Replacing my 348 taillights
Discussion in '348/355' started by RandyT, Sep 29, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. itsablurr
    itsablurr Formula Junior
    789
    Carlisle, MA
    Matt
    I think the adapted slat grille is more in keeping with the design language of the 348, as are the older crisper-edged tail lamps, versus the softer-edged F355 style.
  2. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
    I agree. It would be a lot easier and cheaper to go with the slat design.
    The only thing I would need to do then is shave a little off the backside of the slats on the ends to make the yellow lights tuck inside nicely. The red lights already have plenty of room.
  3. CH_348
    CH_348 Rookie
    35
    Zurich, Switzerland
    Chris Steinacker
    Do you already have an idea what you are going to do with the two rectangle cutouts that were covered by the OEM rear light?
    Are you just going to put the same mesh behind it that ist behind the two center cutouts?
    Would definitely stick to the OEM rear grill in the way you photoshopped it, looks brilliant!
    If you ever consider selling this spec as a set, count me in :-D
  4. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
    Update:
    I cleaned up the cutouts, prepped the area and painted it satin black. I also made the screen that will go behind the openings.
    On the original grill, I removed the last vertical slat because I didn't like the look of the vertical slat over the new lights. I will fill in the old slat channel voids with new aluminum and clean up the welds.
    Then I will then shave down the second and third horizontal slats to fit the new lights. It only needs a little bit in the inside corners to make them fit over the new round lights.
  5. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
    HELP!!! ... Which wire go with which wire?
    Okay, I'm not an electrician, so I need your help with this! Here are the wire diagrams for the original 348 light and the new 308 style lights.
    The other photo shows the 308 style RED light lens with the white wire going to nowhere.? I don't understand why there's a white/blk wire going to a bulb socket that's backwards.
    Please help! Thanks.
  6. 4rePhill
    4rePhill F1 Veteran
    7,229
    Worcester, England
    Phill J
    #31 4rePhill, Oct 5, 2017
    I don't own a 308 so can't say for certain, but I would have thought the "reverse" bulb on the rear light assembly is to illuminate the rear trunk just behind the engine.
    TBH, I'd say your best bet is to ask on the 308/328 section about the 308 wiring.
    Edited to add:
    Yep - 328 trunk lights: http://www.ferrarichat.com/forum/threads/my-328-has-trunk-lights-wow-hi-tech.447752/
    (Reading that thread, not many owners realised they had them! :) )
  7. Tired of seeing this ad? Upgrade now
  8. Ricambi America
    Sponsor Owner
    Dec 7, 2003
    14,821
    Winston Salem, NC
    Daniel
  9. SoCal1
    SoCal1 F1 Veteran
    Rossa Subscribed Owner
    Jun 14, 2011
    6,857
    SoCal LA/OC
    Tim Dee
    Very cool I was thinking of doing the same thing. I'm in a fabrication mood lately that needs an itching.
    Defiantly leave the stock grill makes it look like it should
  10. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
    Thanks for link, but my 348 to 308 lighting is a bit different.
    Someone on this site must be able to help with my wiring diagram?
    UPDATE:
    Getting closer! I really like the look of the stock grill...
    ernie, CH_348, boat3 and 3 others like this.
  11. ghardt
    ghardt Formula 3
    1,105
    Texas
    Jerry
    Could the 308 white/black wire be for the euro fog light? I think the US 348 is wired for euro fog, but not utilized.
  12. 4rePhill
    4rePhill F1 Veteran
    7,229
    Worcester, England
    Phill J
    Could the answer be to ask on the 308/328 section? :confused:
  13. Nader
    Nader Formula Junior
    604
    East of Seattle
    Hammonds rider likes this.
  14. Tired of seeing this ad? Upgrade now
  15. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
    Different strokes for different folks.
  16. bjwhite
    bjwhite F1 Rookie
    2,642
    Seattle, WA
    Brian White
    Exactly. After all Nader, you have a tan interior. Yuk. ;)
  17. Vintage Racer
    Vintage Racer Karting
    Sep 22, 2006
    102
    10 Year member in GA
    Doc
  18. hashiriya
    hashiriya Formula Junior
    Feb 26, 2010
    324
    If you want to be different, I pretty much the look without the grille with your 308 lights. But it looks unfinished (too brutal for a Ferrari :) ), so if a sheet could be made to have concave shape (i.e. be closer to the bare sheet metal) and thus change the looks dramatically. You won't look like a 355 wannabe.
    Just some thought if you want to spend some more time, haha. And you'd be able to save the stock grille.
  19. Battleweapons
    Battleweapons Rookie
    Aug 16, 2017
    4
    Jerez De La Frontera
    Original is always good... but this very nice looking... and the mod on the grill is super nice ! Congrats.
  20. Al1exx
    Al1exx Rookie
    Nov 1, 2003
    18
    This looks awesome, great work!
  21. international blue
    Jul 6, 2008
    5
    I like the Challenge Grille as well, seems the stock grille is "later period" and the 308 look the previous generation. Very tasteful and reversible mod that looks complimentary and pleasing.
  22. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
  23. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
  24. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
    Time to start assembling!
  25. RandyT
    RandyT Karting
    142
    Calabasas, CA
    Randy T
  26. tracktoys
    tracktoys Rookie
    Feb 5, 2017
    5
    Wales UK
  27. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    20,882
    The Brickyard
    The Bad Guy
