Transmission won't Shift at all F1 | FerrariChat
Discussion in '348/355' started by Boaf 32, Mar 21, 2017.
  1. Boaf 32
    Boaf 32 Formula Junior
    Aug 23, 2016
    390
    US
    Gents,
    More troubles for my 1999 355 F1 Spider:
    1. Came to a stop, put brake on but was still in first when opened door. Heard a unusual clunk.
    2. Car would not go into gear. Tried to shut off and re-start. Now here a cycle sound like a pump. Never hear that before.
    3. Might be an issue, the engine cover now indicates it is open, even though it is not. I just washed the car and wondering if that "open hood" indicator controls if the trans engages or not. Water damage to connector??
    Getting it towed tomorrow hopefully. I read somewhere that there is a way to re-set the trans when it gets stuck in neutral. Turning the key 10 times or something like that. Any thoughts there?
    a very Pissed off Boaf.
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes - that switch will force the F1 to go into N
    You could short the switch to test (bypass)
  3. Boaf 32
    Aug 23, 2016
    390
    US
    I disconnected it and closed the hood. Still hear that "pumping" sound. Going out to try the car again after it cools down.
    How else can I short out the switch? Thanks.
    Bob
    PS if it's easier, I can call you tomorrow. Let me know
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bob - disconnecting will likely result in open connects (hood open). You probably need closed contacts but I'm not in front of my PC to review the circuit. A jumper wire in the connector should close the contact.
  5. Qavion
    Qavion F1 World Champ
    14,269
    Ian Riddell
  6. Boaf 32
    Aug 23, 2016
    390
    US
    Thanks. I just went out and I heard the pump just keep cycling. I will try and find a jumper. I have zilch for electrical tool and supplies at my apartment. Would the pump cycling stop even with the hood open?
    I just get the feeling that the light will go on until the pump builds pressure, then confirms the hood is closed. I appreciate it.
    Bob
  7. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ian - the circuit is in the WSM.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    You start the car in N, the bonnet can be open in N with car running. The pump will run until it builds the needed pressure.
  9. Qavion
    14,269
    Ian Riddell
    #9 Qavion, Mar 21, 2017
    The F1 system probably needs to see the switch CLOSED. By disconnecting the plug to the switch, you are probably simulating an OPEN switch.
    You need to put something metallic between the pins on the plug you just disconnected and left dangling down. A bit of aluminium foil might work as a temporary measure. Just don't bend the pins.
    Cheers
    Ian
    (EDIT... Sorry.. cross-posted... also, disregard... see Taz355's post)
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    NOT for my F1.
    I checkd this a long time ago and just confirmed it.
    My car will shift gears if unplugged. I checked this because unlike th brake pedal switch you do not need a spare just unplug and go. My guess is the water shorted it out when closed.
    99F1
    Dave please check your car.
  11. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Just unplug it. Then check
  12. Boaf 32
    Aug 23, 2016
    390
    US
    Thanks Ian, I did put the wires from the release cable to close the circuit. The pump just keeps cycling... I'll try it again tomorrow when it's light. But I am not hopeful.
    Bob
  13. Qavion
    14,269
    Ian Riddell
    Sorry, Bob.. Disregard my post... See Grant's (Taz355) post.
    By the way, the F1 manual shows two symbols with open hood symbols. Which one is illuminated?
  14. Boaf 32
    Aug 23, 2016
    390
    US
    Thanks guys. I did just wash the car but was driving it just fine. I believe it did short out but I would have seen it when pulling out of the car wash and when I stopped for parts. It happened when I opened the door in-gear. Now I just hear the pump on and off and the light flashes.
    Bob
  15. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Are you positive, Grant?
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Well what I am possitive about is that when unplugged rear bonnett went into car and shifted from neutral to first, second, then third, left for about 5 seconds, then back to neutral and shut car off.
    I did not start car and try to drive because I believe I did that about 3 years ago before my long trip. I was chcking functions that could lockout transmission on trip without spares.
    The brack switch is definately one that will so I hav a spare, along with the grey tyco relay, and fuses in pfw.
  17. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    It is slightly possible that car needs to be idling.
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Want me to check it with plug in and bonnett open but not started??
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Sure but starting is not the issue - selecting and staying in gear is.
  20. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    What i am saying is with 100 percent confidence is when engine not started car stays in gear without bonnets plugged in.
    It may not when car started.
    Its differant need to check with car started.
  21. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Will do tomorrow i am sick
  22. phrogs
    phrogs F1 Veteran
    7,344
    Kzoo Michigan
    It will do the 3 shifts when engine is off. But not when on Il bet you a us dollar.
  23. Qavion
    14,269
    Ian Riddell
    #23 Qavion, Mar 22, 2017
    I just checked my non-F1 engine cover switch and it's open circuit when closed, and short circuit when the cover is open. This means that pulling off the plug will produce a lid closed signal.
    From the workshop manual
    "2.4.10. Engine hood switch
    The information of "engine hood open" is sent simultaneously to the TCU and to the alarm system ECU, through an ON-OFF switch that closes the circuit to ground.
    If this occurs when the car is at a standstill, the engine is running and a gear is engaged, the system enables the buzzer and releases the gear, passing to Neutral"
    Although I couldn't find a clear circuit, the text suggests that "hood open" closes the switch to ground... otherwise, wouldn't they call it a hood closed switch?
    Similar text is used for the driver's door switch.
    Cheers
    Ian
    (EDIT) Caution: Having seen the plug and trying to pull it off, I see how you could damage the wiring. For future reference, it may not be best to recommend removing the plug. You may need tools to remove the earth wire to allow sufficient wire length to remove the plug.
  24. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #24 Dave rocks, Mar 22, 2017
    Good to know - they probably do it opposite like this for a fail safe.
    This is from the WSM - although I don't understand the circuit symbol - from my knowledge of electronics (minimal) this is a bizarre format
  25. WATSON
    23,679
    WI
    Refresh my memory as my car has been buried under a cover for 4 moths now.
    Where is the "open hood indicator" and what does it look like?
    Are you looking at a warning light all the way on the left hand side of the dash? Solid or flashing?
