Which of these 360 parts are heaviest? | FerrariChat
Discussion in 'Technical Q&A' started by Brian C. Stradale, Jan 26, 2004.
  1. Brian C. Stradale
    Brian C. Stradale F1 Rookie
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Haven't gotten any input on this question in a thread in General... so, thought I might try the smart guys that hang out over here...
    Which of the parts below are the heaviest?
    Which are most likely to explain the 154lb difference between US and Euro models of 360?
    (The goal is to figure out what they are and swap them to the Euro equivalent!!)
    Core Engine - 182020 (Euro) vs 182024 (US)
    Ignition Control Unit - 178765 (Euro) vs 178784 (US)
    Depression Accumulation Tank - 177060 (Euro) vs 180315 (US)
    RH Float Valve - 171097 (Euro) vs 180381 (US)
    LH Float Valve - 171098 (Euro) vs 180383 (US)
    RH Fuel Tank - 175419 (Euro) vs 181338 (US)
    Union (Fuel Tank) - 180059 (non-catalyzed) vs 177638 (catalyzed)
    LH Valve with Pipe - 171132 (Euro) vs 180384 (US)
    RH Valve with Pipe - 171099 (Euro) vs 180382 (US)
    Fuel Vapor Filter - 174782 (Euro) vs 180132 (US)
    Pipe to Disareator - 175965 (Euro) vs 180373 (US)
    RH Catalyst - 174211 (catalyzed) vs 180082 (non-cat) vs 180019 (US)
    LH Catalyst - 174210 (catalyzed) vs 180083 (non-cat) vs 180020 (US)
    RH Outer Rear View Mirror - 65731910 (Euro) vs 65732010 (US)
    Front Bumper without light washers - 64861610 (Euro) vs 655005310 (US)
    Front Bumper with light washers - 65580710 (Euro) vs 65581110 (US)
    Rear Bumper - 64852810 (Euro) vs 64853710 (US)
    LH Safety Belts - 65408300 (Euro) vs 65802500 (US)
    RH Safety Belts - 65408200 (Euro) vs 65802400 (US)
    Instrument Board - 164290 (Euro) vs 177242 (US)
    Rear Fog Light Switch - 180712 (Euro) vs 180687 (US; dummy switch)
    AC Control Set - 65520500 (Euro) vs 65803000 (US)
    Rear Light Connecting Cables - 173429 (Euro) vs 173430 (US)
    Glass Lifting Electronics - 178708 (Euro) vs 178810 (US)
    Direction-Emergency Light Relay - 171798 (Euro) vs 171799 (US)
    Car Stereo - 168855 (Euro) vs 177783 (US)
    Anti-Theft Electrical Boards - fairly country specific, 182137 for US
    Tire Pressure Plates for different tires vary Euro vs US
    Optional Spare Wheel Kit is different Euro vs US
    Roof Panel Upholstery and Accessories are almost all different Euro vs. US
    All the headlight parts are different Euro vs US
  2. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    I would have thought that bumpers, door intrusion etc, and wiring componentry make up the most addition.
    Do you have glass windows instead of perspex etc??
    Floor mats in rubber?? VERY heavy
    and on and on
  3. Diablo
    Diablo Formula Junior
    No spare tire, get rid of that thing.
    The euro bumper is lighter, But remember it does not pass the MPH crash test. most Euro conversions have brackets made for this.
    Maybe you can call around and find a place that could help you out.
    Good Luck
  4. Brian C. Stradale
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    That list I have above are the only parts that have different part numbers US vs Euro. Thus, there is no extra door intrusion in a US 360 Modena. The bumper covers are different (different size license plates)... and maybe that part includes structure that is heavier... but nothing behind that part is different. The floor mats are the same US vs. Euro.
    Perspex or lexan windows are not a 360 Modena option... so that's not part of the 154lb difference.
    What wiring componentry are you referring to?
    Do you mean electrical wiring? Why would that be different in the US? And would it really be that heavy?
  5. Brian C. Stradale
    Mar 17, 2002
    3,603
    Dallas, TX, USA
    Okay, I thought I'd try this query one last time over here...
    Are there any Ferrari Parts Managers on this list?
    Or anybody with a Parts manual that shows weights?
    Even if just shipping weights?? (I realize those aren't too precise, but that would give me a ballpark idea; maybe an upper limit.)
    If anyone does have access to part weights, I would greatly appreciate it if you could provide the weights for any of the above parts have non-trivial weight.
    Alternatively, if anyone wants to give me access to the weight data, I'll peruse it and report back the weights myself.
    Thanks in advance!!
