News
Transmission Failure- Car does not start!
Discussion in 'Technical Q&A' started by mhjf2001, Aug 3, 2010.
  1. mhjf2001
    mhjf2001 Rookie
    Aug 2, 2010
    3
    Hi Everyone,
    I have a problem with my Ferrari 612. Some days back i switched off the engine and when i tried to start the car, I got "Transmission Failure" message and the car is not starting anymore.
    Please help me... Thanksss
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    10,919
    South East
    Jimmie
    If your car is under warranty call the dealer
  4. mhjf2001
    mhjf2001 Rookie
    Aug 2, 2010
    3
    actually i am travelling with my car and right now, there is no dealer in this country. so, i need to have it fixed by local mechanics!
  5. greyboxer
    Dec 8, 2004
    10,919
    South East
    Jimmie
    OK you have a reset battery off switch to try - see section 5 of the manual
    Also its worth checking when you get the failure light if you can push the reverse lever slightly forward - it may have loosened and this could (just) be a possible cause
  6. mhjf2001
    mhjf2001 Rookie
    Aug 2, 2010
    3
    I did what u said! but its still the same!
  8. maserati424
    maserati424 Rookie
    Apr 11, 2004
    29
    Berlin, Germany
    frank gablenz
    If you Open the door ,can you hear the F1 Pumpmotor?
    If not give it one with a hammer, not so hard be carefull, let ignition on,i helped me with a Maserati 4200CC
    best wishes Frank
  9. geeza
    geeza Rookie
    Jul 16, 2010
    4
    will be the clutch position sensor failed i expect they suffer with heat soak, there was a campaign to replace them under warranty.
