Tough new visa requirements for travel to USA---- | FerrariChat
Discussion in 'Other Off Topic Forum' started by tonyh, Jan 8, 2004.
  1. To remove this ad click here.
  2. tvrfreak
    tvrfreak F1 Rookie
    3,879
    Arkansas
    F K
    All of these measures match people with paperwork, to a greater degree of confidence. ie. the passport says you are so and so, and the person inspecting the passport, if they inspect it thoroughly enough, can be 99.9% confident that the bearer is indeed so and so.
    Problem is, it is the mindset and intention of the bearer that need to be clearly identified. That, and discovering any concealed weapons or explosives. A passport can be easily obtained by presenting an easily obtained birth certificate. Further, it merely specifies a name, date and place of birth, and a partial record of prior travels, if it has been used before and if the countries entered and exited with it stamp the entry and exit.
    If the identification document ie. passport, and travel endorsement ie. visa is issued after extensive profiling and investigation, then it presents an additional hurdle for a would-be terrorist. All this presumes that the person bearing it is the person who was granted the documentation and travel permit.
    Otherwise, it is a feel-good but meaningless gesture. Like removing nail-clippers from passengers while allowing unchecked workers and vehicles to enter the tarmac area. Better than nothing, in some cases.
  3. teak360
    teak360 F1 Veteran
    Nov 3, 2003
    9,928
    Boulder, CO
    Scott
    Exactly
  4. writerguy
    writerguy F1 Veteran
    Sep 30, 2003
    6,786
    NewRotic
    Otto
    BOY did you say a mouthfull there.
    I always get a kick out of any politico's abilities to misdirect "LOOK nothing up my sleeve.... " Just distracts from Haliburton and other scandals that should be tops
  5. Chenrezi
    Chenrezi Karting
    Feb 10, 2003
    161
    Europe
    Michael
    Well, I'm not from the US, but I think this afects everybody who wants to travel there.
    I can totaly relate to the increase in security for the US, I mean, it is THE country most likely to be hit by a terrorist attack of some kind, so.... defend yourselves at will!
    I do think though, that some efforts are being misdirected and more should be done in other areas.
    Forgering a passport is, like somebody already said, not such a hard thing to do....
  6. To remove this ad click here.
