Well.. I did it (Range Rover) | FerrariChat
Discussion in 'British' started by Matthew_Love84, Nov 1, 2006.
  1. Matthew_Love84
    Matthew_Love84 Karting
    Aug 9, 2006
    143
    Orange County, CA
    Matthew Love
    got my wife out of that crazy ass mind set of getting a 500hp muscle car, and pointed her in the direction of a luxery SUV. It's simpler, we have a dog.. and with her career the extra space could come into play.
    So, I'm looking at the Range Rover V8 (non supercharged) 305hp car.. what do you boys think? Anyone have any owners experience with these cars? Are they a nightmare when it comes to service?
    I heard you either get lucky and have zero problems, or you're at the dealership once a month.
    a bit scary
  2. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
  3. drjohngober
    drjohngober Formula 3
    Jul 23, 2006
    2,040
    Cville and Gbury Tex
    Dr.John Gober
    Over the last ten years I have owned many sports cars as well as SUVs. I hads an 05 Range Rover for about a year. It was the biggest, unreliable,finicky,problematice PO$ I have ever owned. Broke down totally unexpectedly and without warning on the highway with my wife and son. Neither would ever ride in it again. Read previous threads and investigate the MB GL 450,Denali or H2. At the very minimum, these trucks will start and not leave you stranded. Be sure and read previous threads.
  4. crazynova23
    crazynova23 Formula Junior
    May 2, 2005
    895
    Las Vegas, NV
    Kyle
    What is wrong with you? If you wife wanted the 500hp car, you should have let her get it. Then you could have bought the SUV yourself and taken the car out when desired.
  5. bostonmini
    bostonmini Formula 3
    Nov 8, 2003
    1,890
    I think you can get a cayenne turbo for cheap used no? relatively speaking? also I think the Infiniti FX is a great buy.
  6. ShopBoy87
    ShopBoy87 Karting
    Jun 27, 2006
    82
    Sacramento,Ca
    Matthew H-McCormick
    Matthew-
    As Bullfighter pointed out, this topic has been covered quite "extensively" already but I'll try to give some input. What I recomend doing prior to the purchase of any vehicle is do as much research as possible, especially if the car is British! Your new favorite website should become www.rangerovers.net but specifically this link http://www.rangerovers.net/rrmkiiiremedies.html. Almost 95% of the problems listed on that page are minor and very easy/cheap to remedy. It's always best to familiarize yourself with the possible problems that may arise. When you ask people what they think about Range Rovers they've owned your going to get a mix of polar opposite answers. There's two groups of Rover owners, one group that can't praise the trucks enough because they haven't had any problems, and the other group who could write a novel about how horrible they are because they've obviously had to spend their life savings on repairs. From 2003 (which was the first year for the new body rover "Mk III") unti 2005, there weren't many changes. For these three production years they kept the same BMW 4.4 engine which I believe to be far superior to the new Jaguar derived engine they introduced in the summer of '05 which became the '06's. The most common issues that I've seen are the little things such as electrical gremlines, brake switches, etc. On two occasions I have seen failure of the tilt function of the steering column which can either be as easy as a motor replacement all the way to a new coulumn needing to be installed. I've yet to see any front differential failures, but that's likely due to the fact that these issues were still being remedied by the dealers. One big plus is the air suspension in the MkIII's is also far superior than the system in the previous model. I've yet to see any MkIII's with air system issues. My advice would be to skip out on purchasing a new 2006 and look for a new '05 with a good warranty, or saving yourself 15-20k and buying a Land Rover Certified lease return '03-04' with under 30,000miles. Most of these certified Rovers still have warranties remaining and when those run out it wouldn't hurt to purchase an extended through a third-party company. Also become familiar with any independent service facilites in your area. Chances are you can save a good amount of money by having your Rover *serviced* at an independent instead of a dealer. The reason I recomend buying a lease return or certified rover is that most of the problems in these cars arise early on and would have been alleviated by the first owner. Another point is that these things depreciate like a lead rake. An '06 will have the same value as an '03-'04 in 1-2yrs and the average joe blow couldnt tell the difference between the two cars so you'd be better off saving money and buying an older model. The only exterior change was a different front facia and rear taillights in '06. Hardly noticeable. For me, the pro's far outweigh the con's and it comes down to how much you like the vehicle. Personally I wouldn't be caught dead in any other SUV. You're not going to find the quality of the Rover interior in any other SUV on the market these days. Keep in mind I deal with these things on a daily basis as I work at an independent Land Rover service facility so I do have an idea of what I'm talking about. This may also make me a bit biased as well... :) Hopefully my reply will give you a little insight. If you have any other specific questions, shoot away and I'll answer them. The more you know before you buy, the better off you are! Best Regards, -Matt
  7. drjohngober
    Jul 23, 2006
    2,040
    Dr.John Gober
    I hate to disagree but 33% of all Range Rovers from 2003-present have had the differential failure. This is per the RR Forum. My local dealer says that that is actually a conservative number. From your own personal experience, how ofter have you seen one broken down on the side of the road. How often have you had ex-owners comment on how unreliable they are. The owner websites are full of people discussing the problems they have had.Makes F-Chat look like a tea party. Build quality-what a joke. I cannot count how many CD players and electrical gremilns mine had. Lights worked sometimes, sometimes they did not. Sunroof did not line uup and close properly-three trips...goes on and on. I took over a $20K loss in 1 year- the dealer told me they did not want used ones back. The MB GL450 is light years beyond the RR- not even in the same class.
  8. william
    william Two Time F1 World Champ
    27,659
    Good Luck!!
    My neighbour bought one 2 weeks ago. The car has been at the workshop 3 days already, for trivial faults he wanted sorted. BUT, he had to be rescued once on the road (don't know why), and this morning the RR wouldn't start and he had to call the AA again. I just gave him a lift to the train station in my Jeep as he was going to miss a business appointment.
    The guy is well pissed off, and I didn't ask too many questions about his first impressions!
  9. Mike J
    Mike J Formula Junior
    May 10, 2005
    570
    Ship Bottom, NJ
    Michael
    To steal a phrase,
    Absolute Junk, Absolutely.
  10. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    Friends don't let friends drive SUVs...
  11. mattymouse33
    mattymouse33 F1 Rookie
    Oct 25, 2004
    4,634
    We'll set aboot ye!
    Matthew
    mmmmmmm, decisions decisions decisions!!!!!
    What to buy out of all those cars, hmmmmmm.........
  12. Matthew_Love84
    Aug 9, 2006
    143
    Orange County, CA
    Matthew Love
    I have been shopping around quite a bit lately, and I appreciate all of the information you guys have shared with me. I came to a conclusion this is one of the best places to get information on car, ferrari or not.
    After driving an M6 I just wasn't impressed, same with the M5.. My wife is looking into a new car and I just dont have a giant knowledge on standard cars that she's into (SUVs, etc..) so i thought I'd ask some of you guys.
    I personally now have started my quest for a 575M (wish me luck :) ), and I've never been so excited. The Range Rover was going to be something that my wife and I would use as a dailey.. but with these reports I think i'll stay away.
  13. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    Have her check out the SRT-8 Jeep Grand Cherokee. Loads of performance for a bargain price.
  14. BoxerCrazy
    BoxerCrazy Formula Junior
    Nov 7, 2002
    355
    Charleston WV
    Douglas A Hunt
    Toyota LandCruiser , nothing else even comes close!!
    doug
  15. Tyler
    Tyler F1 Rookie
    Dec 19, 2001
    4,274
    dusty old farm town
    Tyler
    Agreed!
  16. crazynova23
    May 2, 2005
    895
    Las Vegas, NV
    Kyle
    They get up and go, I've driven one. Also, the interior is pretty nice too, especially the seats.
  17. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,687
    Kansas
    Chris Parr
    Well, I have a 2006 Sport and it is the best new car I have ever owned, 12,000 miles and not a single issue...
    My Mercedes sucked.... Hummer really sucked!!!!!!!!!
    Chris
  18. william
    27,659
    parkerfe. Can you explain us WHY?
  19. william
    27,659
    Well, now you are talking!
    I have a 2-year old Grand Cherokee, and never had any problem.
    Good service from the dealer, and good value for money too.
  20. 8 SNAKE
    8 SNAKE F1 Veteran
    Jan 5, 2006
    6,948
    Springfield, MO
    He might be able to tell you why it's not right for HIM, but he can't tell you why it's not right for YOU.
