what makes the wisteling noise on 355 warm up.
Discussion in '348/355' started by chaa, Feb 26, 2004.
  1. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I have noticed on all the 355 that i have seen, that during the first min of cold start warm up, a wisteling noise comes from the engine then exactly two mins later it stops. I was told that it makes this noise during warm up, to let you know that its warming up.is this right and what makes it?
  3. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    auxiliary cooling fan?
    doody.
  4. ty (360mode)
    ty (360mode) Formula Junior
    Sep 25, 2002
    807
    Houston
    Tim
    i'm curious about this too as my 355 did the same thing.
  5. VS1
    VS1 Karting
    Oct 16, 2002
    197
    Beavercreek, OH
    Vishal Soin
    I've noticed the exact same thing. So, I'm intereted in finding out what it is as well...............................V
  6. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    If its the same as the 360 (which seems likely) its the "secondary air system". Essetially a fan etc system that warms up the cats more quickly that they otherwise would.
    It might also be the "power steering issue" - mine is very noisy for the first couple of minutes when its really cold. This is a very different noise to the secondary air which happens all the time hot or cold weather.
  8. ferrari355gtb
    ferrari355gtb Formula 3
    Nov 3, 2003
    1,600
    R
    Cold air injection for cold starting (similar effect to a choke ???). Mine hadn't been working for a while (blown fuse) now mended and cold starting and running is a lot better.
  9. dan360
    dan360 F1 Rookie
    Feb 18, 2003
    2,669
    Boston
    #7 dan360, Feb 26, 2004
    More tech detail on the 360 version attached in a pic. NB if you're on owners.ferrari.com you can download a pdf manual which is cool for these questions. Pretty much every ferrari since the 250 series.
    On final interesting detail. Failures with the check process described below were one of the primary causes of the check engine light on 360s until they updated the ECUs.
  10. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    It is the electric air pump that runs until the cats have been warmed up.
  11. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    Nice one dudes, Ta very much.
  13. notoboy
    notoboy F1 Rookie
    Jul 8, 2003
    2,531
    NYC
    David
    Been wondering the answer to that question for 4 years now...
  14. chaa
    chaa F1 Veteran
    Mar 21, 2003
    5,058
    I have a strange feeling that many have thought about asking that question...... but were afraid to in case it was expensive to put right. HA! HA! F***ing Ferraris.
  15. David_S
    David_S F1 World Champ
    11,083
    Mountains of WNC...
    David S.
    It's just your neighbors as they're thinking "Man, I wish I had a sweet ride like that!" :)
  16. tifosi69
    tifosi69 Formula 3
    Dec 23, 2003
    1,671
    Atlanta, Ga.
    Al-Al Cool J
    I agree. LOL
