Trunk lights in 328 ? | FerrariChat
Discussion in '308/328' started by Sigmacars, Jan 27, 2020.
  1. Sigmacars
    Sigmacars Formula 3
    1,218
    my 2 lights in the trunk are not comming on on my 1988 328US,I tried the parking light switch,the stack on the steering column no response,the bulbs are ok the wires are ok.there is no fuse listed in the manual for these lights,can someone help with this how the work.
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    When you say trunk lights, do you mean the ones built in to the underside of the rear deck? If so these are the number plate lights that will come on when you turn on your side/headlights.
  3. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    On my 308 there is a single wire connector at the right side hinge to power those lights. Is that fully connected?
  4. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    There aren't any trunk lights in a 328. As noted, those are license plate lights.
  5. dinoart
    dinoart Formula Junior
    798
    Westminster CA
    David
    Check the ground that's usually the problem. Remove them from the deck lid and clean the contacts.
  6. Rossocorsa1
    Rossocorsa1 F1 Veteran
    May 14, 2017
    6,217
    Incorrect. There are two trunk lights on the 328, located on the back panel of the rear compartment, under the vinyl zipper cover.
    Rifledriver likes this.
  7. Rossocorsa1
    May 14, 2017
    6,217
    Turn your headlights on. If they still don't go on then either the bulbs are bad or your connectors need attention.
  8. Sigmacars
    Sigmacars Formula 3
    1,218
    Don't you have a 328 have a nother look there are trunk lights in every 328,anyway the do come on when the lights are up so when you drive at night the are on all the time very strange set up.
  9. Brian Harper
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I don't see any trunk lights on the 328 parts diagram. I do see the same license plate lights that feebly light up the trunk when the lid is open. You can see the wiring runs to the front of the lid by the hinge to make the jump to the body.
  10. Rossocorsa1
    May 14, 2017
    6,217
    The license plate lights are completely different. No sense in confusing the topic. Yes, there are two trunk lights affixed to the back wall in the rear trunk, under the vinyl zip cover. I understand the skepticism, because Ferrari diagrams and owners manuals can be unreliable and incomplete at times. Regardless, they do exist, and they illuminate when the headlights are on.
  11. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,870
    Mike 996
    GREAT :) I learned something! I've never seen the "trunk lights" come on in my 328 and never noticed them being there in 11 years of driving the car! Goes to show what happens from making an "assumption" as opposed to actually looking it up in the owners manual, which I was too lazy to do. Thanks! AND apologies for leading the OP in the wrong direction!! :(
  12. Rossocorsa1
    May 14, 2017
    6,217
    One of those peculiar Ferrari oddities, particularly given that the headlights need to be activated for the trunk lights to be illuminated.
