ZF S5 325 Gearbox Values>? | FerrariChat
Discussion in 'Maserati' started by 19633500GT, Sep 26, 2016.
  1. 19633500GT
    19633500GT F1 World Champ
    12,027
    Blueberry
    Muffin-Tops
    Hey guys, thinking of selling my spare gearbox.
    What is a fair price range? Is it more desirable to Iso guys? Aston guys, or Maserati?
    Just looking for some input, and as I'd asked if the other thread, will the S/N on the gearbox tell you which car it originally belonged to?
    -Ken
  2. velocetwo
    velocetwo F1 World Champ
    Dec 11, 2006
    12,536
    Left Coast
    I sold one to a Iso owner for over 12 k
  3. 19633500GT
    12,027
    Blueberry
    Muffin-Tops
    How long did it take you to sell it?
    Appreciate the reference point.
  4. 19633500GT
    12,027
    Blueberry
    Muffin-Tops
    Ok. Yes I think via some research that $12-15K is a realistic price. This ones complete and in good condition
    Also, fitting Aston, Iso and Maser etc helps
  5. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    I have a couple of these gearboxes gathering dust in my garage. I am curious what you are able to get for yours.
    When you say it is complete ... you should to be more specific. Does it have the shift lever? if so, which one (the Indy and Ghibli use different levers). Does it have a bell housing? If so ... which one (the Indy and Ghibli are different).
    Put it on ebay and see if you get any bites .....
    Ivan
  6. 19633500GT
    12,027
    Blueberry
    Muffin-Tops
    I believe it's Ghibli bell housing. Ghibli shift lever. It is missing it's dip stick tube.
    I had a spare in 2012, without the shift lever, oil tube, and it lasted like 45 minutes on eBay, a gentleman in Las Vegas purchased it (maybe $8,250? I'm trying to remember) for which car though I don't remember, this one was set up for DB5/DB6.
    Do you have a list of everything they fit? I know Iso (Rivolta AND Grifo? or?) Aston, Maserati Mexico/Ghibli/Indy? Are there more?
    Thanks for the guidance
  7. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    You should post several photos so that we can see what you have and can best help you identify the bell housing.
    "I think it is a Ghibli bell housing" is not a good enough description for an effective ebay listing. It either is or is not a Ghibli bell housing. If it is then you have something that is much more desirable as those bell housings are quite rare. You may want to sell the gearbox separate from the bell housing.
    While all Ghiblis with a manual tranny used this gearbox not all Indy and Mexicos used it.
    Ivan
  8. 19633500GT
    12,027
    Blueberry
    Muffin-Tops
    #8 19633500GT, Nov 30, 2016
    Agreed. I just don't know tons about the specific layout on the bellhousings
    I also have this stored in CA at my friends shop, but I'm thinking of taking it apart and cleaning it all too.
  9. red27
    red27 Formula Junior
    Sep 7, 2010
    833
    London UK
    Mark Oliver
    If it helps pin down the species of bellhousing, the Ghibli had 2 different part numbers depending on the type of clutch used.
    115TF63571 for the early 9 1/2" twin plate, and 115TF63403 for the late 68 introduction
    Of the 10 1/2 inch single plate. I would broadly agree with the assessment of value stated by previous posters.
    GLWS.
    Cheers.
    Mark
  10. Scott98
    Scott98 F1 Rookie
    Nov 3, 2004
    2,739
    Weston, FL
    Scott
    Threads like these illustrate just how stunning the wealth of information on this forum is.
    Scott
  11. Bisgaard
    Bisgaard Rookie
    Feb 14, 2015
    31
    Denmark
    Oluf Bisgaard
    Woow, I just wish that my Indy 4900 1972 was born with a ZF gearbox instead of the Borg Warner...
    I guess its a bigger job to modify it, even if I had the ZF.
    Dont You think so, Ivan? :)
  12. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    I once converted a Ghibli spyder from auto to the ZF 5-speed and must say it was a job. The problem is that at least on the Ghibli the mounting points for the ZF tranny were not present. Also the automatic gearbox is wider and the frame is slightly different. The removable cross member (which has the tranny support) from an original 5-speed Ghibli was not be long enough and I had to come up with an alternative. This all can be done but will take some time and patience.
    Best thing to do is to find an Indy with the ZF gearbox, put the car on a lift and take a lot of photos and measurements.
    Ivan
  13. velocetwo
    Dec 11, 2006
    12,536
    Left Coast
    sorry it was so late I sold mine within one week. maybe a it sooner. Iso guys want them for the automatic grifo's
  14. Bisgaard
    Bisgaard Rookie
    Feb 14, 2015
    31
    Denmark
    Oluf Bisgaard
    Thanks Ivan, I thought so. :)
    I will have to live with my auto box and the low rearend ratio...
  15. thecarnut
    thecarnut F1 Rookie
    3,019
    Atlanta
    The Car Nut
    #15 thecarnut, Feb 16, 2017
  16. santarosaferra
    Nov 23, 2015
    1
    where in CA? maybe i can be of help. I m looking for parts to help rebuilding a friend's ZF . u can contact me offline. Thnks
  17. robinlarry
    robinlarry Rookie
    Aug 22, 2007
    8
    Does anyone still have a ZF S5-325 available. I'm looking for one for an Iso.
  18. red27
    Sep 7, 2010
    833
    London UK
    Mark Oliver
    Jacques/MIE has one currently on eBay with this item number.
    123005818748
    cheers.
    Mark
