430 - What was the solution about exhaust back brackets/mounts? | Page 3 | FerrariChat
430 What was the solution about exhaust back brackets/mounts?
Discussion in '360/430' started by Themaven, Nov 2, 2020.
  1. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,586
    San Jose
    dc
    Not sure if called out yet but the Ferrari sports exhaust (Tubi) has a rubber hanger system. So swapping to that should be an improvement.
    I have the stock exhaust and followed the recommendation in post #5.
  2. RedTaxi
    RedTaxi F1 Rookie
    3,310
    New Zealand
    Glen
    When the lower brackets crack/fail the exhaust does not sag at all. The 360 does not have these brackets and has a heavier system than the 430 and has way less header issues. If you really want to destroy your headers, weld those cracked brackets up good and strong. If not, bin them.
  3. Themaven
    Themaven F1 Rookie
    Nov 2, 2014
    4,361
    Eastdown
    Darius
    Mine is an 05 and it has the mk2 manifolds fitted as a recall under a previous owner. Everything else is standard.
    I’m getting convinced by the Capristo spring loaded. It’s a good point that doing nothing is a choice. I like the sound of the exhaust as it is so would be reluctant to get a new exhaust.
  4. SingleClutch
    SingleClutch Karting
    Apr 19, 2019
    120
    Seattle
    Kris
    He purchased the car almost two years ago, and I believe the dealer had replaced (upgraded) the manifolds, but I’m not certain if that. No idea about the brackets. It is what it is though - he’s definitely replacing the motor.
    Fly fast and take chances
  5. Danedingerson
    Danedingerson Karting
    Dec 26, 2011
    236
    Maui
    Dane
    Does anyone know of an owner having an issue caused by leaving the brackets off? My dealer says no, but that is because Ferrari never properly looked into researching that issue. They don't suggest Capristos either, just factory brackets. I have the factory warranty on my 2007
    , so am limited about changes.
