Weight saving on 360/F430 ? | Page 2 | FerrariChat
Discussion in '360/430' started by 360trev, Mar 21, 2018.
  1. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
  2. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I betting it will weight in at 2500 to 2450 :)
  3. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    How do you drive it with no seats or dash ?
  4. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Mase engineering is going to have some time decoding out the ECUs from all the systems we deleted . I would like to see some good pics of your car inside and out , mind so be back on the road in a few weeks one year down
  5. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    What systems did you delete ? Are you keeping a weight saving diary? Would be fantastic to post differences. The whole air injection, pump, etc, can be deleted if you get mase to disable air injection in ECU firmware. Then you can use lightweight headers and cats too.
  6. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Mase said he may need to keep my car for a week or so, decode out air bags, anit theft , power windows doors evap and secondary
  7. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Airbags only effects dashboard clocks, a resistor trick can stop light triggering but you can also remove airbag ecu entirely, wiring the lot. Even without patching firmware you can just cut track to the led. Be aware some places you cannot do this legally so check with your local laws. Airbags with harnesses make no sense. Windows has a seperate ECU which dont trigger any lights and are not monitored. You cannot remove ECU if you want to Keep
    Power locks as it's combined but will do no harm if you fit lexan side windows to just leave it in, not very heavy. Same for alarm siren and tilt sensor, can be removed without problems. Only tricky one on list is immobilizer, can be done by either Messing with immo settings in eeprom on ignition ECUs or patching it out completely from firmware flashed. Be aware without immo you may invalidate any theft insurance.
  8. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    Trev thanks again I have already remove air bag ecu and dash cables wend we where installing all new CS harness, from dash front compartment and the upper dash harness even asr cable , pedal cable F1 harness LH tunnel cable, even shock ecu and so on. And you are spot on about the four point harness and roll bar wend strap in the air bags will never touch in a collision. If you are thinking about all the harness I replace would be a ton of money ? there is a trick I figured out go to Ferrparts and Eurosparse there are about five efferent part numbers for the same F1 harness cable the price is from 5800.00 to 633.00 they are the same cables.. Wend I bought my F1 harness for 633.00 I was thought there has to be some thing not right it was perfect .
  9. Mickster
    Mickster Formula Junior
    Oct 24, 2015
    608
    Sweden
    Mikael Andersson
    Man! I just love it when people leave their comfort zone and do something different!
  10. duck.co.za
    duck.co.za Formula 3
    Jan 9, 2007
    1,004
    Cape Town South Afri
    Dave
    Great info , thank you . Is there a difference in the harnesses LHD to RHD ?
  11. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    not on the F1 harness same LHD to RHD Eurospares are by far the best to deal with, my go to guy there Neil
  12. RANDY6005
    RANDY6005 Formula 3
    2,271
    Jacksonville
    RANDY
    I put the my 360 on a set of scales after I removed all carpet and insulation and replace new CS interior alcantara it weight in at 2840 pounds .... I will have reweigh again after removing air bags secondary air system and evap the stock battery and replace with light weight Odyessey and removal of stock battery tray and replace aluminum race battery tray and all Lexan glass for the doors and rear glass and Euro spec new factory front and rear bumpers and much to mention now we estimate another we shed another 400 pounds real close now to weigh in at 2450 2500 pounds may be less
    tifosi101 likes this.
  13. deimh
    deimh Karting
    Sep 4, 2016
    93
    Australia
    David
    #41 deimh, May 20, 2019
    Trev
    Firstly thanks for all the fantastic info in this post (as well as your many other posts) - it is wonderful that you gurus share your knowledge with those of us less capable!
    I am coming from this in a slightly different way and instead of trying to lighten a road-going F360/F430 I am just kicking off the process of road-registering my F360 and F430 Challenge.
    I do quite a bit of historic racing (mainly single seaters) and don't care for the "softness" of modern supercars (just my personal view-point, so please don't flame me) and hence I want a proper "road-racer" that is as much of a snarling brute as possible.
    The F360 Challenge is the last one that Ferrari built and was never raced and still has less than 1000 miles on it. Hence I would like to keep this "standard". However, I'm thinking of playing about with the F430 Challenge a little and driving that quite a lot.
    In addition I have a crashed F430 Challenge, which I bought as a "lifetime" of spares and after seeing your analysis of bhp/tonne it got me thinking whether I could rebuild / upgrade the engine out of the crashed F430 Challenge and try and reach the bhp/tonne of the La Ferrari. By my calcs I would need to get 590hp out of the F430 engine - see below:
    Ferrari Model -- kg -- bhp -- bhp/ton
    F360 CH -- 1170 -- 427 -- 365
    F430 CH -- 1185 -- 503 -- 424
    La Ferrari -- 1585 -- 789 -- 498
    F430 CH Mod -- 1185 -- 590 -- 498
    I don't have the weight of the F430 Challenge, so I assumed it was 15kg more than the F360 Challenge - is that about right?
    The plan could also include removing the front half of the roll-cage (which I estimate a weighting saving of about 35kg) and this would reduce the bhp needed down to 572bhp.
    So what are your (and others') thoughts on getting 572 - 590 bhp from a F430 Challenge engine (without adding forced induction), and what would the best route be this horsepower gain be?
    Dave
    PS As everyone likes pics - some of the F360 and F430 Challenge cars in their hibernation state and the crashed F430 Challenge in a less peaceful state...
  14. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,759
    England
    Mark
    600 from the F136 is achievable. I'm currently putting together parts for a 600@9k RPM build .
    Your best bet is to find a builder with experience - some of the later Scuderia GT3s ran air-shift in place of the F1 system and 4.8l displacement made some interesting figures.
    Bas likes this.
  15. Some Guy in the sky
    Some Guy in the sky Formula Junior
    Sep 19, 2018
    355
    Does anybody know what items are absent on a 1999 US Modena compared to all other years for the US models other than the secondary air system and precats in headers?
  16. deimh
    deimh Karting
    Sep 4, 2016
    93
    Australia
    David
    Hi Mark
    Thanks for your input - I am a huge fan of yours and I have followed all your builds on the "other " forum - fantastic work and brilliant determination!
    Is there any chance of following your lead (i.e. tagging along) on your engine rebuild? I will drop you a PM...
    Thanks again and appreciate the input and advice!
    Cheers
    Dave
  17. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,759
    England
    Mark
    Thanks Dave! Of course. I can out you in contact with the guy porting my heads and regrinding the cams.
    Mark
  18. deimh
    deimh Karting
    Sep 4, 2016
    93
    Australia
    David
    That would be brilliant - thanks!
    PM sent....
  19. Dewinator
    Dewinator F1 Veteran
    7,481
    WA
    Trev, header question: if when I solve the precat issue by installing precatless headers and relocating the sensors to a downsteam location on aftermarket cats to avoid a CEL, if I delete the air injector system as well, will there be much weight savings? And will it cause a CEL I can't get rid of without using your upcoming tool? Thanks!
    360trev likes this.
  20. azzurribaggio
    azzurribaggio Formula Junior
  21. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,725
    Lake Villa IL
    Not a bad idea for some, but not all.
  22. 360trev
    360trev F1 Rookie
    Project Master
    Oct 29, 2005
    4,329
    Gibraltar
    360trev
    Pm me and I help. The cat efficiency delete via my Swiss Army Knife SAK tool works 100% across all 360s and F430s including CS and Scud. Can also do air injection delete too no problems.
    Dewinator and G. Pepper like this.
