Unobtainium Supplies: Jack Handle Ring | FerrariChat
Discussion in 'Technical Q&A' started by Verell, Jan 5, 2008.
  1. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    #1 Verell, Jan 5, 2008
    Awhile ago, Kerry Chesbro asked if I could source the plastic ring that slips over the jack handle extenson's end. These frequently develop cracks at the hex opening's points & then break if you continue to use them. According to the various FPCs they're not sold separately. These are used in most of the tool kits for 308s, 328s, Mondials, & others.
    I'm pretty sure that there was a thread on this, but am apparently not giving SEARCH the correct key words.
    Anyway, as you can see from the attached pictures I just finished making a mold. To avoid the breakage problem, I'm offering it in a very firm rubber like polyurethane similar to that used for suspension bushings. The hardness is similar to tire rubber. It's hard enough to be useable, but has enough give so that the hex opening won't split out the way the OEM ones do.
    However, if so requested, I can also supply it in the hard polyurethane I use to make the boot lid prop flex joints & the latch housings for the bonnet & boot latches. The hard polyurethane is quite a bit stronger than the OEM plastic, so if you twist it hard enough, it probably can be broken just like the OEM one.
    Price is $35 each.
    To order contact:
    Orders(at)UnobtainiumSupply.com
  2. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    8valve,
    Thanks for finding the older threads, spent half an hour trying to locate them before throwing in the towel.
    I just had an idea. I'm going to visit the HW store & see if I can't find a metal ring of some kind that's just slightly bigger than the hex. If I can find one, I'll try embedding it in the hard plastic part. Should strengthen it, & even if cracks start, they'll be less likely to grow past the ring. Forgot to mention, the hard plastic also contains a high % of glass fibers.
  4. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Thanks Verell! Will you let us know on this thread if you succeed in embedding the ring? I'd love to have one of those.
    Joe
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    BwanaJoe,
    Of course I'll let you know.
    Other than sourcing the ring, only problem I'm worried about is that I don't know of a way of centering it inside the casting thus it's likely to be near the surface, so might be visible if you look really close.
    Just browsed McMaster-Carr & they've got something that should work. Will get some on order.
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The ring must be pretty well centered around the hole to ensure stresses are distributed. If I just drop it around the mold's center, it'll be right on the hex hole's surface on one side.
    I've ordered a supply of small sturdy key ring type rings. I'm going to try clipping a piece of wire or thread as a chord thru the ring, the wire will rest on the mold's center & help radially center the ring in the mold. Luckily one of the hex's flats is facing upwards, so the wire will be stable resting on it! Not sure how to ensure it's more or less axially centered, maybe can bend & use the wire's free ends somehow.
  7. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    Hi Verell, I sent you an email.
    Thanks, Mick
  8. Darolls
    Darolls F1 Veteran
    7,782
    Sparky
    My jack is for an 84' 308QV and is like the one shown in this thread:
    http://www.ferrarichat.com/forum/showthread.php?t=134083
    I need the nylon bushing; anyone know if it can be replaced?
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Radially centering the ring by a wire chord works like a charm, but takes some extra time.
    BTW,Like most of my molds, this mold makes 1 part at a time, so production will be slow: Best case is about 2-3 parts/day.
    If you want to order, please send me eMAIL with the address to ship it to & a phone # for the shipping co.
    I'll send you a PayPal invoice unless you specify otherwise in the eMAIL. To send me eMAIL, just right click on my name & select [Send eMAIL to Verell].
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    CAUTION:
    The mfg. tolerences on the handle's hex are pretty sloppy. One person just reported breaking his new ring.
    When I measured across the flats of the ring & handle hexes I discovered that the handle's width varies widely. One pair of the handle's flats was 0.78 mm/0.030" wider than the narrowest pair of flats. The intermediate pair are 0.43 mm wider than the narrow pair.
    I measured a new & my OEM ring. They measure identical within my ability measure them. They should be identical as I made the mold from my ring, the materials & process I use preserve dimensions within 0.001"/foot or better.The ring's hex is much more symmetric than the handle's, the widest pair of ring flats is only 0.3 mm/0.012" wider than the narrowest pair of flats.
    My best guess is that the maximum manufacturing variation across handle flats is larger than my handle measured.
    I suspect that this handle hex size varience is a major contributor to the OEM jack rings cracking as well.
    I don't see any way that I could have forseen or avoided this particular problem. It's just Ferrari's usual poor quality tools(sigh).
    RECOMMENDATION:
    If your ring seems to be tight fitting, try several orientations on the handle. There should be an orientation where the ring slides onto the handle but isn't a sloppy fit. If necessary, I recommend using a small file to widen a pair of the ring's flats, & retrying. Repeat as necessarry. You probably won't have to remove much, maybe a few tenths of a millimeter.
    If I try to make the new rings with larger hexes, then most likely they'll end up a very sloppy fit on a large % of the handles. A loose fit will also stress the ring & cause it to be prone to cracking.
  11. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    That would be me in the above post. Turns out I wasn't paying attention when I attempted to install the ring on the spanner. While forcing it down the center hub began to split in two places. I quickly stopped. None of the plastic broke off and that metal washer embedded into the ring seems to have worked. What I didn't notice was a rather large "flash" line around the inner hex circle. I took a very small hobby file and filed all the flats smooth. Now it has a snug fit without having to be forced. Just to ensure I wouldn't have a problem in storage I did remove it to store it in the jack pouch.
  12. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I just checked some production parts & my OEM part. I don't see a flash line. Also, the mold doesn't have an joining seam inside the ring that would produce one.
    However, please notice that the hex thru-hole changes size about 1/2 way thru the ring. On my jack handle, the smaller hex (13.8mm/0.55" width across the flats) fits closely onto the jack handle's hex, & the larger(15.3mm/0.6") hex slides up over the round part of the handle.
    Joe, I'm wondering if your handle's hex is yet a different, slightly larger size than the smaller portion of the thru-hole, or maybe is the size of the larger hex part of the hole. If you have a caliper or micrometer, could you please measure across your handle's flats & post the size here?
    Whoda thought that Ferrari could complicate something as simple as a jack handle ring?
  13. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    LOL! The more I do this, the less shocked I am. You described it perfectly. That is what I meant by "flash" line. I'll have to check to see if I have a set of calipers. If not, this gives me an excuse to buy some!
  14. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Harbor Freight & others usually carry a 4" digital caliper for around $16. I've found that a 4" caliper is a lot more convenient size than a 6" caliper which is what the world seems to use. I've found that a 4" caliper handles 99.9% of my measurements. HF occasionally puts them on sale for around $10. I've got 3 of them, one for the lathe, the mill, & my casting workbench.
    I do have 6" thru 12" calipers, but mostly they stay in their boxes with the batteries out. Altho, my LH 6" caliper also stays by the lathe. I bought it so I could easily measure workpiece diameters. Would have preferred a LH 4" there also, but have never seen one.
  15. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    My caliper isn't as fine as yours but, I got about 13.8, 13.8 and 14 for mine. (The .8 is a guess) The handle is about 15.9.
  16. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    BTW, On the back side of the ring are a couple of mold marks that look like cracks. The original part was indeed cracked, the material I filled the cracks with before using it to make the mold had a slightly different surface texture from the original part, & a bit wiped out while I was smoothing it over. The mold picked up the difference in texture & depth & faithfully reproduced it.
    The fibreglass composite polyurethane resin I cast the ring from doesn't change dimensions while curing, & there's no significant temperature change involved, so there's no mechanism for the casting process to produce cracks.
    Joe,
    That 14mm dimension is probably why the ring didn't want to fit, the ring's only 13.8 wide.
  17. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Gotta love Italian engineering!
    I saw the marks on your ring picture just today, so good news then, no real cracks! The filing worked fine so no worries. It doesn't quite fit over the larger part of the handle like your does, but I am not going to mess with it anymore. The pieces all fit together and work without problems.
  18. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,259
    Black Forest Germany
    Martin N.
    Hello from Germany,
    Verell even ships his items overseas. Just a few days after ordering I received the jack handle ring yesterday. Great item. If any european FChatters are interested but concerned about shipping or whatsoever; be relaxed; I highly recommend Unobtainium Supply as a wonderful source. Amazing small-lot production and engineering.
    Best Regards
    Martin
  19. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Yes, still available, thanks for the PM.
  20. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    Verell is the best, can you make all the other parts I broke too! :p
  21. staatsof
    95,950
    Fuggetaboutitland
    Bob
    I finally found this part two days ago after extensive google searching via the number on the ring and it pointed to the Unobtanium website. Nowe a couple of days later I just happen to notice this thread ... how funny.
    I'm using it on my Espada.
    That number also points to the jack itself btw.
    On some older jacks it's metal and an integral part of the shaft.
  22. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Possibly/probably, What have you broken?
  23. robertgarven
    Feb 24, 2002
    5,294
    Ventura, California
    Robert Garven
    your not going to make me embarrass myself on line are you! :p
  24. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    You can always send me eMAIL... :D
