Washer Bottle | FerrariChat
Washer Bottle
Discussion in '308/328' started by Dorsetgem, Mar 10, 2019.
  1. Dorsetgem
    Dorsetgem Karting
    Nov 15, 2014
    115
    Verwood UK
    Glen
    Hi All
    I have just gone through some older posts but haven't found an answer. I would like to clean my washer bottle as it is very dirty & grimy. It is currently soaking in washing up liquid but I wonder if anyone has used something more aggressive to get it looking new ?
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    Some says bleach works well.
  3. Schulz308
    Schulz308 Formula 3
    1,454
    STL USA
    Remove the pump n cap den,
    Presoak overnight in hot water an dawn dish soap den Trow it in ya dishwasher.
    Your girl will think youz great if ya trow another dish or two in der also.:D Fuggedaboudit
  4. kidryno
    kidryno Karting
    Dec 22, 2014
    92
    Atlanta, GA
    This might be a really dumb question (so apologies in advance), but what's the easiest way to disconnect the bottle from the pump?
  5. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Easiest: Buy a new pump ($18) and cut the old one off with a Dremel.
    eyeman1234 and Martin308GTB like this.
  6. Martin308GTB
    Martin308GTB F1 Rookie
    4,231
    Black Forest Germany
    Martin N.
    +1. Especially since the new pumps install much easier without that inner sheet metal ring. The new ones have a different seal, which simply locks into place.
    Thanks once more to Robert -Crowndog-, who sent me a new pump last year.
    As for cleaning the bottle. It might be of little to no help, but I cleaned mine by submerging it - after removal of the old pump- in my ultrasonic cleaner, filled with a highly concentrated, plastic friendly cleaning solution and with heating. And let it run for half an hour at 50 centigrades.
    Before:
    After:
    Best Regards
    Martin
    Rosey and waymar like this.
  7. Dorsetgem
    Dorsetgem Karting
    Nov 15, 2014
    115
    Verwood UK
    Glen
    Looks good
  8. Martin308GTB
    4,231
    Martin N.
    Thanks. The problem with cleaning such things, is reaching every corner on the inside. This is, what ultrasonic cleaning can easily cope with.
    Best Regards
    Martin
  9. Martin308GTB
    4,231
    Martin N.
    BTW. It just comes to my mind, that before I fill in my fresh coolant after my recent work, I would like to clean the inside of my header tank. It was never cleaned in 38 years and there are all kinds of hardened debris, especially on the sidewalls. Otherwise it's looking good. I suspect no deeper corrosion.
    Did anyone perform this task? What's the best cleaner to use? I suspect, that something acid would work best, but I'm a bit hesitant. I would once again put the header tank into my US-cleaner, which I can heat up till 80 centigrades.
    Best Regards and thanks in advance
    Martin
  10. miketuason
    Feb 24, 2006
    15,541
    Cerritos, CA.
  11. Saabguy
    Saabguy Formula 3
    1,761
    Shreveport, LA
    Martin, is your ultrasonic adjustable? Might be too much for a hard, thin, metal.
    Lester
  12. Martin308GTB
    4,231
    Martin N.
    Hi Lester,
    unfortunately no. It works with constant 160watt US-power. I can only adjust time and heater temperature. Do you think, that's too much for the header tank's brass sheet metal?
    The stainless steel tub of the US-cleaner is not much thicker. But it actually shows some erosion, especially around the piezos.
    Tub wear (erosion) after approx 200 hrs. in use:
    The cleaner:
    Best Regards
    Martin
  13. Saabguy
    Saabguy Formula 3
    1,761
    Shreveport, LA
    Martin, that is much smaller than I thought. I was expecting a big commercial unit. I don't think it would be a problem but you might find someone else's tank to try first. ;-)
    Lester
  14. dinoart
    dinoart Formula Junior
    756
    Westminster CA
    David
    Martin
    Is that an inline filter on the Cavis hose? That is an excellent idea stopping sending unwanted particles down to the nozzles. What kind of filter is that? I like to do the same.
    David
  15. Saabguy
    Saabguy Formula 3
    1,761
    Shreveport, LA
    #15 Saabguy, Mar 14, 2019
    Can't delete post... so never mind. I was thinking of another pic.
  16. Martin308GTB
    4,231
    Martin N.
    David,
    Yes.
    It's a small inline fuel filter, used on small motor vehicles, like scooters for instance.
    But I haven't installed it with the new pump. I had the impression that it restricts flow too much. But I will try once more soon, because the new pump is so much more powerful than the old worn out or -more likely - partially seized one. Had to adjust the nozzles, because the first try ended with washing the engine lid and roof instead of the windshield.
    Lester,
    as for my US-cleaner. Yes, it's the smallest I found, which still takes two Weber 40 DCNF. That was my aim. Because the bigger, the longer it takes to heat up and the more cleaning solution is needed. Mine has a roughly 10 ltr. capacity.
    Had a cheap chinese machine from ebay before. But was not happy with its US-power. This is much better, costing €1.200.00 though. But it's worth its weight in gold. Since I have it I don't waste time no more with manually cleaning things as long as they fit into this washing machine.
    Best from Germany
    Martin
  17. Saabguy
    Saabguy Formula 3
    1,761
    Shreveport, LA
    That makes sense Martin, I purchased a used one large enough to load a 3 cyl engine into. Got a great deal as someone bought and found that it didn't do what they wanted it to. Yes, it takes a lot of time to heat up and I need a garden hose to fill it.
    Lester
  18. Martin308GTB
    4,231
    Martin N.
    Pictures? :)
    Best from Germany
    Martin
  19. Saabguy
    Saabguy Formula 3
    1,761
    Shreveport, LA
    When I get out to my shop, might be a few weeks.
    Lester
  20. Martin308GTB
    4,231
    Martin N.
    My "shop" and garage is just downstairs, but this is also the reason, why I slowly run out of space for my gear and could not purchase an US-cleaner taking a (american) V8-block :)
    Best from Germany
    Martin
  21. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,419
    Toronto / SoCal
    Rob C.
    For those of us that do not have an ultrasonic cleaner lying around I'll share a tip that I previously offered to scrub the inside of tail lights. Half fill the bottle with a solution of water/bleach/and some dish soap. Then add a half cup of un-cooked rice. With the bottle sealed shake it vigorously and the soft rice will gently scrub every corner on the inside of the bottle. Rinse and repeat as necessary and you can achieve some incredible results.
    Over time the bottles will yellow so you can never get that fresh white of a new bottle but you can get it very very clean and even looking with a little elbow grease.
    eyeman1234, Martin308GTB and thorn like this.
  22. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Long screwdriver down the throat to pop off the ring. You will want to replace it with a much easier to install pump. Search for my thread on this .
    thorn likes this.
  23. Martin308GTB
    4,231
    Martin N.
  24. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  25. Martin308GTB
    4,231
    Martin N.
    IIRC they were already gone, when I asked you last year. But I remember I saw them before the big update.
    Have to look,what happened to mine on older threads.
    The big update leaves much to be desired. Especially it's the 'internet short living'-philosphy, They don't even give us enough time to go over tech posts once more. 10 minutes is a joke. I fear, quality is not the priority.
    A lot of things went down the drain with the introduction of the modern look. Support for subscription paying members too.
    Best from Germany
    Martin
