348 - Using anti-seize compound | FerrariChat
348 Using anti-seize compound
Discussion in '348/355' started by Fguy, Jan 20, 2020.
  1. Fguy
    Fguy Karting
    Oct 4, 2011
    69
    Sarasota, Fl
    Julian Angus
    I will be installing new plugs using the recommended NGK DR8EIX part number; I have seen recommendations from several members to use anti-seize compound but also I understand these plugs have the compound already on them. Which is the correct way? Thank you for your input.
  2. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Great question! I've used anti-seiz on all spark plugs in the past, but that was 10+ years ago for a Ferrari. Hopefully someone who's more current will respond.
    Interesting info from NGK (emphasis mine):
    1. Anti-seize
    NGK spark plugs feature what is known as trivalent plating. This silver- or chrome-colored finish on the threads is designed to provide corrosion resistance against moisture and chemicals. The coating also acts as a release agent during spark plug removal. NGK spark plugs are installed at the factory dry, without the use of anti-seize. NGK tech support has received a number of tech calls from installers who have over-tightened spark plugs because of the use of anti-seize. Anti-seize compound can act as a lubricant altering torque values up to 20 percent, increasing the risk of spark plug thread breakage.
    https://ngksparkplugs.com/en/resources/5-things-you-should-know-about-spark-plugs
    tonyswfla and Qavion like this.
  3. Rifledriver
    34,138
    Austin TX
    I use nothing but NGK and they say don't use it. I have never, not once ever seen a Ferrari motor from the factory with anti seize. That includes back in the Champion Spark Plug days and later with NGK.
    Given that, why do those guys know better than the combined engineering expertise of Ferrari and NGK?
    Spark plug threads get damaged from boneheads, not lack of anti seize.
    Beetle, BOKE and krazykarguy like this.
  4. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    Agree Brian. Some people are just too strong. I have always put a dab of antiseize on plugs especially in Al heads to prevent galling. However, I am very careful with torque and typically just snug plugs tight. The only ones that have ever come loose were ones I forgot to tighten!
  5. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,572
    SoCal LA/OC/New Mexico
    Tim Dee
    Anti Seize scooching down to the electrode is always a fun day :)
  6. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I am careful about who scooches my electrode :)
    SoCal1 likes this.
  7. AceMaster
    Feb 6, 2009
    34,560
    Ontario, Canada
    Isn't that what a torque wrench is for?
    I mean, I know it comes natural for some people and they just know how much to tighten without a torque wrench...but my inference was meant for people that like to gorilla tighten everything
  8. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I was being nice. Some people just dont understand basic mechanics. A good friend of mine, with my help over the years, has improved his skills, but sometimes just doesn't think. Like the time he set the torque wrench in ft/lbs when the battery terminal spec was in inch/lbs! Big difference in torque between inches and feet! He was trying to do it right......
    When I tighten a plug my hand doesn't go to the end of the drive but stays near the head feeling the washer crush, then a little more.
  9. Fguy
    Fguy Karting
    Oct 4, 2011
    69
    Sarasota, Fl
    Julian Angus
    Thank you so much for the feedback. Now to decide what to do since the schools of thought are quite varied. Thanks again.
  10. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    When opinions vary a lot it makes me think it isnt really an issue either way. Why do I put anti seize on a lot of stuff? Because my Dad did and it seemed to work.....not very scientific or based on any legit research. I do know I have felt some very dry threads removing old spark plugs that made my butt pucker and the new plug threads right in with a tiny amount of anti seize. Same with O2 sensors....they generally come precoated.
  11. Rifledriver
    34,138
    Austin TX
    On cars with garbage aluminum heads maybe but the alloy Ferrari uses has never been an issue. If you feel a bad thread in a Ferrari head someone already F'd it up and that isn't what we are talking about here.
  12. Rifledriver
    34,138
    Austin TX
    From the sources with any bona fides (in this case Ferrari and NGK) there are no varied schools of thought. The choice is to chase wives tales or do it right.
  13. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    I've never heard of anyone putting anti-seize on spark plugs. (I wasn't around back in the day) Maybe a very light coat of oil.
    Plug threads get damaged from cross threading or over tightening. That's about it. If an iron head with a steel bodied plug is exposed to water or salt/brine on a regular basis then one may need to find a way to prevent seizing but this is a very atypical.
    Anti-seize is messy and residue will thicken as it ages. Cleaning that out of a plug home on the next change is not fun.
    I think people over think things sometimes. I'm guilty of this myself.
    I would not recommend anti-seize on plugs unless you have a very specific/unique problem that needs to be addressed. Not under normal use.
    I've changed hundreds of plugs and never had an issue will galling or otherwise unless the person before me cross threaded the plug or over tightened it.
    Very light coat of oil from the dipstick. Thats it.
  14. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Some things were different back in the olden days. ;)
    From Ford TSB 06-15-2 and TB-8607-B:
  15. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Oh, and remember this? Marketed as "Insures Removal of Spark Plugs".
    So you can see why so many believe that anti-seize is necessary for spark plugs.
  16. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Wow, I cant believe I never saw that. Maybe I did but it did not register.
    What year was that for TB from?
    Maybe there are wide varieties of Anti-Seize.
    I've used the Aluminum, Graphite paste and that stuff is THICK and very messy.
    The copper stuff is similar in consistency.
    Very useful on exhaust parts in the Rust Belt North East.
  17. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    It was from 2006. Ford had a big problem with the motors in their F150 pickups. Lots of plugs breaking off and needing major head-work as a result. A co-worker of mine suffered that breakage with his truck back then as well.
    Here's some additional info:
    https://www.motor.com/magazine-summary/trouble-shooter-3-may-2008/
  18. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Interesting. Thanks for the info. Sounds like a serious defect somewhere in the design/mfg process. Now they are looking for band aids to keep customers from losing their minds. That sucks for the people affected.
  19. emac
    emac Formula Junior
    851
    upstate SC
    ernest
    I had one of those fords and let the dealer change the plugs. I never thought I would let a dealer change spark plugs for me! Luckily all mine came out. Stupid design.
  20. GTUnit
    GTUnit Karting
    May 25, 2014
    143
    Socal
    Jack
    Ahh, that photo clears things up. The plug threads were not the problem. The clearance between the long part of the plug, beyond the threads, that protrudes into the head was the problem. Carbon buildup fills in the gap and causes a nice, tight, binding seal. Agreed, stupid design.
