What are 355 wheel spacers for? | FerrariChat
Discussion in 'Technical Q&A' started by vref, Jan 11, 2004.
  1. vref
    vref Karting
    Dec 18, 2003
    214
    1 Hr North of Housto
    Jim
    What is the purpose of Wheel spacer for a 355? I see them advertised and wonder why these are needed.
  2. yfc
    yfc Karting
    Dec 23, 2003
    212
    Geneva / Switzerland
    Christophe
    I could not find anything in the F355 user manual. Where did you find these information about wheel spacer?
  3. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I have just put them on my 355 spider, all they do is put the wheels just behind the wheel arch,thus giveing it a more agressive and a little wider stance. Some say this puts strees on the bearings but i have used them on a few cars with out problems.
  4. rossofiorano355
    rossofiorano355 Karting
    Dec 22, 2003
    210
    NOLA - Bham
    Ron
    chaa, what is the thickness of the spacers you used? all four wheels?
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,269
    Wheel spacers move the track outward but leave the suspension movement point unmodified.
    At the front, this results in higher compressive forces in the steering rack, and decreases the feel of the contract patch as felt from the steering wheel.
    At the rear this moves the contact patch outwards, and thereby, causes large braking forces to cause toe OUT, and accelerative forces to cause toe IN. Neighter toe change happens in 348/355 rear suspensions with original wheels and tires.
    Is any of this big enough to worry about, likely not unless you are into racing. The the forces are real, nonetheless.
    Widening the track, causes more weight to reamin on the inside tires in turns, and thereby increases grip (marginally), but is no substitute for lowering the center of gravity.
    I supply the following picture to show the F355 suspension system:: notice how the ball joints and teh shock forces are angled to the center of the contact patch..........
  6. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    I'm curious about the wheel spacers as well. I am considering them for the front, because the wheels don't look right as they do not sit at the edges of the fenders like the rears - hey no laughs, looks are important!
    Mitch,
    What are the real world (not track) implications?
    Do wheel bearings noticeably wear faster for 1/2 inch spacers in front.
    Does a 1/2 inch per side make the steering noticeably numb?
    Would appreciate any input.
    Thanks,
    David
  7. Mitch Alsup
    Nov 4, 2003
    9,269
    My guess is that 1/2" is small enough that the bearing longevity will be essentually unchanged, while the ball joints longevity may go down somewhat, steering tie rod ends longevity may also go down a little. If all these parts are supposed to go 100K miles and then show noticible wear, then the spacer car would get 85K-90K.
    As to steering sensitivity, this would be similar to the difference in steering sensitivity when comparing r-compound tires to regular high performance street rubber. I suspect may will actually like deadening the steering sensitivity.
