458 - Trouble installing carbon rear hatch pull on 458 with photos | FerrariChat
458 Trouble installing carbon rear hatch pull on 458 with photos
Discussion in '458 Italia/488/F8' started by FerrariCognoscenti, Sep 14, 2021.
  1. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    I bought a carbon rear hatch pull from exotic car gear to replace the stock plastic one on my 458. I was able to remove all parts from the old plastic rear hatch pull except the cable from the large pinion. It is crimped down and I’m not sure how to remove the cable without cutting it, however if I cut it and reinstall it on the new carbon rear hatch pull then the cable will be too short! I attached a photo of the problem area on the original plastic rear hatch pull with the cable crimp.
    Any advice is appreciated.
    Here are two photos of the cable on the original rear hatch lever:
    And here is a photo of my new carbon rear hatch pull that I haven’t yet installed as I can’t get the old one off!
  2. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,555
    AUSTRALIA
    ANGELO
    Check out to see how that cylinder is held in place. I'm sure the cable supplier to Ferrari would have already had that cylinder with the cable crimped. I would guess a screw on each end. Have a look
  3. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    The cylinder is held on by two C clips which I removed. Problem is the cylinder can’t be slid out from the two “posts” holding it because the cable goes through the middle of the cylinder.
  4. MANDALAY
    May 23, 2013
    14,555
    AUSTRALIA
    ANGELO
    Well that's a dilemma.
  5. PMiranda
    PMiranda Formula Junior
    Jul 23, 2004
    639
    Austin, TX
    Hmm... usually there is a slot cut in the back side of the cylinder so you can remove the cable once there is slack in it... Is there an adjuster at the other end of the cable?
  6. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,410
    Santa Clarita, CA
    It looks like that hex piece isn’t removable. What’s on the other end of the cable? You may have to remove the whole thing and pull the cable out of the sheathing, remove whatever is on the other end, then slide it back into the sheathing and reattach what’s on the other end of the cable.
    Does the factory sell that whole piece? How is it sold? With the cable already attached? Maybe call the Ferrari parts dept. and ask them.
  7. joseph
    joseph Formula Junior
    279
    New Jersey
    Open the engine bonnet loosen the cable in the engine latch.
    Pull out only the cable not protective covering. install the carbon latch insert the cable in proper hole and back to the rear latch not should slide in easily if not wipe it with some wd40 or similar insert the cable.
    install your carbon latch first then pull on the cable snug don't pull hard tighten instal the latch cover and admire your work.
    Regular Guy 01 likes this.
  8. ohared
    ohared Formula Junior
    Apr 14, 2009
    334
  9. FerrariCognoscenti
    Jan 19, 2021
    2,429
    East Coast
    Will try this weekend. If all fails I’ll just return the latch to exotic car gear. Hope it works out!!!
