Window switches - stronger replacement | FerrariChat
Discussion in '612/599' started by RegW, Feb 13, 2020.
  1. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
    The plastic levers have proven to be fragile and it would be useful to find a stronger replacement from an Alfa or Fiat (instead of having to order a full electronic unit from Maranello with switches that might break soon after again). Below the part numbers of Magneti Marelli...who wants to join this treasure hunt? You can see it was originally designed for a 4 window car and the switches simply plug into the base. Image Unavailable, Please Login Image Unavailable, Please Login
    Sent from my Moto G (5) Plus using FerrariChat.com mobile app
  2. George Vosburgh
    George Vosburgh F1 Rookie
    I've never thought the switches on the 599 to be a problem and I've not heard of anyone having the problem you are speaking of.
    Has anyone here had this problem??
  3. RegW
    RegW Karting
    Aug 8, 2017
    62
    London
    Forgot to specify - this is for a 612 - not sure how different they are from a 599
  4. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    491
    Holland
  5. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,778
    Weston, MA
    Paul
  6. diegolrz
    diegolrz Karting
    55
    Dallas TX
    I need to fix the window switches and would like to know how to safely remove the door panel. Would you mind giving me some quick steps to follow? Thanks
  7. Nospinzone
    Jul 1, 2013
    7,778
    Weston, MA
    Paul
    Sorry, I didn't do it myself, it was done by an independent Ferrari shop. You might try having either a dealer do it or an auto body shop.
  8. brogenville
    brogenville Formula 3
    2,252
    Robin
    Just removed my door (the rod that connects the handle to the latch had decided to unscrew itself [emoji37]). From memory:
    X3 screws at the bottom of the door
    X2 plastic plugs on the edge of the door seal then pull back seal from side of door
    Pop off triangle behind mirror and undo x1 nut for door card
    Rotate door vent connector then undo x1 bold inside vent
    Lift door handle and undo Allen bolt to remove trim
    Undo cables from door handle
    Undo x3 bolts behind door handle
    Pop door card off plastic clips then lift away from door.
    You’ll need to have the window down to get the card back on. This is due to the position you need to get it into to get the top clips on.
    599_GTO likes this.
