usefull if you have only a TDC mark on your pulley/flywheel/whatever.
    Also, if you're using it for general fault finding, you can use the adjuster to move the timing mark to the visible arc of the pulley/flywheel/etc when you're checking other cyls.
