Will non-catted exhaust fit a TR with a cat ? | FerrariChat
Discussion in 'Boxers/TR/M' started by Elberoth, Sep 26, 2022.
  1. Elberoth
    Elberoth Karting
    Feb 12, 2022
    68
    Warsaw, Poland
    Adam
    I can buy a lightly used aftermarket exhaust for a non-catted TR.
    Is it possible to install it on a 1991 TR with a cat? (after removing the cats)
    If the downpipes are the same, that sould be possible me thinks. I may need to well the lambda hookup points (or remove the secondary lambda sensors with cat-ECU completely), but that is not a big issue.
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,394
    Alabama (was Mich.)
    Jeff
    A picture of the exhaust system would help, but it should likely fit okay - if you remove the Cats from your TR. You will need to keep the Oxygen Sensors so hopefully there are bungs for installing those. But you will not need the Thermocouple Probes anymore, these can be removed.
  3. Steve Magnusson
    24,410
    #3 Steve Magnusson, Sep 26, 2022
    I would say "no" as the exhaust headers are quite different -- the non-cat headers are much longer with not staggered outlets:
    non-cat:
    https://www.ferrariparts.co.uk/diagram/ferrari/testarossa-tr-90/019-exhaust-system-(for-b1-rhd1-version)
    with precats & cats:
    https://www.ferrariparts.co.uk/diagram/ferrari/testarossa-tr-90/020-exhaust-system-(for-us-sa-and-cat-version)
    A couple of other things that might be issues:
    I think the rear exhaust grills are also different -- i.e., the tailpipe outlets might be in different places, but haven't looked for photos.
    and
    The 4-piece non-cat silencer may interfere with the charcoal canisters on a US TR.
  4. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,394
    Alabama (was Mich.)
    Jeff
    As Steve points out there are major differences between the Euro and USA exhaust systems - you can't mix-n-match these. I was assuming both systems were for the same market....sorry...... :-/
  5. Elberoth
    Elberoth Karting
    Feb 12, 2022
    68
    Warsaw, Poland
    Adam
    Thanks guys, the exhaust manifolds are indeed different.
