want to buy a floor mount fire extinguisher | FerrariChat
Discussion in '360/430' started by bocaf430, Apr 1, 2015.
  1. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    Is there a certain brand or size that would fit best to mount to the floor of my F430? Can you just drill into the floor passenger floor section..or are there wires or other things in the way? I don't want to damage what I cant see under the floor..rug..
  2. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    I can't answer your question but be careful how you mount it.
    The last thing you want in a crash is a 3kg fire extinguisher bouncing around the passenger cabin.
    Mine is bolted to the central tunnel in the passenger footwell using the fire extinguisher brackets but I'm going to move it to the front boot.
    If I can't get at it quick enough there, the car is gone anyway.
    M
  3. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
  4. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
    Why not mount it to the passenger seat? Couple different ways of doing so depending on the desired orientation.
  5. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    I will just leave it behind the seat..make it easy
    Asthenis likes this.
  6. F360-1386
    F360-1386 Formula 3
    Oct 8, 2006
    1,685
    Markham, ON, Canada
    51216M
    Bottom line is as easy to reach as possible .... unless you want it as decoration ;follow the factory mounting in Scuderia or 16M is good.
  7. Rifledriver
    37,090
    Easy to mount to the electrical access panel behind the passenger. Also an easy reach from the drivers seat.
    It can also be mounted to the passengers side of the forward end of the center console without modifying anything. A little in the passengers way but not too bad.
    Basic rule of thumb, after mounting try real hard to pull it off by hand. If you don't get anywhere it is probably mounted well enough to be safe.
  8. cm2
    cm2 Formula 3
    Sep 26, 2012
    1,451
    SF Bay
    Nathan
  9. yronZFF
    yronZFF Formula Junior
    Dec 21, 2009
    749
    FIVE-O
    Ron
    #9 yronZFF, Apr 3, 2015
  10. F430-Scuderia
    F430-Scuderia Karting
    Feb 22, 2015
    67
    Italy
    Manny
    #10 F430-Scuderia, Apr 3, 2015
    +1! Here's mine
  11. scudF1
    scudF1 F1 Rookie
    2,917
    Long Island, NY
    Billy
    #11 scudF1, Apr 3, 2015
  12. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    Is there a certain type to buy..meaning what is inside the extinguisher?... I thought I read somewhere there are different types...
  13. scudF1
    scudF1 F1 Rookie
    2,917
    Long Island, NY
    Billy
    Honestly I haven't used it or open it.
  14. unkiemotorhead
    Nov 14, 2013
    45
    my 2 cents: B355T - Halon 1211 Fire Extinguisher 5 lb. Fits the factory mount almost perfectly. I added another layer of leather and it's now snug. Yes, it's in the passenger footwell, and yes, in a violent end-over-end accident it'll probably come loose and kill me. As my doctor sez: don't do that. OK. EMT/race mechanic/machinist friend shared this story: "Would put out a forest fire. I put out a 2.5 ton utility cab Truck. Like PG&E uses for line repair in the woods. 4x4, size of 6 pasta rockets. Fuel line was off and some fool tried to start it. well over a gallon of gas in, on the engine, cab, floor when it went off. Flames WELL over my head, out both sides, him in the cab. I hit the thing with a 5 pound Halon extinguisher and it was OUT. It was out faster than it took you to read this. Puuuuuuuuuuuuuufff and it was OUT! ( 3 seconds?? Maybe?? no exaggeration at all)"
  15. F360-1386
    F360-1386 Formula 3
    Oct 8, 2006
    1,685
    Markham, ON, Canada
    51216M
    You don't or anyone doesn't want to use it or open it .... I personally would want it to be there just for decoration and would never have a chance to use it ...
  16. sunir
    sunir Formula Junior
    Oct 30, 2014
    758
    MD
    Sunir
    Factory and floor mount unit is for decoration and original equipment factor. If you are reaching for that in a cockpit fire you have bigger issues already. If you want a real fire suppression system get a halon kit wired to a dash mounted kit with a minimum of three pointed nozzles. One in engine area, one toward drivers area and one toward drivers foot box. These are what properly equipped race cars use. Hope you never have to use it.
  17. mike01606
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Can you guys still buy Halon. Montreal Protocol killed it for us years ago.
    No doubt the best multi-purpose extinguisher ever made....
  18. unkiemotorhead
    Nov 14, 2013
    45
    Yes, Halon still appears to be a simple internet purchase in the US.
  19. F360-1386
    F360-1386 Formula 3
    Oct 8, 2006
    1,685
    Markham, ON, Canada
    51216M
    +1 if you go a track frequently. I have a fire-suppression system installed in my race car " mod 944 Turbo S" but on all my other cars , I have just a mounted one cause I use them on track only few times a year and not tracking 10/10 ...
  20. s52
    s52 Karting
    Oct 14, 2014
    168
    East Bay
    Christian
    anyone have a link to buy the factory fire extinguisher kit for an F430?
  21. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    I posted a link in post #3.
  22. JDoggery
    JDoggery Rookie
    Nov 1, 2013
    40
    Price is not listed. I assume it may vary on material covering as well. When you call, would you mind sharing. Most likely a lot more than when purchasing with the car.
