Transmission Control Unit - not communicating
Discussion in 'Technical Q&A' started by George Moore, Dec 6, 2017.
  1. George Moore
    George Moore Rookie
    Oct 31, 2017
    8
    George Moore
    Hi Guys,
    So my car is driving fine however I have hooked up my computer and get a lot of codes for my transmission, suspension etc ... seems not to be communicating with the ecu or transmission control unit. I have attached a screen shot of my codes. I bought this car secondhand a couple months ago and slowly fixing her up.
    As I said car runs fine ... I suspect I will need to replace the suspension so am going with the KW setup. Just worried about the other codes ... anyone had these before?
    Any help would be appreciated. Been a headache.
  2. Dave rocks
    Dave rocks F1 World Champ
    Sponsor Owner
    Nov 23, 2012
    11,489
    Orchard Park, NY
    Dave Lelonek
    George, what car? You may be better having some with a factory SD connect and have a look.
  3. George Moore
    George Moore Rookie
    Oct 31, 2017
    8
    George Moore
    Sorry bud completely forgot ...
    It’s a F430 2007-2008...
    I was just thinking of replacing the transmission control unit.
    Problem is the engine gets tuned by Project A on Saturday for the exhaust and headers...
  4. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    12,535
    The Cold North
    Howie Felterbum
    Be extremely careful with this. If the car is driving fine..then I would suggest you have a scan tool problem and not a car problem. Ferrari really likes to play with protocols which can produce false codes in none specific scan tools. Have the car scanned with a specific tool before spending any money on a tcu to confirm the faults and perameters.
    whatheheck likes this.
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    1,451
    Berkeley, CA
    Brian Brown
    As tbakowski has said, if the car drives fine and the transmission is shifting as it should, then there is nothing wrong with the transmission control unit. The fault is with your scanner, and it is not communicating with the transmission and differential ECU's.
    Have the car scanned with a known good Ferrari specific diagnostic tool (SD3, Leonardo) before doing anything else. You probably don't have to replace the suspension either. Diagnose it properly before making any changes.
  6. tazandjan
    tazandjan Two Time F1 World Champ
    27,674
    Albuquerque, NM
    I doubt that little OBD II scanner can talk to the suspension or transmission ECU (TCU). Take it to somebody with a real tool like an SD2 or Leonardo.
  7. Tired of seeing this ad? Upgrade now
  8. George Moore
    George Moore Rookie
    Oct 31, 2017
    8
    George Moore
    Ok thanks for the info guys.. I guess the non communication codes make sense. But how about the suspension failure code?
    Suspect the KW suspension upgrade would be a good option anyway. ;)
  9. taz355
    taz355 F1 Rookie
    Silver Subscribed Owner
    Feb 18, 2008
    3,209
    Indio Ca/ Alberta
    Grant
    Likely same problem. Scan tool not compatible
  10. Dave rocks
    Sponsor Owner
    Nov 23, 2012
    11,489
    Orchard Park, NY
    Dave Lelonek
    Terry - he has a 430. Needs and SD3 or SDX. SD2 doesn't cover 430's
  11. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    5,853
    It's things like this that make me continue to love manuals.......
  12. tbakowsky
    Sep 18, 2002
    12,535
    The Cold North
    Howie Felterbum
    Agree..simple, gets the job done with zero need for electronic garbage to make it work. However the autobox in the later cars is something to behold. They work amazingly well, until they don't. Then they rip your wallet straight outta your hands
    brian.s likes this.
  13. tazandjan
    27,674
    Albuquerque, NM
    Most problems with F1 are the result of lack of regular maintenance. Ferrari did not figure this out until the 599 came out when the first recommendation for regular fluid changes and bleeding came out.
  14. Tired of seeing this ad? Upgrade now
  15. Dave rocks
    Sponsor Owner
    Nov 23, 2012
    11,489
    Orchard Park, NY
    Dave Lelonek
    I'd also add that it's people working on the system that don't have the proper tools or knowledge. I'm going on 5 years with no fluid change and my F1 operates flawlessly. Now that I have an SD2 I will change the fluid this coming spring.
  16. taz355
    taz355 F1 Rookie
    Feb 18, 2008
    3,209
    Indio Ca/ Alberta
    Grant
    I am pretty sure you can still change the fluid, just takes longer
  17. vrsurgeon
    vrsurgeon F1 World Champ
    10,793
    Charleston, SC
    Curt
    Are you getting a warning light in the instrument cluster? Any at all?
    As before that's an OBD2 scanner. It will only give you Check Engine Light emission codes.
