What have you done to your Ferrari Today? | Page 131 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. Schulz308
    Schulz308 Formula 3 Rossa Subscribed
    May 21, 2014
    1,506
    STL USA
    Du_Man and Dane like this.
  2. Schulz308
    May 21, 2014
    1,506
    STL USA
    Seals are toast, causing that sinking pedal at a stop.
    Dane likes this.
  3. bitsobrits
    bitsobrits Formula Junior Rossa Subscribed Silver Subscribed
    Nov 12, 2011
    748
    Omaha, NE area, US
    Steve
    Am curious what is the MC bore diameter?
  4. Schulz308
    May 21, 2014
    1,506
    STL USA
    Rebuild completed, easy job. Replaced the old brittle terminals also.
    I did not read your question about bore diameter before assembly but the kit is from AW Italian FER 95696969 29/32" try referencing that.
    Dane, SMS and colorfull like this.
  5. bitsobrits
    Nov 12, 2011
    748
    Omaha, NE area, US
    Steve
    Sounds like 29/32" to me! Thanks.
    Schulz308 likes this.
  6. SMS
    SMS F1 Veteran
    Jan 7, 2004
    6,775
    Indy
    Bill S.
    Dane likes this.
  7. kent holden
    kent holden Rookie
    Nov 24, 2017
    9
    Indianapolis
    Kent S Holden
    The wheels look Beautiful. any issues with clearance? I love the euro bumpers as well, can you provide any information on those?
  8. david bentley
    david bentley Karting
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
  9. jr-f12-15
    jr-f12-15 Karting Rossa Subscribed
    Feb 2, 2020
    72
    Tomball, TX
    John Refalo
    Only thing I did is take them for a long drive.
    New to the Tomball area.
  10. david bentley
    Jan 2, 2004
    182
    Saint Louis Mo US
    David bentley
    When I got our 308,, someone had drilled a 1/16 dia hole in the cover hinges....line up the hole and tighten the bolts and the cover is in alignment!
    ragtop1 likes this.
  11. ragtop1
    ragtop1 F1 Veteran Silver Subscribed
    Nov 11, 2006
    5,242
    Ontario
    Larry Warren
    Great idea, or outline the lid hinge with a sharpie.
  12. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,150
    SanFrancisco BayArea
    1983 US 308 GTS QV
    What I did to my Ferrari today was take it out for its first drive in 2023.
    Dane, Milkshaker0007, ragtop1 and 2 others like this.
  13. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    snap, just come back in from a nice dry day drive in the UK for a month or so here.
    Throughly enjoyed myself happy new year guys and girls
  14. dyerhaus
    dyerhaus Formula Junior Owner Silver Subscribed
    Nov 4, 2012
    898
    Santa Rosa, California
    Christopher Dyer
    Today I decided I’d remove the stereo from my 1975 Dino 308 GT4 and take it in for repair at a place that fixes vintage car stereos. It works, other than the cassette player—cassettes won’t stay in. It's a Blaupunkt Bamberg US, so it's a dictaphone and it would be nice to be able to actually use it as intended. A fun feature and is original to the car (installed by the dealer).
    That turned out to be more of an adventure than it should have been!
    Turns out, there’s two big cables that come out of the back of the head unit and don’t have any visible spot at which they disconnect.
    The big black and gray cables are the ones in question.
    I don’t know how much any of you know about car stereos, but usually (even in old cars) accessories plug into the stereo head unit, thus you can take the head unit out and get a new one or get it serviced without taking the entire system out.
    That is not the case with this system!
    Turns out, the stereo head unit plugs into the accessories (exactly backwards from anything normal or conventional). Thus, you have to remove all of it in order to get the head unit out.
    On top of that, the amp was hidden behind a wall in the passenger footwell and there was a pre-stripped screw in the worst possible location.
    colorfull likes this.
  15. jpl
    jpl Formula Junior
    Dec 4, 2003
    368
    Yulee Florida
    JP Lavigne
    Out for a drive in my new home of Yulee Florida and 24865 just turned over 86K miles!
  16. bitsobrits
    Nov 12, 2011
    748
    Omaha, NE area, US
    Steve
    Car is sitting on the arms of the MaxJax lift, btw. Keeping it low and off the suspension helped the engine extraction process as I don't have a high ceiling in my shop.
    thorn, Dane, Rosey and 2 others like this.
  17. Miklas
    Miklas Karting
    Dec 10, 2018
    84
    Luxembourg
    Nice engine stand. So what height is your garage then? I'm asking because at some point I will have to pull the engine and my garage ceiling is only 205 centimeters (so that might be a struggle).
  18. bitsobrits
    Nov 12, 2011
    748
    Omaha, NE area, US
    Steve
    205 may be near impossible, depending on your lifting equipment.
    My ceiling height is 8'1" which is about 246cm. With help from miked on another post (https://tinyurl.com/4dy8p82c) I determined I needed a minimum of 30" (76cm) of lift to clear the rear bulkhead of the car using a lifting strap around the forward cylinder head. Which is why I have the car sitting as low as possible, without wheels, so the suspension springs are out of the equation. (otherwise the body will lift as the engine is hoisted). Sitting as it is, the bulkhead height on my car was 32" (81cm) so I needed a lifting apparatus that could function in the remaining space. I used an 8' tall gantry crane which has the lifting hook 15" below the top of the crane at max lift, which gave me a useful 49" of lifting range.
    My engine stand btw is essentially a copy of one I saw on one of the threads on this forum.
    This forum is awesome!
    cavlino and Dockboy like this.
  19. ChevyDave
    ChevyDave Formula Junior
    Dec 21, 2019
    420
    Pacific Northwest, USA
    Dave W
    Looked at the weather report. Again.
    I had resolved to make weekly “calisthenics”runs this winter to keep everything limber, but it’s now rained every day for the last three weeks. Ugh. :(
    Fingers crossed today’s the day.
  20. 308gts79
    308gts79 Formula Junior
    Mar 20, 2007
    783
    San Francisco/Hong K
    Completed a proof of concept project: hand-built carbon fiber engine lid, weight reduction from 60 to 15 pounds, better handling on mountain roads, car runs cooler as cut-open air-box area provides more venting, plexiglass air-box cover removed for visible carburetor photo, keeping the original lid, all bolt-on easily reversible for show.
    cavlino likes this.
  21. Kingswood
    Kingswood Karting
    May 16, 2022
    148
    Stew
    Finished up all suspension, hubs, and steering on my project GT4.
    Finished up a complete brake system rebuild. Booster, master cylinder, callipers, etc. Lots of missing parts I needed to source. And yes, that handbrake equaliser is not factory, I had to make one as the car was missing it.
    This is how I received it.
    Also wrapped up a clutch replacement (thank you Birdman), on a freshly machined flywheel, and a freshly rebuilt starter.
    absostone, Saabguy, Harry-SZ and 4 others like this.
  22. lm2504me
    lm2504me Formula 3 Silver Subscribed
    Aug 26, 2004
    1,122
    Nipomo, CA
    Richard
    cavlino, Jbrauer and RodC328gts like this.
  23. classicalfas
    classicalfas Formula Junior Silver Subscribed
    Dec 5, 2012
    318
    Gardiner, NY
    Peter D
  24. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    JuLiTrO, Dane, ragtop1 and 2 others like this.
  25. Kent Dellenbusch
    Kent Dellenbusch Formula Junior Silver Subscribed
    Oct 7, 2008
    664
    Upland, CA
    Kent Dellenbusch
    I have to make one of these gatherings one day. Good for you Barry.
