WARNING LIGHT!!! HELP PLEASE!!!! | FerrariChat
Discussion in 'United Kingdom' started by gumball3000, Dec 26, 2003.
  1. gumball3000
    gumball3000 Formula Junior
    Dec 17, 2003
    288
    East Yorkshire
    Ed Neilson
    OK....So I picked my F355 up on the 23rd and this morning......
    SLOW DOWN 1-4 comes on
    The manual seems to suggest a cat problem...
    Anyone got any ideas? I am driving myself nuts here!
    Merry Christmas by the way!!!!!
    Ed
  2. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Does your car still have the cats on? mine were removed when tubi was fitted... have you attempted to re-start car since warning light came on.sometimes these things just seem to right themselves. if you are still having probs, i suggest you post this msg on main discussion board and someone will help. sorry i can't be of more use .
    good luck
    tony
    ps. i assume you phoned the dealership to let them know?
  3. gumball3000
    Dec 17, 2003
    288
    East Yorkshire
    Ed Neilson
    Tony
    Merry Christmas!
    No one in at the dealers today! The car starts fine but after a few seconds it seems to retard the ignition and the light comes back on. I will try again shortly. I am wondering if the cat has got wet?
    Taking them off may be a good plan for future reference!
    I will let you know how I get on!
    Ed
  4. Dale
    Dale F1 Veteran
    Oct 7, 2003
    5,211
    uk
    Dale Juan
    Hi Ed sorry to hear youve got the mil light on,
    you are going to have to get the dealer to pick it up,i personally would not drive it till its been code read and rectified by the dealer,they may say its ok drive it down,its only one of many sensor's or a wiring harness fault,as tony said post it on the tech help board you should get the code meaning on there,at the end of the day Ed its a dealer job just a shame they are closed,
    merry christmas
    Dale.
  5. gumball3000
    Dec 17, 2003
    288
    East Yorkshire
    Ed Neilson
    Dear All....
    It seems there may have been a temporary glitch....I started the car and let it warm up and there were no problems at all this time. I took her for a quick run up and down after warming her up and she runs like a dream again. Maybe she had a post Xmas Day hangover!!!!
    Tomorrow morning will tell all!!!
    Ed
  6. MarkCollins
    MarkCollins F1 Rookie
    Jul 2, 2002
    3,202
    South England
    Mark Collins
    Ed
    It's a common problem normally caused by the insulation breaking down on the Cat ECU's and water/ moisture gets in, there is one per bank, 1 - 4 is mounted on a plate behind the rear wheel arch. It's a 5 min job to change but they are expensive, around £150 a go so get the Dealer to change it as it will never get better only worse. The system can shut the whole bank down if it gets the wrong signals
  7. harmitc
    harmitc Karting
    Nov 2, 2003
    207
    England
    Bernard R
    I agree, almost certainly a CAT ecu. You can pull the plug that that connects the ECU to loom & the car will run OK, but the light will remain on. However check with dealer & ask to be talked through the procedure if the service dept can't help before Monday!
  8. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    If its post 1995, does it have an OBDII conector?
    If so you may want to get a cable and turn the light off yourself (it sounds daunting at first but its really really simple, you just need a cable, some software (vag-com seems to work) and an hour or two)
  9. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Ed ,
    I trust 355 is behaving itself following earlier incident? Any chance of some pics ..... you've had plenty of time to take some !
    Tony
  10. gumball3000
    Dec 17, 2003
    288
    East Yorkshire
    Ed Neilson
    Tony!
    Have got the pictures! Unfortunately my photoshop has broken and I cant resize the pics at the moment!
    Will get them up ASAP!!!
    Ed
  11. stevep
    stevep F1 Veteran
    Jan 19, 2004
    8,345
    Geordie Land
    steve
    did you get this sorted. Mines done the same for about 6 months now. Range dealer and they said to give the car a long run. Light went off after about 7 miles. But comes on itemittently. It has also shut down four cylinders before., but if you pull over and turn ignition off/on it clears. It is a well known fault on 355's and its normally just the cat ecu sensor thats faulty. Just needs replacing. Its 99% of the time this and not the cat thats shafted!
    steve
  12. MackemX
    MackemX Rookie
    This may be a stupid question, but is it possible to get the dealer to remove the cats or do you need a whole new exhaust for that?
  13. kenyon
    kenyon F1 Rookie
    Oct 7, 2002
    2,836
    East Yorkshire
    Justin Kenyon
    If you remove the cats you will not have this problem with ECU warning lights coming up. They measure the temperature of the cats.
    Try this method it has worked for many I know.
    Disconnect leads from battery.
    Leave off a few minutes
    Reconnect battery leads.
    Start engine. Dont rev.
    Leave to idle for 10-15 mins.
    No lights should appear.
    Turn off engine.
    Re start and go for a drive.
    I understand this method resets the ecu's.
  14. gumball3000
    Dec 17, 2003
    288
    East Yorkshire
    Ed Neilson
    Gentlemen!
    Thanks for the suggestions!
    Fortunately the car sorted itself on Boxing Day! All fine, and no problems since!
    Ed
  15. wazza
    wazza Formula Junior
    Oct 9, 2003
    614
    Ed,
    Glad you got it sorted
    Happy driving
    Wazza
  16. wazza
    Oct 9, 2003
    614
    Hey Ed,
    I noticed that GPR are advertising for a new sales rep for thier Chiswick store.
    Are you boys getting a bit overworked ?
    or is it that you just new blood for the PS2 game.
    Wazza
    BTW how much are they paying.
  17. Dale
    Dale F1 Veteran
    Oct 7, 2003
    5,211
    uk
    Dale Juan
    Wazza you been on autosport appointments
    Dale.
  18. gumball3000
    Dec 17, 2003
    288
    East Yorkshire
    Ed Neilson
    Not sure how much they are paying! Not enough I would imagine!
    The reason for the position is my impending departure! A the end of the month, to be precise! I am heading off to look at other projects. (i.e no idea!) I was only on a 6 month contract, so I am looking for another consulting job...That is what I do!
    Ed
