What battery fits the 2010 California? | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by DrFeelGood, Apr 2, 2020.
  1. DrFeelGood
    DrFeelGood Karting
    Feb 4, 2014
    55
    I've got a 2010 California that needs a new battery but nobody seems to know what battery to order to replace it. Does anybody have specs or anything that would help point me in the right direction? TIA
  2. DrFeelGood
    DrFeelGood Karting
    Feb 4, 2014
    55
    Seems like everything available online is AGM but I read on this forum that AGM is for HELE cars which mine is not.
  3. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
  4. Rule12b
    Rule12b Karting
    Jun 4, 2018
    102
    Richard
    I put a Braille in my Cali T last month. No issues. There is a great write up on another thread. . .
  5. Stercrazy
    Stercrazy Karting
    Sep 29, 2017
    115
    NC and FL
    Paul Winchester
    I have a 2011. I installed an Interstate MTP-49/H8 last year. no problems
  6. Randy R
    Randy R Formula Junior
    351
    SF Bay Area
    '14 Cal 30 TDF/Tan
  7. DrFeelGood
    DrFeelGood Karting
    Feb 4, 2014
    55
    Thank you!
  8. Stercrazy
    Stercrazy Karting
    Sep 29, 2017
    115
    NC and FL
    Paul Winchester
    I second that CTEK recommendation. OEM unit is useful as a paper weight maybe.
  9. tomc
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    Yup. Ctek 7002 for me. Bought it 3 years ago. Totally happy with it.
    T
  10. Joshman0531
    Joshman0531 Formula Junior
    866
    Tennessee
    Joshua Seidenberg
    I am having one installed this week and I'll post a pic of what it is shortly
  11. Il Co-Pilota
    Il Co-Pilota F1 Veteran
    May 29, 2019
    6,023
    Hopefully some place nice.
    A.B
    #11 Il Co-Pilota, Apr 9, 2020
  12. HollywoodRich
    HollywoodRich Rookie
    Jul 18, 2021
    19
    Los Angeles
    Richard Rosen
    Connect the Ctek directly to the battery? Not the adapter in the trunk?
  13. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    118
    California
    John McCoy
    Yes, install directly onto the battery! A brand new Interstate installed by the Ferrari dealer and ALWAYS on the factory trunk charger lasted only a year for me. So far, so good with the charger mounted directly to the battery. Every month that passes with a perfect battery is a success, and I was waiting to post my HOW TO series about installing an Optima yellow top in a California, along with a cut out switch and direct battery charger, until more time has passed, but I could do that any time with lots of photos, if FERRARICHAT readers want to see it now.
  14. JohnInItaly
    JohnInItaly Karting
    Feb 5, 2019
    118
    California
    John McCoy
    Living with our beloved cars requires some experimentation. Looking forward to Ferrari Club drives with friends and then missing them when the car won't start that morning is a real bummer, and I vowed to find a permanent solution. Maybe the JuiceMyRide will work or maybe it won't. The reading that I have done suggests that the long distance between the trunk and the battery up front is part of the problem, and no one seems to know it the battery connection is direct or if it goes through other electrical components in the system somewhere. The car's computer always draws against the battery, but it draws less when the alarm system is ON because other functions are then shut off, I learned. I now set the alarm even in my high security storage facility, just to help the battery. But zero draw means no battery loss, and I installed an old fashioned $20 1950's bronze battery disconnect for when I return to Italy for months at a time, and the big Optima charger keeps the battery at 100%. The Optima charger cord is connected to the battery before the disconnect switch. When I return and reconnect the battery, I only have to reset the clock, although there can be peculiarities like the gas cap button doesn't work until I have driven the car for some minutes, and I cannot explain that one. There have been no other ill effects with the battery disconnect switch, despite some people saying that you have to go back to the dealer to reboot your computer, etc, which is not true on my car. My California will be at Concorso in Monterey and various other 2021 Car Week events, if you want to see the modification in person.
