348 - View inside the Climate Control ECU - Info Request | Page 2 | FerrariChat
348 View inside the Climate Control ECU - Info Request
Discussion in '348/355' started by Wade, Mar 15, 2019.
  1. m.stojanovic
    m.stojanovic F1 Rookie
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Once you remove the TIP, the side of the diode connected by trace to the resistor (which is also connected to one of the TIP legs) will probably be free (unconnected to any other component) so you can test it then in-situ. When one side of the diode is free, it does not matter if, and where, the other side is connected.
  2. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    In order to be protection for the TIP against inductive spikes from the pump motor, the diode would have to be connected across the TIP's collector and emitter with its cathode to the collector. However, the diode is connected to the TIP's collector with its anode and its cathode does not seem to go to the TIP emitter but elsewhere.
    Otherwise, TIP142 (Darlington type) already has a built-in protection diode so it does not require an external one.
  3. Cauf61
    Cauf61 Formula Junior
    Jul 12, 2016
    557
    Belgium
    Patrick
    As i said probably.
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I ordered a replacement pump as cheap insurance (less than $60 from RockAuto). As the Lady says, "These go out quite a bit, so it's not really worth pulling them from junkyard vehicles 'cause they're usually seized."
    https://www.ferrarichat.com/forum/threads/question-about-the-auxiliary-water-pump-in-the-nose-of-the-car.249456/
    As per the video, there's a size difference for the pump's hose connections. We'll see how that turns out once the part comes in.
  5. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    I received a note from another one here on F-Chat. He has an original second gen ECU (151711 with the black back), his R82 is green as well. It's labeled "k8537".
  6. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  7. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I assume on the original pump the brown wire was '+' and the black wire is '-' ?
    Sent from my LM-Q710(FGN) using FerrariChat.com mobile app
  8. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  9. Gonman
    Gonman Rookie
    Apr 3, 2021
    1
    Portugal
    Gonçalo Marques
    Hi guys!
    I am currently rebuilding one of this modules for the HVAC of a 348 that got severely damaged because of a short.
    Can anyone tell me what the red component is and its MPN? Is it a PTC? A Varistor?
    Best regards!
  10. m.stojanovic
    3,309
    Serbia - Niš
    Miroljub Stojanovic
    Looks like a Transient Voltage Suppressor. Can you see the markings on it?
