News
Wiring Diagram for 430 radio?
Discussion in '360/430' started by FullRiot, Oct 30, 2009.
  1. FullRiot
    FullRiot Rookie
    Oct 24, 2008
    11
    Does anyone have a wiring diagram for a 430 radio w/ subwoofer? Specifically how to integrate the factory amp. Amp turn on wire colors (+which harness) and is it low level or high level inputs? Willing to paypal some money for info, thanks!
  3. Irish
    Irish Karting
    Mar 18, 2009
    201
    #2 Irish, Oct 30, 2009
    Please find enclosed info, this is from a Becker Mexico which is a retro looking unit I have installed in my 60s and 70s Ferraris and in my experience wiring is the same, good luck.
  4. sclja
    sclja Formula Junior
    391
    San Diego Ca
    Scott Cairncross
    the diagram works... What are you planning to change the radio or the amp?
    Scott
  5. FullRiot
    FullRiot Rookie
    Oct 24, 2008
    11
    Thanks so much!! Changing the radio, want to try to keep the amp, for now...
  6. sclja
    391
    San Diego Ca
    Scott Cairncross
    You can get a standard european mercedes/vw harness from any car stereo shop along with a european antenna female to motorola male adapter. The stock amp uses 4 channel speaker level input so any radio will work with it.
    Scott / La Jolla Audio
  8. FullRiot
    FullRiot Rookie
    Oct 24, 2008
    11
    Everything went very well. I did have a problem with a turn-on "static" type pop when the amp kicked in. It happened right before audio played and I believe it was on every source, and only if the car wasn't turned on in the past 10 or so minutes. Weird, but with the engine running you dont even hear it.
  9. m.roberts
    m.roberts Formula Junior
    Nov 2, 2009
    907
    any recommendations for an aftermarket headunit?
