Winter testing 2014 | Page 9 | FerrariChat
Winter testing 2014
Discussion in 'F1' started by DF1, Jan 27, 2014.
  1. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Exactly. Why would they even care? Added weight?
    Why not just re-design their turbo housing to capture debris in the event of a turbine wheel failure and lose 3-4kg's in the process? Oh, the whining has begun!
  2. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    What did they do in the last turbo era?
    I remember neither containment vessels (how Chernobylesque) nor schrapnel.
  3. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Wouldn't they only have to create a ballistic cover for the turbo versus redesign the entire engine?
  4. MisterMaranello
    MisterMaranello F1 Rookie
    Apr 5, 2011
    3,335
    Europe
    #204 MisterMaranello, Jan 29, 2014
    Agreed.
    How hard can it be? Get rid of the cover and make the turbine housing strong enough to contain itself.
    Lighter cars = less fuel consumption = less compromise during races.
    Yeah but it probably requires some reworking of the turbo as well. The Ferrari turbo might be a bit heavier than the other units since it can contain it's own debris during a failure. Adding a ballistic cover would make that function redudant, and hence
    unnecessary weight.
  5. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    3-4 Kg high up in the engine can have an effect on car balance.
  6. ricksb
    ricksb F1 Veteran
    Apr 12, 2005
    9,975
    Montclair Village
    B. Ricks
    Let the games begin!
    On the other hand, less weight on the top for the other teams would result in a lower center of gravity...it seems the easiest solution would be to attempt Ferrari's interpretation versus trying to penalize them for a different approach.
  7. MisterMaranello
    Apr 5, 2011
    3,335
    Europe
    But to be honest, I don't think this is a real issue. Its just whining from other teams. The regulations say nothing about how the car must contain the debris, as long as they are contained in case of a failure. There has been no official complaint towards Ferrari or any statement from the FIA. It seems that for the moment they (Charlie Whiting) are satisfied with the safe operation and implementation of Ferrari's solution.
  8. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Seems reasonable....
    Seems reasonable..... ;) meets the regs it would seem.... As long as it 'contains any significant debris', they're good, surely? Nothing to see here......
    Cheers,
    Ian
  9. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Again was this an issue in the last turbo era?
    Engines were spinning a lot faster then and pressures higher but I done remember any schrapnel incidents. Grenades yes but shrapnel no.
  10. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Not sure about more rpm and higher pressures back then, but fer sur they weren't as 'safety conscious' as they are now....... They don't want red hot turbo debris flying into the stands I guess, which kinda makes sense.
    Cheers,
    Ian
  11. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    The old turbos were much more highly stressed. 1000BHP in Q trim.
    Fan safety is paramount but if there's no danger why bother?
    You don't want them spewing anti-matter but that's not regulated against.
  12. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    Even more if Dr Theissen is to be believed! *But*, they also only lasted for that one Q session! They swapped (most of ;)) 'em out before they had a chance to destroy themselves and everything around them.
    I hear you brother, and don't disagree. But again, this year they get (IIRC) just 5 'power units' for the entire season. As you well know, they used to use that many in a weekend back in the 'good old days'.
    Times change. I'm not saying for the better, but it's one hell of an engineering challenge......
    Cheers,
    Ian
  13. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    That all means that they're stressed even less. Why the sploshin concerns?
  14. Fast_ian
    Sep 25, 2006
    23,397
    Campbell, CA
    Ian Anderson
    That, I cannot answer! ;)
    I do know that something, anything, spinning @ over 120K contains a lot of energy.....
    Cheers,
    Ian
  15. 05011994
    05011994 Formula 3
    May 1, 2004
    1,865
    Golden, Colorado
    I listened to the F1 Magazine podcast this morning and Craig Scarborough said peak power for these motors is around 10,000 rpms, that they actually lose some power above that level. He also reiterated that the drivers will need to drive towards a fuels saving strategy and that the energy recovery system would be vital to posting competitive laps. The fall off will be much more if there are issues with the batteries as the additional power that they generate will be around 180 bhp and the need to conserve fuel is so important. According to Scarbs if the cars run full speed, they are out of gas after an hour which will be a major concern for power tracks such as Monza, Spa and Montreal.
  16. crinoid
    crinoid F1 World Champ
    10,042
    LaCrinoid
    Wow. This might be my last year watching F1... Tired of this BS.
  17. DF1
    DF1 Three Time F1 World Champ
    This is not looking like a 'pinnacle' right now. Surely Formula-E is not so restricted.
    If they cant run 1 hour at Monza the mecca of speed F1 has lost it. I hope this is not true.
  18. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Cribbage is looking like an exciting alternative.
    I mean this is a spoof. Right?
    The real F1 cars will be announced tomorrow with a big GOTCHA!
    Right?
    Right?
  19. piolaxo
    piolaxo Formula Junior
    Feb 24, 2012
    647
    Bay Area
    Salvador
    Which ones? The Marussia's of the world? :)
  20. TOOLFAN
    TOOLFAN F1 Rookie
    2,807
    California
    I hope this year fails from a spectator turnout and viewership standpoint and they re think the fuel load aspect. Give them more fuel! F1 should NOT be about fuel saving endurance 'racing'.
  21. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    We can hope.
    The pictures look like cartoons.
    Did all the designers spend too much time watching Disney's Cars?
    An abomination!
  22. VIZSLA
    Jan 11, 2008
    41,693
    Sarasota
    David
    Last year's tire fiasco taught them nothing.
  23. Igor Ound
    Igor Ound F1 Veteran
    Sep 30, 2012
    8,102
    The Horn
    Igor Ound
    My exact feelings on the Ferrari. You could imagine Donald Duck coming out from the helmet. They should have called it the f 313.
  24. subirg
    subirg F1 Rookie
    Dec 19, 2003
    4,378
    Cheshire
    So the shambolic sound we are hearing from the cars is as good as it's going to get. And the cars are barely faster than GP2?!
    What a debacle.
  25. TOOLFAN
    TOOLFAN F1 Rookie
    2,807
    California
    Ugly, slow, and fuel saving, what's not to like?
