Trickle Charger | FerrariChat
Trickle Charger
Discussion in '458 Italia/488/F8' started by petromega, Jan 3, 2014.
  1. petromega
    petromega Rookie
    Oct 28, 2010
    27
    Hey All,
    Where is the charger on the 458. I thought it was in one of the bags under the hood, but it is not there.
    Ray
  2. jm2
    jm2 F1 World Champ
    Aug 19, 2002
    19,158
    michigan
    john
    that's where it's supposed to be.....ask the dealer where it went
  3. Clutch5150
    Clutch5150 Karting
    Jul 27, 2013
    221
    Actually mine was in a bag in side of the bag holding the car cover. Check there as well.
  4. Noblesse Oblige
    Noblesse Oblige F1 Veteran
    Nov 7, 2011
    6,114
    Three Places
    Yes.
  5. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Mine was there also.
  6. Surfah
    Surfah F1 Rookie
    Dec 20, 2011
    3,144
    +1. Secured to a cardboard backing.
  7. gilly6993
    gilly6993 F1 Rookie
    Aug 20, 2009
    2,558
    Longmeadow, MA
    Eric
    Is your car new or used?
  8. forgeahead
    forgeahead F1 Rookie
    Sep 16, 2008
    4,408
    Rocky Mount, NC
    Ray
    If you find it, don't use it. Use an aftermarket one (about $80). The Ferrari ones are notorious for not being effective.
  9. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Guess I should consider myself lucky. They have all worked well for the
    3 Ferrari's I have owned including my current 458.
  10. Rcktrod
    Rcktrod F1 Rookie
    Dec 21, 2010
    3,946
    +458
  11. 458dreamer
    458dreamer Formula Junior
    Jul 3, 2012
    762
    Dubai
    I have never used my trickle charger. After I found it in the trunk, i put it in the cupboard along with car cover where it has sat since. I just drive the car often enough which keeps the car charged. I don't travel for more than 7-10 days at a time, no problems starting car so far.
  12. Noblesse Oblige
    Nov 7, 2011
    6,114
    Three Places
    They do have a bad reputation. The one that came with my 458 failed early on but its replacement under warranty has been fine for 2 1/2 years. The one that came with our '07 F430 is original and still works fine.
    The OP should find his and try it out to make sure it is OK.
  13. RBK
    RBK F1 Rookie
    Jul 27, 2006
    3,105
    Calif and Nev
    Bob
    You could not prove that by me after almost two years of constant use. Best
  14. Rcktrod
    Rcktrod F1 Rookie
    Dec 21, 2010
    3,946
    Me as well. Over 2 yrs of constant use and it works great.
  15. Webraider
    Webraider Karting
    Sep 12, 2011
    227
    Germany
    Ulli
    Same here.
    Judging by it's outer appearance I'd say they are OEMed by C-Tek (from Sweden ?), the same OEM of the Porsche-chargers among others. I use a C-Tek-charger for my oldtimer, too, as it isn't driven most of the year.
    C-Teks have a good reputation as far as reliability and function are concerned.
    Happy New Year y'all, btw. ;)
    Best,
    Ulli
  16. LouB
    LouB Formula 3
    Apr 15, 2001
    1,811
    FL, OR
    Really, I have always used mine when I switch Fcars to drive. Has always worked perfectly.
    Also on my 430.
  17. petromega
    petromega Rookie
    Oct 28, 2010
    27
    many thanks, found it in car cover bag
  18. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    my OE charger has a special plug to fit the outlet under the passenger side dashboard. Can you get an aftermarket charger with this plug? If not, how do you attach to the car to charge?
    Mine works fine. cycles the battery.
    Best
