What to Coat Garage Floors With? | Page 2 | FerrariChat
Discussion in 'Detailing & Showroom' started by arachnyd, Apr 5, 2018.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Well, there is truth to that but you need to consider the functionality. Those dual scissors take up a lot of room when up and they will also be under the car getting in the way as a 2 post has the posts outside the car area. You could always do a in-floor 2 post ;)
    WATSON likes this.
  2. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,950
    Weston, FL
    Scott
    I’m in the process of installing an epoxy floor myself and am pretty much already following the guidance you posted. However, I was not aware that I should scrape off the excess flake before putting on the top coat. How do you recommended I go about scraping off the excess? What can I use?
    Thanks,
    Scott
  3. LBBP
    LBBP Formula Junior
    I think you are just removing the excess by sweeping the floor once dry, at least that's what i recall when i considered doing an epoxy floor myself. There should be DIY videos on epoxy floor explaining the process.
  4. Shaun Oriold1
    Shaun Oriold1 Karting
    Mar 21, 2008
    206
    Burlington, Ontario. Canada
    shaun
    Home Depot sells a 16" metal scraper. I'm not sure what its intended application is, but that what we use. Scrape over the floor in both directions. The purpose of this is to knock down any flake which ended up falling on its edge. You can also use a floor buffer, but I think it leaves the floor too smooth, and way too slippery when wet. Make sure to vacuum once scraped flat.
    Shaun
  5. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,950
    Weston, FL
    Scott
    Thanks!
    Scott
  6. toparkt
    toparkt Formula Junior
    762
    orange county
    Andrew Goetz
    Kretus epoxy
