What have you done to your Ferrari Today? | Page 141 | FerrariChat
Discussion in '308/328' started by SteveGTB, Feb 5, 2014.
  1. E-Dino
    E-Dino Formula Junior
    Aug 11, 2012
    378
    San Diego
    Dino was down for a little over a year and a half, so long enough to be screwed by the CA gas. I tried to wake it gently with a slug of fuel treatment in the carbs, but one float stuck open, and I did a "dead-head" crank with #2 cylinder full of gas! I freaked out for a while, did a compression test and all seems ok. So now it is a complete rebuild of all 4 carbs. The belts are 8 years old, so it is also time for new ones and tensioners. Coolant flush (maybe rad out and cleaned), new brake fluid, oil, plugs, alt belt. The snowball may include water pump and thermostat. It was cooling just fine, but you know how this "while you are at it" goes. Then there is the oil leaks, do I chase a few of those down? So that means cam covers come off. Should I check valve lash? What else am I forgetting, oh yea, I want to prep for an AC project next summer, so I want to figure out the best compressor bracket. I will go after the fuel lines when I drop the tank for the AC lines. I think that is it until I look at it again :rolleyes:
    Your bumpers are awesome so let me know if you want to build and sell me another set :)
    Edit: Holy crap, it was almost 2 years to the day since it was last driven. I went back and here is it's last photo running...
  2. Kingswood
    Kingswood Karting
    May 16, 2022
    148
    Stew
    As I am in Australia, the freight would be a killer.
  3. E-Dino
    Aug 11, 2012
    378
    San Diego
    Yeah, that makes it tough. Oh well, if you get a chance and want to post some pictures of what you did I would be interested. :D
  4. E-Dino
    Aug 11, 2012
    378
    San Diego
    doggydoggen and 85QVEuro like this.
  5. Frisky
    Frisky Karting
    Apr 26, 2014
    230
    MA
    Rolfe Lofmark
    Did you win a medal at Lake Placid?
  6. TheMayor
    TheMayor Ten Time F1 World Champ Rossa Subscribed
    Feb 11, 2008
    106,183
    Vegas baby
  7. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,007
    Simon Ashley
    Ultrasonic cleaner is what you need, makes the job easy and fume free
    miketuason and bitsobrits like this.
  8. E-Dino
    Aug 11, 2012
    378
    San Diego
    Man I am getting old...I forgot but I think I have a small ultrasonic cleaners that I will use for the little bits. I don't want to dip the whole carb because I don't want to get into the throttle shaft and bearings. I am not sure if the dip will hurt those parts, but at this point I don't want to risk it.
    Ha ha, no medal here. But my Dad did give me that mug back in 1980 and I keep it around because it makes me think of him.
    Frisky likes this.
  9. bitsobrits
    bitsobrits Formula Junior Rossa Subscribed Silver Subscribed
    Nov 12, 2011
    746
    Omaha, NE area, US
    Steve
    I used an ultra sonic cleaner on my carbs. Then splashed the bearings with acetone (absorbs water, evaporates quickly), then ACF50, then re-greased the bearings.
    E-Dino likes this.
  10. Jonny Law
    Jonny Law F1 Rookie Silver Subscribed
    May 6, 2008
    3,203
    Over yonder.
    IT Guy
    The ultra sonic cleaners on Amazon are very affordable these days.
  11. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    78 GTS us
    Got tired of dealing with the stock fuse blocks. I tried every trick including soldering the "rivets". Still had problems with the fuses losing contact. Especially on "spirited" drives on not so smooth roads. It would have been easier to just buy one of the blade after market blocks but what fun is that. I found 6 fuse blocks with no common along with necessary adapters. Total cost for parts about $85.00 Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login .
    I cut the blocks down as much as I could and glued the removal backs to a fiberglass backing plate. It ended up being one long array of fuses that use the stock mounting bolts and locations. I cut the clear plastic covers that came with the new fuse blocks and glued them together then printed labels that mimic the stock ones. the plastic cover snaps on like the stock one. Took it out on a hard drive last sat and all is good. With AC and fans running for over an hour the fuses weren't even warm. It may be my imagination but I swear the after market fans I using for radiator cooling run faster.
    chas-3, ragtop1, E-Dino and 2 others like this.
  12. Snaponjackson
    Snaponjackson Formula Junior Rossa Subscribed Silver Subscribed
    Sep 19, 2018
    529
    INDIANAPOLIS INDIANA USA
    Chris Jackson
    Very clean and professional looking work!
    waymar likes this.
  13. bl10
    bl10 Formula Junior
    Jun 8, 2011
    442
    Chatsworth, CA
    Barry Leavengood
    Thanks. It was a fun project
  14. Albert-LP
    Albert-LP F1 Veteran Owner Rossa Subscribed
    Sep 1, 2010
    8,175
    around Modena, Italy
    Alberto Mantovani
    Rosey and E-Dino like this.
  15. Sigmacars
    Sigmacars Formula 3 Silver Subscribed
    Jul 19, 2006
    1,218
    ragtop1, pilotoCS, rwbolt1 and 3 others like this.
  16. Schulz308
    Schulz308 Formula 3 Rossa Subscribed
    May 21, 2014
    1,506
    STL USA
    Lots of nice tasteful mods in that 328! Well done.
  17. Sigmacars
    Jul 19, 2006
    1,218
    Thank you the hardest job was to remove and recover the existing leather from the headrest
  18. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    Finally got to the bottom of my gearbox leak, turns out the thread on the filler section of the gearbox has got cross threaded/ stretched over time after having many oil changes in its life, so had to tap a new 22mm 1.5 pitch thread into the whole length of the casing, not just the first half.
    You can see the bad thread at the front, and the un used GOOD thread at the rear
    Superformance do an updated longer length of bolt (Hills engineering)for this exact situation 36mm length, so now bone dry with zero leaks, with another crush washer installed as you can’t tell by picture
    Glad that went OK , as there was no other option.
    kestrou and Portofino like this.
  19. Sigmacars
    Jul 19, 2006
    1,218
    Nice Job how did you get the cutting chips out of the gearbox the can’t stay in there and float around
    Milkshaker0007 likes this.
  20. newark_308
    newark_308 Karting Silver Subscribed
    Jul 28, 2004
    213
    Newark DE
    Glenn Frenck
    ragtop1, Rosey and waymar like this.
  21. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Good job mate. :)
    moysiuan and Milkshaker0007 like this.
  22. PAP 348
    Dec 10, 2005
    100,220
    Pap
  23. dino1971
    dino1971 Karting Silver Subscribed
    Sep 24, 2013
    156
    Bordeaux, France
    Dario
    Is that a CO2 laser? sure beats my grinder...
    Favoloso!
  24. Zenobie
    Zenobie Formula Junior
    Feb 22, 2021
    251
    Belgium
    CO
    Replaced rubber flap around fuel filler cap because ori showed cracks. Had to make the new flap slightly smaller as it is slightly thicker than ori
    PAP 348, TheMayor and Rosey like this.
  25. Milkshaker0007
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    No started yet but just ordered some new CV boots to fit after reading the birdman’s write up and Dave’s comprehensive write up, as mine is slightly leaky but not split yet.
