Where to find Shell Helix | FerrariChat
Discussion in 'Technical Q&A' started by Rudolph, May 11, 2006.
  1. Rudolph
    Rudolph Rookie
    Jan 2, 2006
    3
    Diamond Bar
    Rudolph Gaytan
    This isn't a reply, but a plead for information:
    I am a 64 yo newbie to Ferrari ownership. I've searched for information about the subject, and perhaps I am searching incorrectly about the subject of oil availabilty.
    I purchased a triple black 03 360 F1 March of 06, with 5300 miles. I've driven it about 450 miles, and the dip stk marked oil at the end (below the lowest add mark) with the engine running and warm. Two things, did I check it correctly, and is it normal under "normal" use for it to be low at this mileage?
    I found a body shop in the Los Angeles outskirts whose owner said he had one qt and wanted $50. Clearly, I didn't buy it. I understand that the correct price is closer to $16. So I just parked the car for a couple of days until I could locate the oil.
    I decided to just have an oil service done (plus all fluids and belts), took a sample of the oil, and the service tech charged me the $16 per qt for four extra qt to have at home.
    Anyone know where to send the oil sample? I want to check for metal and pH and moisture.
    Anyone have a stock Ferrari Becker CD radio to sell?
    Thanks for any info. Rudy Gaytan [email protected]
  2. Wolfgang
    Wolfgang F1 World Champ
    Mar 8, 2003
    16,743
    Heidelberg, Germany
    Wolfgang
    Hello Rudolph,
    sorry, can`t help or answer your question; but I`m sure the SoCal gents will help you.
    Just wanted to say "HELLO" and a very warm welcome at ferrarichat.com.
    First post and already Rossa Subscribed and showing up with a serious tec. question. Thats the way!
    Enjoy your triple black 360 F1 (take care of NNO;)) and fchat.
    Best
    Wolfgang
  3. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
  4. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    First of all don't waste your money (or Engine) on Shell oil.
    Use Redline or Mobil 1 and you will be fine and it does not void your warranty.
    To check oil bring car up to operating temp and then shut off, check oil immediately after shutting off.
    it is normal for Ferrari's to use a little oil and I believe the owners manual says up to a quart every 500 miles but I wouldn't expect that much.
    Hope that helps
  5. speedball
    speedball Formula Junior
    Mar 29, 2004
    268
    Pasadena Area
    Scot Anderson
    I use Mobil 1 in my Maranello ....... next time you change oil, switch over ..... Shell is hard to get and way too expensive.
  6. Ronbo
    Ronbo Formula Junior
    Aug 2, 2005
    413
    Morris County, NJ
    Ron
    I just (today!) switched to Mobil 1 5W-40 from Shell. Half the price and no need to (a) buy from dealer or (b) buy in wholesale quantities from distributor. Four miles and no problems whatsoever. ;)
  7. f355spider
    f355spider F1 World Champ
    18,043
    Many on this list are using Mobil 1 0w-40. Works for me....I've never seen Mobil 1 5w-40...where are you guys getting that? I would think the 0w-40 would be preferred...but that's just my AEHass "brain washing" I have had....or should I say "re-education"? ;)
  8. MarkPDX
    MarkPDX F1 World Champ
    Apr 21, 2003
    15,111
    Gulf Coast
    Diverging slightly...... I usually get Mobil 1 at Wal Mart ($21 for a 5 quart jug) is there anyplace cheaper?
  9. Stew
    Stew Formula Junior
    Apr 16, 2006
    547
    Los Angeles
    I been using Shell Helix in my 325 for the last 5 years. My car runs great !
    You can get Helix in several places. One is at the Auto Gallery in Woodland Hills. The Helix is definately great stuff even though It is over-priced. Mobil 1 is certainly a good choice, but I must admit I like the Helix.
    Regards,
    Stew
  10. Stew
    Stew Formula Junior
    Apr 16, 2006
    547
    Los Angeles
    I meant 328... Tough day !!!
  11. f355spider
    18,043
    What weight?
  12. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    Shell Helix Ultra has the lowest flash point. Lower than even most of the 5W-20 wt. oils. This contributes to much higher levels of evaporation. The other 40 wt. oils have much higher flash points and probably less evaporation. This is why I shy away from the Shell oils. Also, they do not publish their actual Noack evaporative rates at all.
    The 5W-40 Helix Ultra has a flash point of 206 C whereas the 5W-20 Pennzoil plain multi-grade dino oil has a flash point of 229 C for example. Red Line 5W-20 has a flash point of 256 C. The evaporation is very very low with this oil.
    aehaas
  13. Rudolph
    Rudolph Rookie
    Jan 2, 2006
    3
    Diamond Bar
    Rudolph Gaytan
    Great responses. I appreciate it.
    During my futile search for the Shell Helix, I thought I would just get Mobil 1 to top off the needed liter. Several mechanics suggested I don't mix the oils.
    Since my 03 360 is just a few weeks old to me, and I couldn't verify the last oil change, I just had it changed and continued with Helix. I also didn't check the oil level the day I purchased it, so I cannot tell how many miles it was driven to consume that missing liter.
    My independent mechanic uses and recommends Shell Helix. Says it has certain hydraulic properties that the others don't have. I thought it wise to follow his suggestion, until I become better informed.
    Thanks for all the info and technical responses.
  14. sjvalin
    sjvalin Formula Junior
    Aug 31, 2004
    724
    Nevada County, CA
    Steve Valin
    If I recall from the 360 manual (I had a 2000), you are supposed to check the oil with the engine up to temp and running.
    -steve
  15. Ricambi America
    Sponsor Owner
  16. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    Ferrari Changed the procedure to up to temp and check immediately after you turn engine off.
  17. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    Nonsense on his part......
  18. Watry
    Watry Karting
    Aug 8, 2005
    78
    Berkeley, CA
    Andrew Watry
    I bought 5 gallons of Shell Spirax for my Alfas through the local Shell jobber. They delivered it free to my front door. Look online for Shell oil product distributors or in the yellow pages. They're everywhere.
    Andrew Watry
  19. DGS
    DGS Seven Time F1 World Champ
    71,590
    MidTN
    DGS
    On older cars, perhaps. But the newer models use the oil as hydraulic fluid in the self-adjusting valves. I've often wondered if some of the issues with early 355s weren't due to people replacing their 5W40 Helix with 20W50 oils, thinking "heavier is better".
    At one point, Helix 5W40 looked like a good all-year oil for my turbo Celica. Local Shell dealers lost the ability to speak English when I asked them about it. ;)
    I used to worry a lot about what oil to use. Then I discovered how often oil companies change the formulation of their oils. What's good today may be recalled tomorrow. It's a consumable. Be careful replacing mineral with full synth, and keep around the same grade, and don't lose sleep over it. (That's what the oil company chemists are paid for. ;))
  20. Gary(SF)
    Gary(SF) F1 Rookie
    Oct 13, 2003
    3,637
    Los Altos Hills, CA
    Gary B.
    My '05 F430 manual still says check with engine idling.
    Gary
  21. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    The procedure was changed for the 360
  22. AEHaas
    AEHaas Formula 3
    May 9, 2003
    1,465
    Osprey, Florida
    Ali E. Haas
    "But the newer models use the oil as hydraulic fluid in the self-adjusting valves."
    Oil use in "self adjusting valves" is viscosity independent. Ref: SAE Automative Handbook, current edition. This of course makes sense. A 5W-40 has a viscosity of approx. 100 (or more) at 75 F and 14 at 200 F and 3 cS at 300 F as in a hot racing engine. At cold temperatures the same oil will have a viscosity of 500 cS or more.
    aehaas
  23. speedball
    Mar 29, 2004
    268
    Pasadena Area
    Scot Anderson
    What's the (current) procedure on a 550?
  24. Sloan83qv
    Sloan83qv F1 Rookie
    2,537
    with BIG Dave M.
    Little Dave M.
    Either procedure can be used and you will get the a good reading, the 360 was modified I belive due to the foaming while running and thus it was hard to get a clear reading on the dip stick. The key with modified version is to check it immedately after shutting the engine off.
