News
TPMO - Tire pressure and temp monitor
Discussion in '458 Italia/488/F8' started by abz, Aug 1, 2011.
  1. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Does anyone know exactly how this "electronic system" actually works? How is the pressure and temp continuously monitored? Is the system reliable and accurate? Curious, what is the cost?
  3. tuttavelocita
    tuttavelocita Formula 3
    Aug 26, 2007
    1,453
    Well it doesn't cost you anything if you are in the USA, since it is a federal mandated law that the NHTSA requires a tire monitoring devices installed on all new cars (since 2008 i believe).
    As far as how its done, there is a sensor attached to your valve stem that communicates wirelessly with your car that tells it the current pressure inside the tire and im assuming they have incorporated a temp sensor to do the same.
  4. gzachary
    gzachary Formula Junior
    I love using it in my 458. well worth it.
  5. fuse
    fuse Formula Junior
    Aug 11, 2004
    340
    It seems to be continuous. I put a a pump on it and watched it and it changes 1 lb at a time, although I can't tell how often it updates, since I am using a small portable pump...quite slow.
    I did notice that the 458 read 3 lbs lower than both of my tire pressure monitors. A 45 lbs max and a 60 lbs max. Not to say that my monitors are reading accurately.
  6. JazzyO
    JazzyO F1 World Champ
    Jan 14, 2007
    11,910
    The Netherlands
    Onno
    Cost in Europe is €945 excluding all taxes.
    Onno
  8. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Thanks everyone. So then it is a standard ferature installed on all 458s in the US. Look forward to checking it out.
  9. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    If it is attached to the valve stem, can this easily be removed and reconnected if a tire needs changed, for example?
  10. fireplace63
    fireplace63 Rookie
    Jun 18, 2011
    45
    Does that mean if you change the wheels, the system is useless? How does it work? the sensor is attached to the stock wheels? I was told if you plan to change to aftermarket wheels, no point opting for this system.
  11. tuttavelocita
    Aug 26, 2007
    1,453
    It is easily removed by anyone doing your tire change, also you can buy a new set of sensors to put on your new wheels if you plan on having multiple sets of wheels. In fact on most cars if you don't put sensors on your new wheels you will have a warning light on your car
  13. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Very nice to know this information. Thanks.
  14. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    It's not clear to me how tire temp is measured. Does anyone really know? A thermocouple in the tire stem wouldn't measure tire surface temp which I assume they are talking about. Who cares what the internal tire air temp is, what you want to know is tire surface temp which racers measure with a pyrometer.
  15. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Agree, it would be interesting to know the details of how this works. Perhaps there is a direct correlation between the inside air temp and the rubber temp.
  16. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    For those that have the TMPO, is it just as easy to add air to the tire whether you have this system or not?
  17. tuttavelocita
    Aug 26, 2007
    1,453
    The sensor is on the inside of the tire, your valve stem looks no different and acts no differently than any regular car tire valve stem.
