Which cigarette light for 1971 Dino 246GT Euro | FerrariChat
Discussion in '206/246' started by HMB-Dino, Feb 21, 2011.
  1. HMB-Dino
    HMB-Dino Formula 3
    2,173
    Pebble Beach, CA
    RonG
    Re-Originals has (3) different NOS lighters, each a different length barrel; 50mm, 57mm and 67mm. These are not cheap ($240), so before I take the plunge I want to be sure I'm getting the correct one.
    Also, McCann has lighters for $145 doesn't indicate if they're repro's or what length. Anyone have experience with his Dino lighter?
    Since I don't have any in my car, does anyone know which is the correct length?
  2. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    #2 alhbln, Feb 21, 2011
  3. swift53
    swift53 F1 Veteran
    6,747
    E.S.
    Alberto
    #3 swift53, Feb 21, 2011
    Ron, this is the one I will use for my Dino/ most Alfa Romeo. As far as I know, they are all the same length.
    Possibly there existed longer ones for the Virginia Slims cigarettes of yore. I don't think it makes any difference, and as you can tell, if I measured properly, mine is 54.6mm.
    Under the console, you can fit any length. There is a ton of space.
    Part number wise, The "L" series is a different one from M & E series (same one).
    They often appear on e-bay. Or, get in touch with APE (Alfa Parts Exchange) (209) 365-1383 and ask SPECIFICALLY for an Alfa lighter for a GTV that works. Be very patient with Larry Sr. as he is well known for his temper.
    Regards, Alberto
  4. HMB-Dino
    HMB-Dino Formula 3
    2,173
    Pebble Beach, CA
    RonG
    #4 HMB-Dino, Feb 21, 2011
    There are (2) Dino lighters that have been on eBay for quite some time, however one is priced at $325 and the other ~$365...which is way more than the Re-Original's $240 (still steep for something I'd never use).
  5. swift53
    swift53 F1 Veteran
    6,747
    E.S.
    Alberto
    I agree, thus try APE, and better yet, buy a lighter that does not work...
    Regards, Alberto
  6. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    isn't this one those generic things that costs $5.00 to a Fiat owner, $25.00 for an Alfa Owner and $250.00 for Ferrari owner?
  7. dinogts
    dinogts Formula 3
    That should be pretty easy to do, whether you buy NEW or USED! ;)
  8. swift53
    swift53 F1 Veteran
    6,747
    E.S.
    Alberto
    They used to be a dime a dozen, unfortunately like everything, they are fading away...
    I bought mine in Italy for $100....+ airplane ticket. Good deal, no? ;-)
    Regards, Alberto
  9. dignini
    dignini Formula 3
    Aug 21, 2005
    1,348
    NJ
    Luigi Marazzi
    A good lunch and local wine in Italy, is worth all that!
    Blew 250 in a NY steak house a few weeks back.
    Now, its all gone..... you still have your cigarette lighter:)
  10. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Mine was INOP and I dug into it; good retraction, proper release and fairly clean sliding action - so what the heck is up with it?
    Pulling the DVM out I isolated the failure to the insulated contact at the end - there was no continuity from wiring connection to the positive post into the unit.
    Crazy...it looks like there never was contact as the connector was completely isolated within the white plastic and never made contact to the positive post.
    Now lubed, working great and a few cycles burned off the residual lube so ready to install
    Image Unavailable, Please Login View attachment 2844935
  11. swift53
    swift53 F1 Veteran
    6,747
    E.S.
    Alberto
    Regards, Alberto
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    You repair these - have you ever seen the end connector tab have zero continuity to the attaching post?
    SMH (Shake My Head) - blew me away and I started wondering how it ever could have worked...
  13. swift53
    swift53 F1 Veteran
    6,747
    E.S.
    Alberto
    Hello Scott, yes, I do repair them, nothing but refinishing.
    Never ran into issues, and I am a complete ZERO in electronics.
    Regards, Alberto
    synchro likes this.
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Well, just don't lubricate the push shaft and apply power unless you are in a well ventilated area as it literally smokes - LOL!
    swift53 likes this.
  15. swift53
    swift53 F1 Veteran
    6,747
    E.S.
    Alberto
    OK. Thanks for the advice :)
    Regards, Alberto
  16. christc
    christc Formula Junior
    Mar 3, 2013
    444
    Germany
    I still have one if someone is interested let me know. 150 plus postage. Can send photos upfront if interested.
    BR
    Christopher
  17. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,309
    brand new ones are available along w the paper wrapper.
