Why wouldn't Ferrari use a carbon fiber tub for their cars? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by Dilusha, Oct 3, 2018.
  1. Dilusha
    Dilusha Formula Junior
    Dec 10, 2016
    769
    #1 Dilusha, Oct 3, 2018
    They did make them for the hypercars, why not for the smaller ones?
    Mclaren uses it for all of their cars.
    Why can't we do it?
    brianweekes likes this.
  2. miurasv
    miurasv F1 World Champ
    Nov 19, 2008
    10,039
    Cardiff, UK
    Steven Robertson
    F50 and Enzo also had carbon fiber tub.
  3. Dilusha
    Dec 10, 2016
    769
    But not for smaller cars? Conventional chassis are a bit too heavy for 2018.
  4. miurasv
    Nov 19, 2008
    10,039
    Cardiff, UK
    Steven Robertson
  5. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,508
    Lake Villa IL
    Jaguar36 and miurasv like this.
  6. Formula Uno
    Formula Uno F1 Veteran
    Oct 8, 2008
    6,659
    New York City
    OMG! I don't think anyone walked out of those wrecks besides maybe the Enzo
  7. maximilien
    maximilien Formula Junior
    Apr 27, 2005
    728
    Capitale of Europe
    Massimo
    It’s just for investment, cost and reparations mclaren produced 3000 car/year Ferrari 9000 car/year
  8. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    I read this once, but I don't know how true. That Carbon fiber maybe deteriorate over time compared to metal? They use it in aircraft so probably not true? Anyone think a carbon fiber aircraft would last as long as DC-3?
    LARRYH likes this.
  9. Robin
    Robin F1 Rookie
    Nov 1, 2003
    2,931
    Arlington, VA
    brianweekes and PaulK like this.
  10. Jaguar36
    Jaguar36 Formula Junior
    Nov 8, 2010
    841
    Cherry Hill, NJ
    That's certainly not true. If you look at any of the military aircraft that have been using composites for decades all of the corrosion and deterioration issues are on the metal parts. The composite parts have far fewer issues.
    While composites are great for large flat parts (like airplane skins) they don't make less and less sense as the parts get smaller and more 3-dimensional. The weight savings that would come from a CF tub are probably just not large enough compared with modern aluminum alloys to make it worth the headaches and cost for design and manufacturing. I suspect it is more of a marketing decision by the likes of Mclaren to use a CF tub rather than a true engineering decision.
  11. ago car nut
    5,267
    Madison Ohio
    David A.
    So what is the cost difference over carbon fiber versus aluminum or steel?
  12. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,508
    Lake Villa IL
    I think they don't do it because of cost.
    No direct experience but I've seen many reviews of newer convertible Ferrari with mention of noticeable cowl shake. Just as many mentioning the absence of such in the McLaren.
  13. red passion
    red passion Formula Junior
    Mar 4, 2012
    793
    Hockenheim, Germany
    The right material for the right type of car I suppose. The widening of the GT segment should give more as enough possibilities for aluminium application. Implementing major parts of carbon fibre in the bigger GT cars certainly is not the way to go. The current mid-engine platform has been around since 2009. Development on it has started well before. Amortization should be done now, so we might see a different approach in future. Also consider that investments in aluminium and alloy technologies does not forbid to use multi material layouts as Ferrari already stressed in latest presentation. Different materials for different cars are the right approach IMO.
  14. LARRYH
    LARRYH F1 Veteran
    9,171
    virginia usa
    Alfa uses it on the 4c .. but i wonder about the fatigue factor in regular cars where as metal can flex a little ....would a carbon fiber tub hold up 20 years and 100 k miles ? And if it cost more ?
  15. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,269
    Which are arguably Hyper Cars.
  16. Mitch Alsup
    Nov 4, 2003
    9,269
    The first warbird made with a CF structure (F117) was retired after less than a decade in service, compared to 30+ years for F15/F14.
    But these crafts are flown at the structural limits of the airframe and wings (more like race cars which are retired every season.)
    CF passenger airplanes go no where near their structural limits (20% maybe) so the CF will last a long time.
    CF is a lot like a white metal, if you use it at low enough structural forces it will last a very long time, but it will eventually fail.
    And unlike steel and aluminum you can't put Humpty back together again.
    Nicky_Santoro and kerrari like this.
  17. miurasv
    Nov 19, 2008
    10,039
    Cardiff, UK
    Steven Robertson
    Yes of course they are hyper cars, but the OP Dilusha edited his post after I responded. See the post I responded to in post 2 of this thread.
  18. Jaguar36
    Nov 8, 2010
    841
    Cherry Hill, NJ
    The F117 was not retired due to structural life limits on its airframe. It was also not the first to have structural composite parts. Many military aircraft designed in the late 70s used composites in varying degrees. The F-16 has carbon (graphite actually) fiber skins on its horizontal and vertical stabilizer. The F-15 has a boron fiber vertical stab. The F-18 uses composites for about 10% of its structure. Those aircraft are pushing 40 years old now.
    This is not true. Carbon fiber (and steel too actually) have an infinite fatigue life and low loads. The carbon fibers themselves actually have an infinite fatigue life at a load level very close to their ultimate load capability. Unfortunately the epoxy that makes up the matrix does not, and this is what eventually fails.
    Repair on composites is actually frequently substantially easier than on metals as well. A properly performed hot bond repair has similar structural capabilities to the factory material. However automotive shops don't have that capability yet. Many of the high strength aluminum alloys cannot be welded.
    Boomhauer likes this.
  19. PaulK
    PaulK F1 Rookie
    4,625
    Michigan
    Paul
    This is the real reason. End of discussion. ;)
  20. PAUL500
    PAUL500 F1 Rookie
    Jun 23, 2013
    3,136
    I watched a video on youtube recently of a Lambo having a factory repair to its composite tub, very basic process, pretty much an epoxy based sticking plaster.
    14 mins in
  21. G. Pepper
    G. Pepper Three Time F1 World Champ
    34,052
    Texas/Colorado
    George Pepper
    My BFF, who is brilliant with this stuff, says that CF can be as rigid or as flexible as you want, depending on the kind of resin you put the weave in. Anything from bow arms to tubs.
    I play CF classical guitars, and the back/side bowl is very rigid, but the top is not, so that it resonates well.
    One is a classical, the other a flamenco (The only difference is action height).
    Nospinzone likes this.
  22. markmoon
    markmoon Formula Junior
    Sep 5, 2010
    682
    Jacksonville, FL
    Mark
    I think cost is the main issue. I have 2 cars with CF tubs ( 2017 Alfa Romeo 4C coupe and 2018 Lamborghini Aventador S coupe).Both feel more rigid than my F12 coupe, but after visiting the Lamborghini factory and seeing the CF monocoque production process in person, I can see why it is apparently so expensive. The production process is incredibly labor intensive. I was told at Maserati in Modena ( where the 4C final assembly tales place) that the CF tub on the 4C was originally designed by Dallara and produced by the Adler Group. The CF tub alone supposedly costs close to $50,000.
    Another interesting fact about Lamborghini is that all Aventadors are hand painted/sprayed, while the Huracans are robotic sprayed like most Ferraris. Ferrari is charging my $63,000 on my hand sprayed paint job on my Tailor Made 812 Superfast. The Aventador looks like a bargain in many ways!!
  23. LightGuy
    LightGuy Three Time F1 World Champ
    39,957
    Texas
    David
    Ferrari currently has more customers than cars.
    If a few millionaires die in accidents that a CF tub could have prevented...well thats a risk they are willing to take.
    But potentially giving up a few bucks in pure profit. Now thats a different matter.
    A 60K Alfa 4C has a Carbon tub and a half million TDF does not.
    Laughable.
    Nicky_Santoro likes this.
  24. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,380
    Weston, MA
    Paul
    Here is a video of George trying to smash his CF guitar (he's the guy in the red shag boots). :D
    Nicky_Santoro, m5shiv and G. Pepper like this.
