What's the best solution to my 348 seatbelt issue.. | Page 2 | FerrariChat
Discussion in '348/355' started by livingthedream, Jul 11, 2005.
  1. sparta49
    sparta49 F1 Veteran Owner
    Mar 3, 2001
    7,804
    LA
    Frank
    The new thread needs to be a stickey
  2. livingthedream
    livingthedream Karting
    Jun 3, 2005
    56
    San Francisco, CA
    Jonathon
    I was not told which 348's/years/VIN's are covered. It was only explained to me that if the dealer simply runs your VIN, chances are it won't show any recalls pending. But, when they specifically asked Ferrari N. America what the story was, the recall was active. So, if you're having your local dealer inquire, make sure they do a bit mroe investigating and less blowing you off. I'm still pissed at how I was treated by FoSV. Clearly they have better things to do than have me as a customer.
  3. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    The thread has started....anyone with seatbelt problems with VINs not under recall post them here....
    http://www.ferrarichat.com/forum/showthread.php?t=66917
  4. Houston348
    Houston348 Formula 3
    Oct 18, 2006
    2,297
    is this the easiest and best way to get the lights to go out... it looks to me like it is.
    I'm going to disconnect the black boxes under each seat to stop the seatbelt from moving. i would much rather have the seatbelt connector stay back at the seat and not up at the front, but i need to figure out a way to do that
    i have also seen that i can disconnect the black boxes under the center console, but that seems like more work that what is mentioned above to solve my problemo.
    thoughts?
  5. Houston348
    Oct 18, 2006
    2,297
    disregard the last post, i found a thread that recently described this!
  6. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Open your passenger door. Lay yourself on the floor on that side facing the center console.
    You'll see two phillips screws holding one "side" panel upright. Remove those, then lift out that side panel. Now you'll be facing your two black seatbelt boxes.
    Open/close doors as required to move each seatbelt mouse to your desired position, then unplug the black boxes.
    Put your upright console panel back.
    Done.
    20 minutes. 1 tool, a phillips screwdriver.
  7. Houston348
    Oct 18, 2006
    2,297
    ok, you lost me at "open your passenger door" haha. j/k.
    that sounds like a pretty easy quick fix.. love it!. all i need to do is find a Ferrari compatible screwdriver that has had its major done on it lol
  8. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    A two-inch long piece of black electrical tape should solve your seatbelt light problem. Looks stock too!
  9. Houston348
    Oct 18, 2006
    2,297
    how about magic marker??, or would that look too "after market"
  10. Houston348
    Oct 18, 2006
    2,297
    you were waaaayyyyyyyy off!
    1. there were THREE screws, not TWO
    2. it took 5 min, not 20!
    geeeezz! lol
    ahhhhh, to be free of the mouse.... pure bliss! thanks again!!!!!!
  11. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
  12. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Hey I like those little buggers! ~O8>
  13. john a barnes
    john a barnes Formula Junior Silver Subscribed
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    My left side 348 spyder belt gave up in 2019. I'll see if that recall is still valid. Parts are not in stock. Seat belt module appears to be next to parking brake. Car is mothballed for now.
  14. Wade
    Wade Three Time F1 World Champ Owner
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    You couldn't find a similar thread newer than 2008?
  15. john a barnes
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    This website is the best if I could find a way to navigate easier.
  16. steved033
    steved033 F1 World Champ Owner Silver Subscribed
    Apr 12, 2017
    10,471
    Atlanta, GA
    Steve D.
  17. john a barnes
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    Hey, thanx,Steve. Bunch of threads.
  18. A348W
    A348W Formula 3
    Jun 28, 2017
    1,864
    North Wiltshire, UK
    There are companies that will put new belts in for you.
    mine are going off next winter for new belt material; might go dark blue to match the exterior!
  19. john a barnes
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    No, no I have a L. side motorized mouse inop. Algar Ferrari shows it's not available any more. More research to do.
  20. f355spider
    f355spider F1 World Champ Owner Rossa Subscribed
    May 29, 2001
    18,059
  21. john a barnes
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    Hi Hugh. Nice Handle. Unusual full name. Yeah I found that. After 15 years its gone deleted. But I did find it from an old thread. No Ferrari garage nearby. So, I've got to take it up with Lake Forest , Chicago in the spring. I'll dig into it further myself in Spring. Car is mothballed(really) for now. What gets me , is that there is an electronic box involved. All that I see could have been done(engineered) with Limit switches and Limit relays, if you know what I mean. Throw in a cheap module made in Singapore or what have you and it's doomed. Just like a GM product.
  22. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,605
    Ian Riddell
    Usually there are second hand parts for sale, but there may be a broken microswitch or something simple causing the system not to work. What year is your car?
    There are two computers. Have you tried swapping them over?
  23. john a barnes
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    Hi Ian, Yeah thats next. I was researching before I got back to the car in a couple months. If I had a wiring diagram for 94-95 348 spider I could probably tell what the big picture is. It's only spider and SS near as I can tell. Seat belt wiring diagram would go a long way I think. I fix cars for a living.
  24. Qavion
    Feb 20, 2015
    14,605
    Ian Riddell
    I have been working on a wiring diagram, but needed a few more details of the plugs and the internal microswitches (I don't have a 348). Anyway, here's my latest theoretical diagram for the GTB/GTS based on some feedback from owners:
    F348GTB&GTS_Passive_Type_Seat_Belt_Wiring_Diagram
    If you're willing to do some wiring checks for me, we may be able to get a complete diagram.
    The system is quite complex and probably does need a computer to handle everything (including a vehicle speed input).
    Common faults: Depending on the symptoms, I would check door microswitch (lower one), microswitches at the end of the tracks, motor operation (using direct 12volts), etc. At At least with one good system, you can compare the two sides.
    john a barnes likes this.
  25. john a barnes
    Dec 19, 2018
    273
    muskego wi
    John a Barnes
    Hey Ian, good stuff. Where the hell did you come up with that? I see the magic boxes are made by Autoliv.. They are the makers of the best Airbags for years. Anyway, I see that motor is powered by that. Probably controlled by a reversing DC H-gate or such. That is really what I was curious about. Now I've got the big picture. I see you found a different part#. That's news to me also. I don't see what purpose VSS input would serve. That was a '90's thing for SCV at first. These didn't even come with radios. Right now it's 15 degrees outside and you probably have 85. I've got a heated shop but the car is packaged up off premises right now. It's gonna be a few months until winter is over. Oh well. The downside to analog cars is every thing has to be tested without chasing my tail. Can-Bus with a scanner made this type of stuff a lot easier as the years went on. Operation in real time. Bi-directional stuff etc. Thanks much and have fun.
    Qavion likes this.
