News
430 When to use a battery tender?
Discussion in '360/430' started by azzurribaggio, Jun 14, 2019.
  1. azzurribaggio
    azzurribaggio Formula Junior
    New owner here guys, when should one hook up a battery tender? My car currently does have one, does one hook up tender if the car won't be driven for like two weeks? OR do I need to hook one up all the time?
  2. flash32
    flash32 Formula 3
    Aug 22, 2008
    1,311
    Central NJ
    Dominick
    It is good practice and to keep your battery in top condition to basically come back from a drive and hook up to tender
    Sent from my moto g(7) using Tapatalk
    LP360, Tamahal, vinny84 and 3 others like this.
  3. mike32
    mike32 Formula 3
    May 13, 2016
    2,249
    Uk
    You will get to know how long it takes for the battery to go down, cars in the US dont have trackers so less drain on the battery. Some people have tenders on all the time, mine is connected via a timer and comes on every 2 days. Just experiment till you get it right
    whatheheck likes this.
  4. Korr
    Korr F1 World Champ
    14,835
    SiO2
    If it's an actual battery tender and not a dumb type trickle charger, leave it plugged in all the time. It'll only supply juice when the battery needs it and won't overcharge it. It's simple insurance vs the royal PITA of jumping or charging a flat battery.
    Walt Gamble and E60 M5 like this.
  5. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    6,351
    Wash DC area
    Robert
    As others have said, plug it in every time the car is parked at home, not in use.
  6. BlacktopRacing
    BlacktopRacing Formula Junior
    685
    Dale
    I normally start and/or drive my F430 every weekend, so I've only been hooking my battery tender up if I won't be able to one weekend. That said, I like mike32's timer idea, although I'm thinking 12 hours every day.
  7. ShadowLAP
    ShadowLAP Formula Junior
    May 15, 2017
    279
    SW Suburbs of Chicago, IL
    Lawrence P.
    I keep my 360 Spider on the battery maintainer when not driving it. Since I have maintainers for all of my 'toy' cars, why not use them and get the benefit and piece of mind.
  8. Korr
    Korr F1 World Champ
    14,835
    SiO2
    You don't need a timer or anything. Get a tender that monitors your battery and only charges when it needs to. Plug it in and forget about it until you go for a drive.
  9. azzurribaggio
    Ok with that said anyone have any recommendations for a good battery tender?
    I was looking at this one on Amazon: CTEK
    4.7 out of 5 stars 558 Reviews
    CTEK (56-353) MULTI US 7002 12-Volt Battery Charger
    Sent from my Nexus 6P using FerrariChat.com mobile app
  10. flash32
    flash32 Formula 3
    Aug 22, 2008
    1,311
    Central NJ
    Dominick
    I have used the Ctek 40-206 mxs 5.0 and the granite digital (save a battery)
    Both served well
  11. Dicecal
    Dicecal Formula Junior
    657
    Phoenix, AZ
    Rob
    CTEKs are good, thats what I use. I have the CTEK plugged in whenever parked in the garage regardless of how much I drive it. These cars are very finicky with low voltages and electrical problems. For some reason, F cars have high electrical parasitic draw. Take a look at the 488 thread on parasitic draw... something Ferrari does not do well!
    vinny84 likes this.
  12. Kevin Rev'n
    Kevin Rev'n F1 World Champ
    Rossa Subscribed Owner
    Nov 29, 2009
    12,610
    Honolulu
    Kevin
    I am a fan of these guys. I am using the 12 Watt version now but have used the 50 Watt also. It looks nice in the garage with a wall mount and puts out a nice blue hue.
    https://www.batterysaver.com/
  13. mike32
    mike32 Formula 3
    May 13, 2016
    2,249
    Uk
    Yes and no to that- leaving a tender on for weeks is fine but does it give the battery a decent charge now and again or just float charge it- i use the timer so the battery discharges a good bit, then it gets a good few amps for a while. Trickle charging a battery for weeks just sulphates the plates, hence i lean towards the timer. We all have different opinions
  14. mike32
    mike32 Formula 3
    May 13, 2016
    2,249
    Uk
    If i remember correct a 430 should be about 30mA in the uk, bearing mind we have trackers fitted
  15. vinny84
    vinny84 Formula Junior
    306
    PA
    Vince
  16. Continental AutoSports
    Sponsor
    Aug 22, 2006
    2,727
    Hinsdale, IL
    Parts Department
    +1 to this. Full disclosure: we sell these at our dealership BUT we swear by them.
  17. Korr
    Korr F1 World Champ
    14,835
    SiO2
    Overcharging sulfates the battery depending on how much juice you pump into it. Battery tenders...good ones...do not overcharge because they stop charging when the battery is topped off. Trickle charging is not the same thing as a battery tender.
    Even a simple $25 battery tender by Battery Tender won't cook your battery. If you don't believe me, measure how much juice it's sucking out of the wall when the light is red. The one on my truck is pulling a whopping quarter amp out of the wall in charging mode. Take a guess at how much juice it is using while it is not charging. At this rate, it will sulfate the battery at about the same time Sol stops glowing in a visible manner.
    P.S. Have you rotated your cam belts lately?
  18. shad99
    shad99 Formula Junior
    269
    Japatul Valley, CA
    Andy
    +2 on Granite. I bought one three years ago based on recommendation of Brian Crall after my CTEK died. Very happy.
    Another reason to keep your battery on a tender is to avoid repeated charging with the car's alternator through the associated wire harness, which appears to have inadequate ampacity. A number of posts on this problem.
  19. BlacktopRacing
    685
    Dale
    #19 BlacktopRacing, Jun 14, 2019
    I already have one... it's the actual Battery Tender brand by Deltran. It's just a little inconvenient having to disconnect and reconnect it every time I drive the car.
  20. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,861
    Ontario, The Real One in Canada
    Lars!
    Noco Genius
    And more importantly, a good AGM battery like Odyssey. Made the biggest difference for me.
  21. ttforcefed
    ttforcefed F1 World Champ
    11,610
    i dont use tenders on my 430s anymore - just turn the battery off with the knob. tender is pointless. no fancy ECUs in that generation.
  22. whatheheck
    whatheheck F1 Rookie
    Silver Subscribed Owner
    Mar 27, 2006
    3,412
    Seattle, Wa
    Dan L.
    As others have said, its best to have a fully charged battery all the time as these cars are sensitive to voltage fluctuations.
    If you drive your car every weekend you wont need to hook it up to a tender.
    I've experimented. I go on a trip for 3 weeks, come back and my F430 starts right up.
    But like I said above a fully charged battery is always the best way to go.
    I too use the NOCO Genius. Works fantastic.
    Dan
    I'm 360 Canuck likes this.
  23. mike32
    mike32 Formula 3
    May 13, 2016
    2,249
    Uk
    Who is saying a tender will cook a battery ? Not me for sure and if you think a 430 has cam belts, you need new glasses mate
  24. I'm 360 Canuck
    Nov 21, 2015
    1,861
    Lars!
    Yup, I learned how sensitive they are last month in my thread about my 360. What looked like a repair of $1000’s, and time in the shop, seems to have been cleared with a new battery. Although I was good about keeping it on a tender, the tender was covering up a weak but not dead, battery.
    I’ve had a lot of cars, never seen one so greatly and weirdly affected by battery power as this.
    I’m too thrifty to have listened to others on here who replace their batts regularly every 3 years or so...but after this, I can see where they are coming from.
